Page 373 of 854 FirstFirst ... 273323363368369370371372373374375376377378383423473 ... LastLast
Results 5,581 to 5,595 of 12803
  1. #5581
    Feb 2018
    Can this cable be used to download vcds on it's a old vag tacho it's worth a try asking cheers if so how do I go about it thanksIMG_4924.JPG
  2. #5582
    Jul 2016
    Vilnius
    Mate, why don't you want to just buy a quality cable and enjoy it?
    * MK100
  3. #5583
    Feb 2018
    Quote Originally Posted by hid3 View Post
    If I knew where the best place was and not pay £400 for it I think I would if you know some where I don't mind a pointer
  4. #5584
    Jul 2016
    Vilnius
    * MK100
  5. #5585
    Feb 2018
    Hi mate cheers for that but that hex v2 looks the same as I've got the disc come empty and problems since
  6. #5586
    Jul 2016
    Vilnius
    It's not the same as you posted previously some posts ago. It's internals are different. Yours = Aliexpress = crap. This one is Atmega162 = good.
    Yours case is better, I agree. But internals are crap.
    Forget the disk. You need Kolimer's stuff.
    * MK100
  7. #5587
    Feb 2018
    your right it is crap wot is kolimer cheers
  8. #5588
    Feb 2018
    sorry how do I get that for my vcds cable cheers mate
  9. #5589
    Jan 2018
    What kind of mess did you have? What steps did you take for that to happen (how to reproduce, etc)? Can you be more exact on the details?
    Here you can see how it happened (see file attached).
    In two words: after trying to chang byte 27 from 00 to 04 it has changed acording to coding debug file to D0. After this I got a lot of faults in BCM but haven’t time to find out the reason. In couple a days I'v get back to the issue and saw completely wrong coding in BCM!
    41190B218D260FC1458901C132010EC54E7E9189426E8661E5 85C80E0142 instead of
    40180A208C250EC0448800C031000DC44D7D9088416D8560E4 84C7040041
  10. #5590
    Jan 2018
    I think it's not STC but some AES chip. It doesn't protect Atmega EEPROM. I have reflashed several such interfaces with jumpers left as shorted without any side effects (doesn't roll back anything).
    I have exatly the same wire you likned on obd2cartool but I have a lot of difficult to properly program this wire. This beacause when I connect the wire to car the led doesn't turn on. I have to connect and disconnect many times then the led turn on red then green. And the wire after few times used does not work anymore. Can you tell me in witch way you program this wire please?
  11. #5591
    Feb 2018
    Italy
    Quote Originally Posted by tucano79 View Post
    You can program it by giving +12v and GND on the OBD connector. For supply the Voltage regulator that power on the ATMEGA.
  12. #5592
    Dec 2014
    PL
    Read this topic. There are two methods for updating the vcds cable with Atmega 162.
    http://obd2-diag.blogspot.com/2017/0...al.html?q=vcds
  13. #5593
    DK Veteran bibkare's Avatar
    B & H
    Hi all,
    I'm having trouble starting V5 loader under win xp, only splash, vcds program not starting, i think loader probably requires higher version of dotnet then 4.0 because under win 7 there are no any problems. Can somebody confirm this.
  14. #5594
    Oct 2017
    Germany
    Try to start loader 3 -5 times, finally VCDS will start
  15. #5595
    B & H
    Yes you are right, but it's definitely better under win 7, it starts every time
