New loader for 18.1.0 V6.1
Special thanks to my friends for testing.
Original installer:
http://dltemp.ross-tech.com/VCDS/dow...-Installer.exe
SHA256 cba53d02a51014b3937938b7bc44edda9ec9354d135c178155 512dae9d021b9e
Loader:
http://ge.tt/7zLlAZo2
https://www.sendspace.com/file/1k82p4
Enjoy ...
2xded (13th February, 2018), 34260551 (12th February, 2018), alexm1 (12th February, 2018), alin 151 (18th February, 2018), AndreaEl (12th February, 2018), bibkare (20th February, 2018), BWF (12th February, 2018), cawadany (12th February, 2018), cmarinoiu (12th February, 2018), dj2d (12th February, 2018), Dynamicdk (20th February, 2018), flavyus1987 (12th February, 2018), ghicicine (25th February, 2018), gimini87 (8th October, 2018), Gyula84 (16th February, 2018), hartklep (12th February, 2018), hid3 (12th February, 2018), I Vasil (12th February, 2018), ivica21 (18th February, 2018), jakuza (13th February, 2018), jokir (13th February, 2018), jos68 (12th February, 2018), kaalis (12th February, 2018), KayLastOS (13th February, 2018), kdijagnostika (14th February, 2018), kitnoos2002 (13th February, 2018), Lolo4321 (25th July, 2019), mattock808 (12th February, 2018), mikroel (12th February, 2018), miouser (30th April, 2018), mkii (12th February, 2018), mrle9 (13th February, 2018), mu95f (25th April, 2018), networkers (12th February, 2018), nicu_cuc (12th February, 2018), Papiti56 (12th August, 2018), Qwarz (12th February, 2018), r0bertt (24th February, 2018), rch11 (12th February, 2018), replay (22nd February, 2018), SergeyIg (13th February, 2018), SliderZ (20th February, 2018), spider-wifi (9th September, 2018), spoon63 (12th February, 2018), tibby5 (13th February, 2018), Tor999 (7th June, 2022), tourettes (12th February, 2018), tr3ce13 (13th February, 2018), vaicekas (12th February, 2018), viking6791 (12th February, 2018), Xaby (22nd February, 2018), xoom (12th February, 2018)
Thanks Kolimer for your work ! Will test and report![]()
Tested on a previous interface that was down due to V5 loader and 18.1 VCDS
Used external programmer, writing OK
Test on Golf Mk5, coding OK, autoscan OK, clear DTC OK, licence valid.
Rewriten it with USB write, all OK.
So far so good![]()
Do you have a way to "lock" it, I mean VCDS can't rewrite with unvalid licence or modify as with V5 and lock the eeprom? Fuses maybe?
Hi, do I need to update the firmware after 17.8 with VAGCOM_EEWriteLang? or simply put the loader in the folder 18 vcds
so far everything passed well
Yep, so far so good:
Updated loader to V6.1 (fixed not starting for the first time)
Updated post http://www.digital-kaos.co.uk/forums...=1#post3213188
alexm1 (13th February, 2018), BWF (13th February, 2018), cawadany (13th February, 2018), Dynamicdk (20th February, 2018), FastFast (13th February, 2018), flavyus1987 (14th February, 2018), FoxMulder (13th February, 2018), hartklep (14th February, 2018), jos68 (13th February, 2018), kaalis (13th February, 2018), kitnoos2002 (13th February, 2018), liviudiaconu (14th February, 2018), Mario6 (13th February, 2018), mikroel (13th February, 2018), miouser (30th April, 2018), mrle9 (13th February, 2018), PierreTheron (14th October, 2018), Qwarz (13th February, 2018), replay (13th February, 2018), tom15 (16th February, 2018), tourettes (13th February, 2018), vaicekas (13th February, 2018), Xaby (22nd February, 2018), xoom (13th February, 2018)
A little bug to report with V6 loader :
After autoscan if you choose manually an ecu it will close right after opened. Only way to open it is to close the software and launch it again.
Same issue several time. Will try 6.1 and report.
Update : With V6.1 issue solved. Autoscan > Clear DTC > connect to any ECU > works well, ecu doesn't close. Thanks !
Does anyone tried 17.8.1 on other languages than English with v6.1 - any report?
Friends I have a doubt. Does exist any type of hardware or firmware difference that allows an old interface (V704 HW0x44 ATmega 162 + Gal16V8 + FT232BL + MCP2515 + transistors) works slowly with CAN based modules (starts good after some seconds becomes to be slow until it loose controller connection - I release connection starts again, and operation continues with the same behavior)) than K-line based ones?
I ask because I have updated this old interface with various tested dumps of this thread and the result is always the same. Any comments or tips are welcome.
Sent from my Android Smartphone
