Page 335 of 854 FirstFirst ... 235285325330331332333334335336337338339340345385435835 ... LastLast
Results 5,011 to 5,025 of 12803
  1. #5011
    DK Veteran bibkare's Avatar
    B & H
    Quote Originally Posted by deluss View Post
    Need to desolder something like R50 ?
    @delussYou can remove or leave R50 it doesn't matter, only remove STC or break a pin like in kolimer's picture.
    @ni88l3r you should check eeprom 93c46 or 93c56 whatever is on your pcb
  2. #5012
    Jan 2017
    Quote Originally Posted by bibkare View Post
    It's a 93c46, but how should I check it?
    A quick google search shows options to desolder it and read it with a programmer.
    Any options to read it direct on the board?
    I have the USBasp and an USB-TTL-Converter but I'm not deep into those things (Needed the USB-TTL-Converter for recovering a Seagate Barracuda HDD and followed a tutorial).
    Edit: If it's not possible to read/program it with my tools - this should do the work? http://www.ebay.de/itm/51-Microcontr...-/381844470039
    Thank you!
  3. #5013
    3 methods:
    1. read by MProg. If MProg = 0403/6001 ==> a. defective eeprom or FT232B or b. erased content of eeprom. try read by 2 or 3 method for see where is the problemm.
    2. read directly on pcb with a external tool. Not always work. I preffer 3.
    3. desolder and read/write. Attn, for WRITE correct content must have it, read from another good eeprom or from another source.
  4. The Following User Says Thank You to liviudiaconu For This Useful Post:
    ni88l3r (13th June, 2017)
  5. #5014
    Jan 2017
    Thanks @liviudiaconu!
    I ordered a new FT232BL and 93c46 and will try them, when they are here from China.
  6. #5015
    Feb 2017
    Could you post a link to a cable with BL chip?
  7. #5016
    Jan 2017
    Quote Originally Posted by ireun View Post
    Why do you want one with BL? My BL is in an old cable from 2011, so I don't know if there are still any.
    When you want a new go for the R, they don't cost much more than the crap ones. I got mine from obd2cartool.com (v17.1 - they have photos of the chips on their site).
    I will get my 232BL and the 93C46 from this gadget http://s.aliexpress.com/VNvyER7N (will unsolder the chips).
    Hope this helps!
  8. #5017
    Apr 2016
    Having some hard time with my cable. Bought recommended interface 17.1 from obd2cartool. Tested with original software and it worked. Then flashed atmega with new 17.1.3 firmware (flash, eeprom, fuses) and now vcds test gives "self test failed" error. I'm using elnec smartprog2 programmer and maybe there are some parameters that need changing? Any suggestions what to try next?
  9. #5018
    May 2015
    argentina
    Hi, what is the latest version available?
    I have the vag-with 12.12
    Can you upgrade?
  10. #5019
    Thanks Kolimer and @all. Successfully upgraded VAG118, tested and working.
    One question... STC should be resolder on board? Thanks
  11. #5020
    Feb 2013
    No, STC stay.s out.
  12. #5021
    B & H
    Quote Originally Posted by ivohi View Post
    Reprogram again but pay attention to fuse settings and proper flash for your hw (44 or 46)
  13. #5022
    I have tested my RL tool and on 32bit system works perfect with kolimer 17.1.3, don't know why on 64bit it doesn't make long coding. I use same flash,eeprom and ept files.
  14. The Following 2 Users Say Thank You to 1 6 D For This Useful Post:
    bibkare (20th June, 2017), paro44 (21st June, 2017)
  15. #5023
    B & H
    Quote Originally Posted by 1 6 D View Post
    thanks for sharing, i will test it also and report
  16. #5024
    Jun 2017
    Hello guys,
    I am using this adapter from Aliexpress. Works with the official VCDS 17.1.3 but cannot do long coding (says coding accepted but it is not saved). I guess I cannot reprogram it since it does not seem to be atmega? Would using an older version or cracked version work?
    The PCB: https://img15.hostingpics.net/pics/2...0872517593.png
  17. #5025
    Jan 2016
    try with a 32bit system
