Page 381 of 854 FirstFirst ... 281331371376377378379380381382383384385386391431481 ... LastLast
Results 5,701 to 5,715 of 12803
  1. #5701
    Dec 2014
    PL
    Read this topic. There are two methods of updating . Using the programmer and without.
    http://obd2-diag.blogspot.com/2017/0...er-manual.html
    Or just connect your cable to the laptop and OBD II connectors. Then you'll have 12v power and GND.
  2. The Following User Says Thank You to Mario6 For This Useful Post:
    Dynamicdk (22nd February, 2018)
  3. #5702
    Dec 2014
    PL
    xxxxxxxxxxxxxxxxxxx
  4. #5703
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by Dynamicdk View Post
    Any 12V DC Power supply will work.. just connect:
    OBD2 PIN 16 to +12V
    OBD2 PIN 4 to GND (minus)
    Do I have to use 12V from the Pc Im using, or can I use another 12v dc power, because I cant get it working..?
    and I get no Light in my vag 11.11 cabel.?
    Progisp says "programmer not found"
    do I need a USBASP programmer..?
    you can supply it from 8 AA batteries in series if no other way
  5. #5704
    I dont get any light i my cable when I connect to:
    OBD2 PIN 16 to +12V
    OBD2 PIN 4 to GND (minus), did also try pin 5
    and get this when trying to program "
    is it maby a wrong cable I have
  6. #5705
    Dec 2014
    PL
    In the thred that I gave you, in link it is written that the VCDS 11.11.0 FTDI 232BL cable could not be updated. You have this cable. But I may be wrong.
    >>Ps.
    I have 11.11 version as well FW1.84 (0x44) containing (ATMAG162+FTDI FT232BL) but it stops on step 6 reporting "Interface not found".
    It has been mentioned on the forum that FTDI FT232BL is not support by this MOD.>
  7. #5706
    xoom's Avatar
    Ylakiai
    Try connect like this. If still not working then probably 78L05 is dead..
  8. #5707
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by Mario6 View Post
    In the subject that I gave you, it is written that the VCDS 11.11.0 FTDI 232BL cable could not be updated. You have this cable. But I may be wrong.
    Ps.
    You can write with EE_Write when you change PID of FT232.. to FA24
  9. The Following User Says Thank You to xoom For This Useful Post:
    Mario6 (23rd February, 2018)
  10. #5708
    Dec 2014
    PL
    You're right. However, I did not have to do it. I seamlessly upgraded my interface from damaged 16.8.3 to 17.1.3, 17.8.0 and now 17.8.1.
  11. #5709
    Quote Originally Posted by xoom View Post
    I got green light both places, but still "Interface not found".
    Do I have to buy anohter one..?
  12. #5710
    Oct 2017
    Germany
    What exactly is telling your "Interface not found"?
    EEWrite_lang.exe? HWType.exe
    Check and report your Hardware-ID (PID)
  13. #5711
    xoom's Avatar
    Ylakiai
    First try Reflash it if its banned VCDS allways say that..
  14. #5712
    Dec 2017
    Default VCDS 18.2.0.3
    Well,.. It's very runny, actually, sir.
  15. The Following 3 Users Say Thank You to ccr64k For This Useful Post:
    BASi77 (23rd February, 2018), tourettes (25th February, 2018), traxpalicaru (5th March, 2019)
  16. #5713
    EEWrite_lang.exe - yes
    HWType.exe - yes
    Progisp v1.72 - yes
    Using windows 10
  17. #5714
    how do I do it...?
  18. #5715
    xoom's Avatar
    Ylakiai
    HWType.exe - yes
    Progisp v1.72 - yes
    Using windows 10
    With MProg 3.5 change PID to FA24
