Page 376 of 854 FirstFirst ... 276326366371372373374375376377378379380381386426476 ... LastLast
Results 5,626 to 5,640 of 12803
  1. #5626
    Nov 2015
    romania
    I tried 17.8.1 ROJ, it does not work
  2. #5627
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by gini80 View Post
    Tried also V6.1 with ROJ..
    First test: Invalid/Unregistered
    but connects to modules..
    Checked again About window and it's Registered :
  3. #5628
    Nov 2015
    romania
    thanks, loader v2 works well with 17.8.1 ROJ
  4. #5629
    Jan 2012
    hi.
    can anybody how remove GAL F16V8BQL?
    what connect with?
    GAL is now removed from PCB.
    then i need coonect pins
  5. #5630
    Feb 2018
    Italy
    why removed GAL?
  6. #5631
    Dec 2017
    Default "Lock" EEPROM
    Quote Originally Posted by dj2d View Post
    Tested on a previous interface that was down due to V5 loader and 18.1 VCDS
    Used external programmer, writing OK
    Test on Golf Mk5, coding OK, autoscan OK, clear DTC OK, licence valid.
    Rewriten it with USB write, all OK.
    So far so good
    Do you have a way to "lock" it, I mean VCDS can't rewrite with unvalid licence or modify as with V5 and lock the eeprom? Fuses maybe?
    Simple hooking of EEPROM writing function from RT_USB.dll will do the trick. Kolimer hooks EEPROM reading function already, it should be a minor adjustment for him.
  7. #5632
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by ccr64k View Post
    RT_USB.DLL have functions to read and write FT232 EEPROM.. but not ATMEGA162 EEPROM if you want to BLOCK writing to AVR EEPROM you should modify FW.. But VCDS writes to eeprom many times
  8. #5633
    Jan 2012
    it block write to Atmega
  9. #5634
    Quote Originally Posted by xoom View Post
    Can be PLD chip (GAL16V8) draws excess current and 8705 gets HOT.. Maybe you have dropping voltage.. (ATF16V8BQL) draws way less current..
    These are the 7805 and GAL16V8 ICs. MCP2515 is working just gets slow after some seconds of use CAN protocol.
    Sent from my Android Smartphone
  10. #5635
    Also weird thing is that I have another similar interface (my backup one just newer V11.3 with same HW, ICs and FW) and works quite nicely.
  11. #5636
    Dec 2017
    Definitely ATMEGA 162 EEPROM is written by FW in ATMEGA 162 flash, but VCDS must trigger the unwanted write and provide mangled content. It should be similar to flashing new firmware. What does VCDS write to ATMEGA 162 EEPROM? The number of coding and adaptation performed?
  12. #5637
    May 2014
    I have an old 16.8.x cracked VCDS that was working with cracked RT_USB.dll, I don't know in what way it's modified but I can assume it is in a good way, I will try to use this one and check what's happening.
    That's the only real issue I got so far, from time to time invalid licence, sometimes uninstall/clear windows reg/reinstall do the trick, other times I have to reflash the atmega.
  13. #5638
    Dec 2017
    Please delete
  14. #5639
    May 2014
    I never read/edit a DLL, I'm downloading Reshacker, I will try to find that and report.
  15. #5640
    May 2014
    I am no engineer but either Ressource Hacker can't read all the DLL, either it's empty AF.
    1 VERSIONINFO
    FILEVERSION 3,2,8,0
    PRODUCTVERSION 2,10,0,1
    FILEOS 0x40004
    FILETYPE 0x2
    BLOCK "StringFileInfo"
    BLOCK "040904b0"
    VALUE "CompanyName", "Ross-Tech LLC"
    VALUE "FileDescription", "RT-USB library"
    VALUE "FileVersion", "3.02.08"
    VALUE "InternalName", "RT-USB.DLL"
    VALUE "LegalCopyright", "Copyright © 2001-2014"
    VALUE "OriginalFilename", "RT-USB.DLL"
    VALUE "ProductName", "RossTech USB Drivers"
    VALUE "ProductVersion", "2.10.00.1"
    BLOCK "VarFileInfo"
    VALUE "Translation", 0x0409 0x04B0
