Page 348 of 854 FirstFirst ... 248298338343344345346347348349350351352353358398448848 ... LastLast
Results 5,206 to 5,220 of 12803
  1. #5206
    May 2017
    17.1.3 and 17.8.0 makes problems
    I go back on my cabel to flash and eeprom 11.11.5 and all works ok.
  2. #5207
    Sep 2013
    hi, please tell me what hw version is this interface20170924_213606.jpg20170924_213620.jpg
    it came with 17.8.0 en
    and what is the difference with this one 20170925_011230.jpg20170925_011316.jpg
    wich one has better hardware protections and more stable.
    sorry for poor quality of photo
    thanks for answering
  3. #5208
    Jan 2016
    You can see for yourself but second one is better. It has GAL and other needed components.
  4. #5209
    Jul 2016
    Vilnius
    None of them have a diode on the 16th pin. I got a similar interface (links to it below). Bought the protection diode for like 0.03€, soldered it in, flashed 11.11.0. Works fine, as far as I have tested. I don't need much new features, basically just read and clear fault codes and check some measuring blocks. I'm happy with it.
    https://ibb.co/fPX5p5
    https://ibb.co/bK5EhQ
    https://ibb.co/fz9wwk
    https://ibb.co/coZkp5
    https://ibb.co/dTBbwk
    * MK100
  5. #5210
    tested -V2 work very good on ft232bl.Thank you Kolimer!
  6. #5211
    May 2017
    Hi All
    VCDS with PATCH KOLIMER STOP WORKING
    Please verify your VCDS with patch v2 from KOLIMER. Yesterday my VCDS stop working... and show in VCDS that is UNREGISTERED. Before all working ok. Yesterday stop working. It stop working on all version 17.8 and 17.1.3
    Please verify it.
    Screenshot with problem
  7. #5212
    Feb 2013
    After re-install will stay Unregistered?
  8. #5213
    May 2017
    Yes. And tested on two PC/Notebook
  9. #5214
    Jul 2016
    Vilnius
    To me it looks like 11.11.0 is still the most stable version to use
    * MK100
  10. #5215
    May 2017
    I found only one solution. Uninstall VCDS and delete all directory. Then disconnect INTERNET. Again install VCDS and Copy patch VCDSLoader. Run test and licence is VALID. Then go to Firewall and block output and input for soft VCDSLoader.exe.
    After this VCDS works ok and i can enebale internet. Licence is not block.
  11. #5216
    fantomel's Avatar
    Mar 2009
    Us
    you found 0 mate, someone told you how to, and i am sure that all users that read forums about vcds know that all cloned keys get blacklisted at some point. This is why Kolimer gave you usb flashing to restore easy your cable.
    Do you think that RT does not look on forums?
    If you like my post and it helped you please press THANKS.
  12. The Following 3 Users Say Thank You to fantomel For This Useful Post:
    cocutanu (5th October, 2017), hartklep (7th October, 2017), paro44 (6th October, 2017)
  13. #5217
    Hungary
    Hi, Gentlemen,
    I have an old 11.11 cable with ATMega of course. I'd love to repair it. Problem is:
    Status: Questionable
    K1: OK
    K2: short to +12V
    I've checked the four transistors they seemed to be OK.
    Tried to reflash (now 17.1 on it) didn't help. Same error.
    Please.... If someone has any idea, I would be glad to hear it :-)
    TIA
  14. #5218
    Photos with both sides of PCB.
    IF have that transistors, change-it them directly. IF not, replace one with another on similar position. After this movement IF transistor defective, must have K1-short to +, K2 OK.
    If not, the problem is in GAL if have (that i asked you photos), atmega, copper tracks..etc
  15. The Following User Says Thank You to liviudiaconu For This Useful Post:
    ivicz (6th October, 2017)
  16. #5219
    solution is loader that work with empty eeprom
  17. #5220
    Hungary
    Here are the photos of the PCB. What's the exact route of K2 from PIN15 to ATMega? Tried to swap transistors... No success...
