Page 359 of 854 FirstFirst ... 259309349354355356357358359360361362363364369409459 ... LastLast
Results 5,371 to 5,385 of 12803
  1. #5371
    Jan 2017
    Will anyone write a new loader to work properly with version 17.8.1 EN/PL?
  2. #5372
    RF
    Quote Originally Posted by hid3 View Post
    So you mean that R0$$ made some amendments in versions later than 17.1.3 so that it stopped working correctly?
    Ross entered one more check of bytes checksum of public key into 17.8.0 versions of the program.
  3. #5373
    Jul 2016
    Vilnius
    Oh, I see, that explains the case then!
    Seriously, I think we need to stop using the terms such as \/(DS, R0$$ and etc. This gets indexed by google, this thread comes up easily in a simple search, and no doubt R0$$ reads this thread, sees what we are doing and tries to implement some blockage for this in order to make this happen harder.
    Also, a great idea would be to make this thread visible only for members having over certain amoount of posts, e.g. 30 or so. This would prevent people who only sneak in the forums from reading the contents...
    * MK100
  4. #5374
    RF
    ...a great idea would be to make this thread visible only for members having over certain amoount of posts, e.g. 30 or so. This would prevent people who only sneak in the forums from reading the contents...
    Restrictions will not prevent Ross to read this subject. He can be the moderator of this subject. Or for example I or you can be Ross actually.
  5. #5375
    Jul 2016
    Vilnius
    To be realistic, doubt that one of them are mods here. Also, doubt that their account (if they even have one) has got posts >30. They are busy guys which get paid for actual work done for the company and not for surfing/posting in some 3rd party forums... If they are browsing as guests and suddenly would lose such possibility, that would make it just a bit more difficult and time consuming to get an account with let's say >30 posts. And if they get one, then they'd have to share a single one accross multiple people just to read some stuff.
    Anyway, that was just an idea on how to limit the visibility from random people and search engines
    * MK100
  6. #5376
    Quote Originally Posted by magadan View Post
    If created the correct public key, and then calculated the new digital signature for atmega EEPOM, then long coding will work.
    But there is also other way until it was forbidden by Ross.
    I see that you have a solution for vcds 17.8 that solves the longcoding failure. Can you tell me more? Thank you
    Enviado desde mi Redmi 3 mediante Tapatalk
  7. #5377
    Jan 2009
    Hi to all the VCDS Gurus here!
    Wish you a happy christmas evening.
    i have read parts of this thread and my head is exploding :-)
    In the moment i´m using a China VCDS interface(form the PCB is think i`ve learned this is HW1 with FTD32BL)
    Becaus e BL, i have to use a loader? Right?
    its labeled with VCDS 805.1
    What is the newest version of VCDS if i try to flash the interface.
    I found Tutorial.pdf and would replace the parallel port thing with USB-ASP Programmer.
    Can you give me a hint which dump i should use and which VCDS Version to use?
    is 11.11.5 the latest i can use (longcoding needed) or can i use newer versions also?!?
    Best would be a version in German
    Thanks for help and Happy Christmas!
    Wene
  8. #5378
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by Wene001 View Post
    Wene
    Becouse you have FT232BL you DONT have to use loader (becouse that FT232BL dont have hardcoded uniq id) but as for kolimer's loader.. yes.. its needed to be used..
    but if you want only use not cracked 11.11 version then NO no need any loader or crack .. just flash your atmega162 with 11.11 dumps .. and also you need to remove that STC chip
  9. The Following User Says Thank You to xoom For This Useful Post:
    Wene001 (27th December, 2017)
  10. #5379
    Jul 2016
    Vilnius
    Hi!
    Your interface is exactly the same I had:
    https://ibb.co/fPX5p5
    https://ibb.co/bK5EhQ
    https://ibb.co/fz9wwk
    https://ibb.co/coZkp5
    https://ibb.co/dTBbwk
    1. You will need to solder out the STC chip completely
    2. You will need to solder additional wires for programming as the interface does not have one
    3. I would strongly suggest soldering in a protective diode for OBD 16 pin
    4. Your HW type is 0x44 and the chip is FT232BL
    5. Afterwards, you should clear the AT chip and program the Kolimer's dump
    6. Use 17.1.3 version w/Loader
    * MK100
  11. The Following User Says Thank You to hid3 For This Useful Post:
  12. #5380
    Working without problems in adapting or LC.Was tested on passat b6 1.9&2.0 &b5.5 1.9tdi.
    I use 2 hardware with BM & RL.
    All it is perfect.
  13. #5381
    I have a problem with vcds 17.8 and longcoding.
    There are solution for this?
  14. #5382
    Jul 2016
    Vilnius
    Again, long coding is NOT enough to confirm working properly.
    Also, your Passats are way too old, they don't have UDS protocol.
    * MK100
  15. #5383
    For the moment it is enough.for me it is working perfect.I use it only for my car, and ocasionally for others.
    I have vcds 17.3 pack, and if it 's necessary i'll do downgrade without problems.
  16. #5384
    Hi, i,m back in recovering VCDS interfaces, I use kolimer loader like few months ago but when I try every option there is always problem with long coding and *.rod files in 17.1.3. One is HW44 and secong HW46, both on FTDI RL. What could I do wrong?
    I can see that extreme burner dosen't make lock bit from FF to 3F, maybe it's why it works uncorrect?
  17. #5385
    Jan 2009
    Thanks to hid3 and xoom!
    Ive soldered programming pins, removed STC Chip
    Used the command avrdude -p m162 -c usbasp -e -U flash:w:Flash1.96_HW_0x44.bin:r -U eeprom:w:eepromavr.bin:r -U lock:w:0x3f:m -U efuse:w:0xf9:m -U hfuse:w:0xdc:m -U lfuse:w:0xcd:m
    to flash eeprom and flash. Installed cracked 17.1.3 in german.
    Looks fine so far, but i get many communication errors while usding vcds on my Audi A4 8K.
    What is the .epl file for?
    Do i need this Mprog3,5 software ?!? or is this only a other way for programming the atmega?
    Any hints?
    Thx Wene
