Page 353 of 854 FirstFirst ... 253303343348349350351352353354355356357358363403453853 ... LastLast
Results 5,281 to 5,295 of 12803
  1. #5281
    Nov 2017
    that is my interface...
  2. #5282
    Jan 2017
    This interface is China invention HW with ARM CPU (not with ATMEGA162 as original has). This interface will NEVER be supported by Kolimer's loader. It's not V2 as described by sellers, but china HW in V2 cover.
  3. #5283
    Nov 2017
    Thanks for reply,
  4. #5284
    Oct 2014
    Netherlands
    Hi guys,
    Today I found my Chinese clone VCDS cable which is still working with the supplied (cracked) VCDS 15.7.0 software.
    I opened the cable and it looks very much like type HW 0x46.
    (pin 34+35 of ATMega162 are not connected to the ATF16V8B)
    I tried to read HW type using VAGCOM_HWType.exe, and hangs for a while and then says no reply.
    What could be the cause?
    Rgs H2Deetoo
  5. #5285
    Oct 2014
    Netherlands
    I have the *exact* same hardware as PepeEL in this post:
    http://www.digital-kaos.co.uk/forums...=1#post3093197
  6. #5286
    Jan 2016
    If you read thread careful you will find answer. Run 15.7 software, do test to unlock atmega, than run VAGCOM_HWType.exe
    Instruction for flashing your interface you will find on this thread also. Need to remove stc and few other components, or just break connection from stc, I think picture is even in instructions you already have. Just read careful
    BR
  7. The Following User Says Thank You to jakuza For This Useful Post:
    H2Deetoo (9th November, 2017)
  8. #5287
    Tunisia
    Quote Originally Posted by H2Deetoo View Post
    Hi guys,
    Rgs H2Deetoo
    you have to plug vcds cable to 12V
  9. The Following User Says Thank You to testourii For This Useful Post:
  10. #5288
    Oct 2014
    Netherlands
    I have done that, same problem.
    But I'll check again to be 100% sure. Thanks.
  11. #5289
    pt
    somebody notice that vcds stop working??
    solution is put date back to 1 November and work again (or use runasdate)
    i am using Pt version 17.1.3
    regards
    ze
  12. #5290
    Nov 2017
    hi obd2cartool,
    I bought this one from you, could you please tell me if this one supports reprogramming?
    Vagcom 17.1.3 En / De/ Fr Full VAG COM 17.1.3 crack latest VCDS
    http://www.obd2cartool.com/vagcom-17...version-p-1336
    Thank you for your replay in advance.
    --- delete this post please!!!
  13. #5291
    Nov 2017
    Quote Originally Posted by obd2cartool View Post
    most vag cable version hw with ATMEGA + FTDI chips support reprogramming like vag 11.11.3, vag 16.8.4, one kind need active 16.8.3 only support english version ,vag 17.1.0 . other like use original software (not office cable) it is used NEC project, we test different FT232 chips, there is no obvious difference. and Thanks kolimer and other friends!!
    hi obd2cartool,
    VAGCOM 17.1.3 EN / DE/ FR FULL VAG COM 17.1.3 CRACK LATEST VCDS 17.1.3 VERSION
  14. #5292
    Oct 2014
    Netherlands
    Just tried it again and now it works:
    FW Version : 1.94
    HW Version : 0x46
    Identification : ROSS-USA
    *EDIT* ah I read that it has worked now because I started 15.7 sw to unlock ATMega. Thanks!
    I will order an AVR programmer and try the upgrade!
  15. #5293
    Oct 2014
    Netherlands
    I had a broken interface which was HW version 0x44 but had the so called "bootloader" inside.
    So I could easily upgrade it using VAGCOM_EEWrite.exe
    Would it be possible to insert this bootloader in a cable which doesn't have it?
    Or does it require special hardware?
    Thanks to all for releasing this stuff!
    Rgs H2Deetoo
  16. #5294
    Oct 2017
    Germany
    The Interface is connected to 12V or OBD during HWType.exe? Ups, to slow
  17. #5295
    Mar 2017
    Hi guys i'm sorry to ask i now that probably somewere there is the answer but im not able to find on 353 pages i have a china vag com 912 with FT232RL can i update it to the last version? do you have any stable version to suggest? And finally were i can found a tutorial to follow to update? all the link that i found are down pls help me, tks
