Page 380 of 854 FirstFirst ... 280330370375376377378379380381382383384385390430480 ... LastLast
Results 5,686 to 5,700 of 12803
  1. #5686
    Feb 2018
    Here are the back and front of PCB (running 17.8.1)
  2. #5687
    Jul 2016
    Vilnius
    Donate me the case and the cable.
    The internals can be safely disposed to trash bin.
    * MK100
  3. #5688
    Feb 2018
    :-) not very helpful
  4. #5689
    Feb 2013
    You/we can fix/update cable with Atmega inside only!
    No Atmega162 inside- no change to make it work with files shared on this thread.
  5. #5690
    Feb 2018
    Quote Originally Posted by alexm1 View Post
    THX. I will open my old 157 to see whats inside
  6. #5691
    Feb 2018
    Quote Originally Posted by hid3 View Post
    This is quality hardware from Obd2CarTool.
    You need header pin with spacing 2.0 mm for reflash with programmer.
    The header pins are already there.
    Pretty straight forward
    Is there chance to unlock my cable via USB?
  7. #5692
    Jul 2016
    Vilnius
    Usually no. First time you need the header and programmer.
    * MK100
  8. #5693
    Dec 2017
    Quote Originally Posted by BASi77 View Post
    It's great that you succeeded to unpack and decode the original.exe file.
    But unfortunately there is such error:
    Attachment 508206
    None of the Kolimer (v1 ... v6) serial numbers are blacklisted up to version 18.2.0
    Attachment 508212
    Attachment 508213
    Attachment 508214
    It is a silly mistake in exe file, the application checks itself for basic integrity. Please download from #5650 again and let me know, if it is correct.
    Look forward for 18.2
  9. The Following User Says Thank You to ccr64k For This Useful Post:
    BASi77 (22nd February, 2018)
  10. #5694
    Jul 2017
    Quote Originally Posted by ccr64k View Post
    At first glance, all is well. But its need to test.
  11. #5695
    Mar 2017
    please remove the picture with the serial number!
  12. #5696
    IF is 18.1.0 why in about screen write data version 20171211, DS 285.1?
    In 18.1.0 Data version is 2018...
  13. #5697
    Dec 2017
    Quote Originally Posted by 34260551 View Post
    Kolimer v5 FTDI_ID is blacklisted in version 18.1.0-18.2.0
    FTDI_ID is hardcoded and different for each FT232 chip, isn't it? So a new cable should have a good chance to work, or there is a whitelist of FTDI_ID in VCDS?
  14. #5698
    xoom's Avatar
    Ylakiai
    Probably While List..
  15. #5699
    Jul 2016
    Vilnius
    I bet there's a whitelist.
    Otherwise there would be no purpose at all to use those Unique IDs unless it accepts any new.
    * MK100
  16. #5700
    Quote Originally Posted by Dynamicdk View Post
    I found V6.1 (Thanks)
    I need some help, how do I make 12V when programing my cabel, Do i put it into my car or do I use some pins on the cabel and make 12V power that way
    I did read my cabel type, when the cable were connected to my car, and get this: Attachment 508355
    Now I need to program it Progisp, but now I need help...
    I did load the Projects, and the what to do..?
    Any 12V DC Power supply will work.. just connect:
    OBD2 PIN 16 to +12V
    OBD2 PIN 4 to GND (minus)
    Do I have to use 12V from the Pc Im using, or can I use another 12v dc power, because I cant get it working..?
    and I get no Light in my vag 11.11 cabel.?
    Progisp says "programmer not found"
    do I need a USBASP programmer..?
