Page 336 of 854 FirstFirst ... 236286326331332333334335336337338339340341346386436836 ... LastLast
Results 5,026 to 5,040 of 12803
  1. #5026
    [...]The PCB: https://img15.hostingpics.net/pics/2...0872517593.png[...]
    @Kolimer - tried to find what uC is that HL008 706GB...
    Nothing.
    Can you tell me more about it?
    Thank you
  2. #5027
    Jun 2017
    Quote Originally Posted by uragan1987 View Post
    try with a 32bit system
    I did. Tried on Windows 10 x64 and Windows 7 32 bits. Just says "coding accepted" but the coding does change in fact. I just need to change one parameter with long coding and everything else works...
  3. #5028
    Jun 2017
    Nothing.
    Thank you
    Not sure did not find info either and the item was removed from Aliexpress (and the snapshot doesn't work either), but it said that it is compatible with 17.1.3, no updates possible but it is Internet safe, meaning it cannot be bricked and it indeed cannot, tried with Internet and the French version of VCDS (which says it is unlicensed) but the English version still work.
    On the plastic casing it says "VAG 17"
  4. #5029
    Thank you.
    Similary as NEC D79F... based cables, the firmware are modified. And the command "burn eeprom" cannot do what must do.
    So, this cables work without damage.
    What you wrote is OK, real, but my question is "what uController is mounted on PCB?"
  5. #5030
    Jun 2017
    Thank you.
    Either way it does not look like it can be re-flashed. It works well but long coding doesn't work and I need it just for that :/
    Is there a cheap source of CAN compatible dongle that supports long coding (for a 2005 VW). I only intent to use it once so the cheaper the better
  6. #5031
    istanbul
    hello friends
    i want to buy vagcom
    i found this
    seller says support golf 6 17.1.3 ver 24 usd and full chip
    what is your idea?
    https://www.aliexpress.com/item/2017...8-3715a8a05f02
  7. #5032
    Feb 2017
    Quote Originally Posted by onemsiz20 View Post
    hello friends
    i found this
    what is your idea?
    Hello. I would recommend you this cable: https://www.aliexpress.com/item/VAG-...819067879.html
    From this seller: https://www.aliexpress.com/store/2411061
    He is a very kind seller, I've ordered many cables from him, everything was as expected. And he is shipping with a priority shipping, the one that you've linked to, has send me a cable using Malysia post. The shipping took 55 days! So I would not recommend him.
  8. #5033
    Jan 2017
    HongKong
    Hi, pcb is ok, but whether support golf 6 it is depend on your car
  9. #5034
    May 2017
    Quote Originally Posted by ireun View Post
    But work on windows 10 home x64 ?
  10. #5035
    Feb 2017
    Quote Originally Posted by pepeEL View Post
    Yes, I've tested it on Win 10 x64 Pro, and even on the USB 3.0 port - everything works! Can works, long coding also.
    Wysłane z mojego SM-G900F przy użyciu Tapatalka
    Guys, now on Aliexpress you can find HEX v2 version of VCDS. This will be somewhat of a review of this cable..:
    It looks exactly like the original version, the cable is detachable and has to lock screw in it. Overall it looks very high quality. But the look is not all.
    I've connected this cable to my PC. No updates, no internet connected, just like it should be. I've used software provided on the CD.. In the test tab it looked like this:
    Not good, Atmega cables always showed 'OK' on the Kx lines..
    Well I thought this will look different if it was connected to a car.. So I went to do some testing..
    I've connected it. and status was all 'OK' except of CAN, which is not available in my car.
    I've connected to the '01 Engine' module, no problem. Than I wanted to do 'Auto Scan' I've selected my car, it checked module 01, and that's all it successfully checked. I've done another test..
    Not quite what it should be, again..
    I've reconnected the cable, same thing. No matter what. I've tried ignition of and off, engine on and off. Every possibility I could think of. The cable was disconnecting all the time, other errors were like this:
    Of course it was connected..
    Other error:
    I've spent 40 minutes trying to get it to work. No luck..
    The PCB looks like this:
    Overall I would NOT RECOMMEND this cable. But maybe it's just my unit...
  11. #5036
    must be checked LM and transistors. i have saw one new clone and is working perfect. long codding etc.
  12. The Following User Says Thank You to ovi730 For This Useful Post:
    mircea13 (15th October, 2017)
  13. #5037
    Feb 2017
    Quote Originally Posted by ovi730 View Post
    Sorry, what is LM?
  14. #5038
    Feb 2013
  15. #5039
    Feb 2017
    Thanks, there's just one problem.. There is no LM7805 on this PCB, not anything similar..
    here's the back photo..
  16. #5040
    Jun 2017
    Yes on the back of the PCB, the chip you see is probably the voltage regulator. Test it with a multimeter.
    What's the point of HEX v2 anyway?
