i just draw in simulator.. check for more info on google
or NE555 datasheet
or NE555 datasheet
Can You KenshinPT tell me, does your 908 dump supports also CAN bus, because, when I use it, I can see only K-line -OK, Can - Not ready. I have Skoda Octavia 1.9Tdi 81kW, model year 2002(I suposse, I have can in the car). Can be problem in FTDI chip, because I have FT232BM and You use FT232BL or RL?![]()
hi guys a simple question its possible update a file labels of vag 10.6 clone version from original 10.6.3????
file label from 10.6.3 version!!!
Code:http://hotfile.com/dl/87985066/26c9f3f/Labels.rar.html
Original Vag-Com HEX-USB+CAN Rev.B from Ross-Tech...
ELM 327 chinese with 1.4b "genuine" soldering pic!!!
OK, when I haven't CAN bus, how can I connect units like (09-Cent.Elect., 35 - Cenrt. Locks, 25- Immobilizer,etc.) I am shure, that I have this units, but I can't connect to them.When I use Auto scan (I can see units: 01: Engine, 03: ABS Brakes, .08: Auto HVAC, 15: Airbags, 17: Instruments, 19: CAN Gateway, 46: Central Conv., 56: Radio)???
thanks a lot for this useful infos!!
Is there a Frensh dump for 90x.x version or 80x.x ?
thx
When I scan/code Airbag Module 8P0 959 655 J of Audi A3 2009 with VAG-Com 908 the VCDS tell me: No ASAM data for: "EV_Airba10AURB4" (AU35).
What means ?
Regards![]()
Hello.
Finally decided to upgrade my china cable v.8.05 after a long time thinking about it.
I used the package posted by KenshinPT (post #453) and all was good from the first try out.
First flashed the FTDI eeprom,then flashed ATMega162,and in the end set Security Bits.
Now i have a full features cable v.9.08.
Thank you.
Hello guys...First, I want to say that this topic is really helpful, and want to thank everyone who provided all those information....But...As I'm not so familiar with electronics (but i hope, in the near future, it will be changed, at least a little ) I'm looking for some help with pinouts for atmega162...
In the picture of my interface, where are pins 1-4???
The white dot on your PCB is next to the pin 1 from your ATMEGA chip. From that point count from left to right and you will have the nexts pins numbers..2...3...4...aso
Good Luck
White dot is circled with red now. From that dot the next red marked pins are 1-2-3-4. Counting the same as I did and going all around chip you will find others pins.
