Page 384 of 854 FirstFirst ... 284334374379380381382383384385386387388389394434484 ... LastLast
Results 5,746 to 5,760 of 12803
  1. #5746
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by Dynamicdk View Post
    VCDS.exe first time, and then VCDSLoader.exe
    Looks like you NOT READ pdf at all..
  2. The Following 2 Users Say Thank You to xoom For This Useful Post:
    liviudiaconu (26th February, 2018), mickye_dj (26th February, 2018)
  3. #5747
    EU
    Could someone verify succesful connection to any ECU that is wired to K2 line (pin #15) using clean vcds software + loader and post details here or PM?
    Thank you.
    Not working with actual 16.8 or 17.x hardware.
    Only way i found it work was old 12.12 upgraded.
  4. #5748
    I can tell you this, dealer use an adaptor for old audi for what we named K2 or L line, pin15.
    L line is a second k line, but i think more slowly.this protocol will be lost in near future.
  5. #5749
    EU
    You are partially wrong. K2 is still used in some extras in Audi A4 B5-B7, A6 C5 and others VW etc. And they all don't need 2x2 adapter to 16pin cable.
    http://www.ross-tech.com/vag-com/car...ions/a4s4.html
    http://www.ross-tech.com/vag-com/car...ons/100a6.html
    Plus old 100 C4, A6 C4, 80 B4 with 2x2 connectors in the car itself.
  6. #5750
    Feb 2018
    Hi all, need some help please.
    I have vag 113 / 11.11.3 cable but doesnt connect any longer.
    Cable is atmega162
    Showing as rosstech hex cable in windows but has exclamation mark?
    Please point me in the right direction to what i need to fix my cable
    Also- can this cable be modified to use on BMW Inpa diagnostics?
    Sent from my HUAWEI VNS-L31 using Tapatalk
  7. #5751
    Feb 2013
    anyone can help with Interface programming pinout ? For connecting to Uspasp prog.
    Mosi, MISO. SCK RESET.
    Pic below.
    L.E. - this is hex V2.
  8. #5752
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by alexm1 View Post
    Pic below.
    Do a "Beep" test on multimeter to find SPI pins..
    ATMega162 pins:
    1: MOSI
    2:
    MISO
    3:
    SCK
    4:
    RESET
  9. The Following 3 Users Say Thank You to xoom For This Useful Post:
    fantomel (2nd March, 2018), hartklep (2nd March, 2018), liviudiaconu (3rd March, 2018)
  10. #5753
    Quote Originally Posted by kolimer View Post
    New loader for 18.1.0 V6.1
    Special thanks to my friends for testing.
    Original installer:
    http://dltemp.ross-tech.com/VCDS/dow...-Installer.exe
    SHA256 cba53d02a51014b3937938b7bc44edda9ec9354d135c178155 512dae9d021b9e
    Loader:
    http://ge.tt/7zLlAZo2
    https://www.sendspace.com/file/1k82p4
    Enjoy ...
    hi,
    can reupload installer please ?
    thank you.
  11. #5754
    Jul 2016
    Vilnius
    Pic below.
    it would be nice if you could share the pinout when you figure it out.
    The very same interface should reach me in a few days so having the pinout on hands would save me a few minutes of life.
    Thanks.
    * MK100
  12. #5755
    May 2012
    when rosstech moved to 18.2.0 for sure removed the 18.1.0 from the server......link is from rosstechserver
  13. #5756
    hello again.
    after a succesfuly upgrade by usbasp programer, cable is seen by windows but i cant do the test .
    i try test on bench with 12v from a 1A power suply.
    the interface is 0x46 that was originaly with 9.xx software.
    led is starting red and after turn green, but no test was made.
    i have stc chip but i cut pin 9 to r50 link.
  14. #5757
    Feb 2013
    Quote Originally Posted by xoom View Post
    ATMega162 pins:
    1: MOSI
    2:
    MISO
    3:
    SCK
    4:
    RESET
    Using a multimeter, was my first choice...but battery run out of juice and no "beep" from the them....so I had to go out to buy new one, anyway I did reflash by usb...I ussualy do the "classic style"...usbasp
    Quote Originally Posted by hid3 View Post
    Thanks.
    I managed to find pinout for hex.v2. see pic below.
  15. The Following 4 Users Say Thank You to alexm1 For This Useful Post:
    ASCM (29th May, 2022), liviudiaconu (3rd March, 2018), muscles1960 (1st April, 2018), seal777 (13th February, 2019)
  16. #5758
    Quote Originally Posted by alinutz198 View Post
    hello again.
    i test with vag com hwtype.exe , din't detect any hardware
  17. #5759
    Feb 2013
    Try to reflash again with usbasp and choose right dump (0x44/0x46) see indication in pdf released by Kolimer in v6.1 zip to see what type is your cable.
    Pay attention to fuse lock bit...if they werent set properly before.
  18. #5760
    Jul 2016
    Vilnius
    Using a multimeter, was my first choice...but battery run out of juice and no "beep" from the them....so I had to go out to buy new one, anyway I did reflash by usb...I ussualy do the "classic style"...usbaspI managed to find pinout for hex.v2. see pic below.
    Hi Alex,
    thanks for sharing, this might be useful for other people here too.
    Also, did I understand correctly that you reflashed via USB? Was this cable from Odb2CarTool with their software/dumps inside? Did it have bootloader? I know these dumps are Kolimer's too, but if I remember correctly they didn't have the bootloader...
    * MK100
