Page 374 of 854 FirstFirst ... 274324364369370371372373374375376377378379384424474 ... LastLast
Results 5,596 to 5,610 of 12803
  1. #5596
    Oct 2017
    Germany
    No doubt, i don't know why the loader needs more "start tries". Windows 7 seems to work a lot better.
  2. #5597
    Dec 2014
    PL
    Quote Originally Posted by networkers View Post
    Hi. I had the same problem on Windows XP. After installing dotnetfix 4.0, the problem disappeared.
  3. #5598
    Feb 2013
    Sometimes happens in win 7 too... usualy at first start on a new pc.
  4. #5599
    Feb 2018
    Italy
    I see that on some HQ china start ti appear the newer version (v18.1.0). Have you some news about loader, dump for this newer version?
  5. #5600
    Feb 2018
    France
    Quote Originally Posted by alexm1 View Post
    A few page back you will find all you need or just click below...
    Enjoy kolimer's work.
    https://www.digital-kaos.co.uk/forum....php?p=3185666
    Thank you alexm1 for the Link
    Unfortunately VAGCOM_HWType.exe report "no response" of my cable, it's however detected by windows 7 ?!?
    I don't know if I can still try to flash anyway and without hardware changes. I don't have on my PCB, protection diode and L9637D driver instead of
    transistors. It's the same hardware of alexm1 's cable http://www.digital-kaos.co.uk/forums/showthread.php/99750-VAG-COM-VCDS-EVERYTHING?p=3207108&viewfull=1#post3207108
    @Alexm1
    If it worked for you, can you explain your VAGCOM_eewrite settings that you used, because I don't know what HW type should I choose (not detected for me).
    Thank you for your help.
  6. #5601
    Oct 2017
    Germany
    Quote Originally Posted by Triquepas View Post
    You need to supply 12V to the cable or connect it to a car.
  7. #5602
    Feb 2013
    Make sure your cable is seen in dev. Manager as Ross...cable interface/ hex...etc
    Power up with 12 your cable via obd or direct to LM7805
    Run Vcds...test.
    After that run hwtype.exe
    But if your is cable has a old vers of vcds...there is no chance to write dumps via usb. You need a Usbasp programmer.
    To see what type of hw you have, read pdf file from the archive.
  8. #5603
    Yes, at first start maybe because loader first time change the extension.
    Second time launch OK.
  9. #5604
    Jan 2017
    Quote Originally Posted by Vet View Post
    Here you can see how it happened (see file attached).
    In two words: after trying to chang byte 27 from 00 to 04 it has changed acording to coding debug file to D0. After this I got a lot of faults in BCM but haven’t time to find out the reason. In couple a days I'v get back to the issue and saw completely wrong coding in BCM!
    41190B218D260FC1458901C132010EC54E7E9189426E8661E5 85C80E0142 instead of
    40180A208C250EC0448800C031000DC44D7D9088416D8560E4 84C7040041
    Which VCDS version?
  10. #5605
    Jul 2016
    Vilnius
    Happens with all of them.
    Ha ha
    * MK100
  11. The Following User Says Thank You to hid3 For This Useful Post:
    34260551 (9th February, 2018)
  12. #5606
    Jan 2018
    Quote Originally Posted by engycz View Post
    Which VCDS version?
    17.8.1_En with Loader V5
  13. #5607
    Jan 2017
    There are at least two versions of 17.8.1. https://mega.nz/#F!or5AQTwY!GxLeQwZkfOaogV0HCERViA One (V1) is working with V5 loader, second (V2) is not working correctly and it's dangerous to use it.
  14. #5608
    Feb 2013
    V1 has 37.5 mb and v2 37.4 mb?
    L.e. I see the complete name after download, now is clear.
  15. #5609
    Oct 2017
    Germany
    Both Versions are original/unmodified RT Installer.
    v1 has Signing date 10:08 PM 12/1/2017
    v2 has Signing date 12:16 AM 1/13/2018
    sha256 hashes:
    a9943631c1a7a7fe47f075ccbc5a69b04aa4a3ea97c0ca496c 652c074bad49d1 VCDS-Release-17.8.1-Installer_v1.exe
    8e123d05455438a1d6cbf52543181f41aef9d0267dac0cd855 baab48964d926b VCDS-Release-17.8.1-Installer_v2.exe
  16. The Following User Says Thank You to networkers For This Useful Post:
    bibkare (20th February, 2018)
  17. #5610
    Feb 2018
    Quote Originally Posted by kolimer View Post
    Cracked VCDS 16.8.0 (Exe only) and ATMega dump (FW for HW type 1 & 2 + EEPROM). Dissabled marriage with FTDI Chip ID and cleared blacklisted serials. Original VCDS 16.8.0 installation can be found here https://link-4share.com/download/jl3...aller_rar.html.
    Copy cracked VCDS vcds_dump_16.8.0_crack.exe to the directory where vcds is installed and run it.
    Attachment 425389
    thank you! I try later.
