Page 355 of 854 FirstFirst ... 255305345350351352353354355356357358359360365405455 ... LastLast
Results 5,311 to 5,325 of 12803
  1. #5311
    Nov 2017
    one more question before I connect the cable to 12V and try to reflash: Is it required to remove the STC chip? I have not modified anything on the cable, yet.
  2. #5312
    Oct 2014
    Netherlands
    @Majami, using 17.8.0 EN can you check an UDS cluster and go to Adaptation channels and choose "staging" channel and see what is read?
    Several people get a "km" result and not "active" as it normally should be.
  3. #5313
    Oct 2014
    Netherlands
    The STC will reflash the ATMega it seems, so you need to remove it if you plan to upgrade yourself. Otherwise the STC will reflash back to some old version.
    You can simply remove 1 resistor (R50) but you can also simply remove all (STC+RESISTOR+TRANSISTOR).
  4. #5314
    Feb 2017
    I can confirm that Beta 17.10.0 has some problems with CAN communication.
  5. The Following 9 Users Say Thank You to kolimer For This Useful Post:
    autodiagdoctor (16th November, 2017), H2Deetoo (16th November, 2017), ivica21 (25th November, 2017), jakuza (21st November, 2017), liviudiaconu (16th November, 2017), Majami (16th November, 2017), radsky (20th November, 2017), relax80 (19th November, 2017), tr3ce13 (16th November, 2017)
  6. #5315
    Oct 2014
    Netherlands
    Also 17.8.0 gives problems for several different users at least (UDS cluster adaptation f.e.)
  7. #5316
    Jan 2017
    HongKong
    Hi, friends
    we have new ATMEGA162 HEX-V2, HEX V2 VCDS 17.8 full active cable For VW Audi Seat Skoda VAG HEX V2 support reprogramming, full chips : ATMEGA162 + FT232RQ + 9241 + 16V8B +ATA6561... Special thanks Kolimer for his support!!!
  8. #5317
    Nov 2017
    Quote Originally Posted by H2Deetoo View Post
    Thanks for the reply. In my case the PCB is not numbered and the resistors not numbered, which one is R50?
  9. #5318
    Oct 2014
    Netherlands
    In that case I suggest to remove the STC completely, don't worry about the other components.
  10. #5319
    Oct 2014
    Netherlands
    @kolimer:
    I am working on VCDS protocol and I might have a small improvement to your tool EEType.
    As you know sometime the AVR doesn't respond when requesting fw version.
    It is mentioned here the cable must be "unlocked".
    But in fact this is because cable is in some other mode (lets call it "canbus" mode).
    You can send the following command to put the cable back in "command" mode :
    -> 53 04 A0 F7
    <- 4D 04 FE B7
    After you sent this command you can request firmware version again
    Also, for completeness, the following command will put the cable back in "canbus" mode:
    -> 53 04 B0 E7
    <- 4D 04 FE B7
    Feel free to contact me to discuss this protocol if you're interested.
    Rgs H2Deetoo
  11. The Following User Says Thank You to H2Deetoo For This Useful Post:
    seal777 (24th February, 2019)
  12. #5320
    Feb 2013
    There is possible to run vcds software from PC (NR.1) with the cable plugged into another PC(NR.2) using a internet connection with a remote/vpn software like Teamviewer?
    Same questions for flashing Atmega via usb in the same situation: interface connected on PC NR.1 and running software(VAGCOM_EEWRITE) from PC NR.2? Pc.s conected togheter via a wirelles network using Teamviewer or another software?
  13. #5321
    Hi forum!
    I'm looking into buying a VAG-COM cable for my 2016 Skoda Superb, but I dont want to spend $199 for a cable.
    Since it looks like there are many bright heads here, is there a cable you can recommend? I'd like to use Ross Tech VAG-COM 17.8 - need a cable to which is compatible with this software.
  14. #5322
    Apr 2013
    Look post #5316 for example
  15. The Following User Says Thank You to 2xded For This Useful Post:
    T_ac_S (19th November, 2017)
  16. #5323
    Spain
    hi i need help vcds loader blocks 91% in Windows 8.1,
    i have uninstalled vcds loader and vcds 17.1.3 remains the same.
  17. #5324
    Jan 2017
    Talking
    Quote Originally Posted by pacomasi View Post
    Wrong theard, we talk about Kilomer Loader and not China garbage.
    Forget Windows 8 and 8.1
  18. #5325
    Jan 2017
    HongKong
    Hi, you could try use newer vcds loader v1.10 to try , EST software this period not work very well, waiting for update newer
