Page 349 of 854 FirstFirst ... 249299339344345346347348349350351352353354359399449849 ... LastLast
Results 5,221 to 5,235 of 12803
  1. #5221
    Quote Originally Posted by ivicz View Post
    Attachment 477441Attachment 477442
    Here are the photos of the PCB. What's the exact route of K2 from PIN15 to ATMega? Tried to swap transistors... No success...
    Why?
    Test Result?
  2. #5222
    Hungary
    Why?
    Test Result?
    Same. K2 short to +12
  3. #5223
    Look at this photo...check continuity.
    If all right, possible GAL/ATF defective or atmega.
  4. The Following 3 Users Say Thank You to liviudiaconu For This Useful Post:
    ivicz (7th October, 2017), makadam (1st November, 2017), SergeyIg (13th October, 2017)
  5. #5224
    Hungary
    Thank you very much. What schematic is it? Top secret?
  6. #5225
    Jul 2016
    Vilnius
    I have exactly the same interface. Minde is working fine (so far).
    If you find something suspicious while checking continuity, let me know, I might look up on mine to check if there is a continuity or some resistance between certain components...
    Your interface board looks a bit "oily".
    What I hate about it that there is no pins on the board (not a free space to drill and solder them permanently) for programming.
    I paid 5 Euros to solder a few wires to the chips
    Also, I have added a protection diode to the 16th pin.
    * MK100
  7. The Following User Says Thank You to hid3 For This Useful Post:
    ivicz (10th October, 2017)
  8. #5226
    "Give a finger to one person and he will take entire hand"...
  9. #5227
    Hungary
    Just was a question....
    "Thought won't get a slap in face for it..."
  10. #5228
    Oct 2017
    Dear Members!
    I'm new here. I've got a Chinese clone cable, low end type - I guess. Atmega, 232RL, MCP2515, MCP2551. Two oscillators, some resistors, etc. No GAL, no 7805. If it's pluged, three low beeps. Red LED begins to flash. In Windows Control Panel: Ross-Tech HEX-USB. VID/PID: 0403/FA30. MProg: Blank devices/Programmed devices: 0/0. VIDPIDFix: nothing. If Atmega erased: no blinkong, but 3 low beeps. It flahsed: RED blinking. What the hell could be the problem?
  11. #5229
    Plug-in in a car and led became green. What functionality can have cable without well conditions?
    Btw, your cable is a very low quality, aka named [by me] "petard".
  12. The Following User Says Thank You to liviudiaconu For This Useful Post:
    cloudless (11th October, 2017)
  13. #5230
    Oct 2017
    For example: "Interface found. Not plugged into car." or MProg reading/programming
    Petard? Why? Is it explosive?
    Should I do any modification for better/safer performance?
  14. #5231
    Oct 2017
    You were right, the LED became green, BUT still not recognized. "No interface found" (VCDS), no interface found (Windows)... After several reflashing.
    I don't understand why Windows shows the interface in Control panel with the right VID/PID with yellow "!" but neither Mprog nor VIDPIDfix can see anything....
  15. #5232
    You think you're smart and / or spiritual, but let's get over.
    "For example: Interface found. Not plugged into car. Or MProg reading/programming" - this is not a feature, it's just a possibility sometimes necessary.
    "Petard? Why? Is it explosive?" No, but like a petard, it only smokes and noises, nothing useful. That's a shameful quality
    And returning to serious business. If the driver is not installed correctly, without "?" or "!", you will not succeed. Btw, FA30 is for "bulshits" or "petards" programs cables. If want use Kolimer's solution, PID_FA24
  16. #5233
    Aug 2012
    EU
    Hi all
    needed dump and software for vcds 12.12 clone
    sorry for me bad english.
  17. #5234
    Oct 2017
    My children also think the same
    Thank you. I'll find it.
  18. #5235
    Oct 2017
    Quote Originally Posted by cloudless View Post
    Did you solve this ?
    I have the same cable as yours and works like a charm.
  19. The Following User Says Thank You to uh60 For This Useful Post:
    cloudless (12th October, 2017)
