Page 385 of 854 FirstFirst ... 285335375380381382383384385386387388389390395435485 ... LastLast
Results 5,761 to 5,775 of 12803
  1. #5761
    Feb 2013
    I do not know from were was bougth....I just write FTDI, reflashed Atmega by usb and all was ok...so, bootloader was there.
  2. The Following User Says Thank You to alexm1 For This Useful Post:
    muscles1960 (1st April, 2018)
  3. #5762
    Quote Originally Posted by alexm1 View Post
    Try to reflash again with usbasp and chose rigth dump (0x44/0x46) see indication in pdf released by Kolimer in v6.1 zip to see what type is your cable.
    Pay attention to fuse lock bit...if they werent set properly before.
    i do update with progisp using projects file, and with avrdude. no error in both cases. but still same error.
    with other cable, same steps , all was ok
  4. #5763
    maybe i have to do the test on the car?
  5. #5764
    Jul 2016
    Vilnius
    So is your OBD2 connected to +12V while you are doing test? Connect to the car and retry.
    * MK100
  6. #5765
    Feb 2018
    Hi, Please help,
    Ok I have a VAG171 and I can successfully flash via PROGISP. The problem is when I power down and connect USB the LED stops working and it is not recognised. I can reflash but cannot proceed. I have also been able to VAGCOM_EEWriteLang successfully. I think the old protection is reflashing and making unusable?. Can somebody direct me to what chip needs removing or tracks that may need cutting.
    I have also installed 17.8 and cannot get it to validate with V5.1 or V6 VCDSLoader?. Any help much appreciated.
    I am doing this because I have never manage to get CAN:Ready on my system.
  7. #5766
    Quote Originally Posted by Hadgee View Post
    Hi, Please help,
    disconect wire from programer and will work
  8. The Following User Says Thank You to alinutz198 For This Useful Post:
    Hadgee (3rd March, 2018)
  9. #5767
    Feb 2018
    Quote Originally Posted by alinutz198 View Post
    Hi, Thank you for quick reply, I have got working now with 17.8 but I still get 'CAN: Not Ready' Any Ideas?
    vcds 178.jpg#
    Many thanks.
  10. #5768
    May 2012
    Hi, Please help,
    remove the Jumpers.
  11. The Following User Says Thank You to openit For This Useful Post:
  12. #5769
    vcds 178.jpg#
    Many thanks.
    try on the car. will work
  13. The Following User Says Thank You to alinutz198 For This Useful Post:
  14. #5770
    May 2012
    the response from hid3 and alinutz198 is the right way sir. test ist on car not on bench...
  15. The Following User Says Thank You to openit For This Useful Post:
  16. #5771
    Feb 2018
    Using a multimeter, was my first choice...but battery run out of juice and no "beep" from the them....so I had to go out to buy new one, anyway I did reflash by usb...I ussualy do the "classic style"...usbaspI managed to find pinout for hex.v2. see pic below.
    Hi friend. Which pin is vcc on isp socket? do I need to use the v4 or v6.1 loader to 17.8.1 akp version? Thanks
  17. #5772
    Feb 2013
    I did not looked for vcc or ground on the header, I allways aplly 12v to obd2.
    I use v6.1.
  18. #5773
    Feb 2018
    Quote Originally Posted by openit View Post
    Hi, thanks again to all, I have tried on the car with and without jumpers.......'Can:Not Ready' This has never worked from new so I am thinking it may be a bad lead.
    Just for information what do the jumpers do on this lead?.
    Thanks again.
  19. #5774
    Jul 2016
    Vilnius
    It's not clear regarding the jumpers. There is a theory that one is for the Aes chip, another of K-line (or L line?). I have tried with both jumpers shorted and it works fine.
    BTW, what car are you testing on? Maybe your car doesn't have CAN at all?
    * MK100
  20. The Following User Says Thank You to hid3 For This Useful Post:
  21. #5775
    Feb 2018
    Quote Originally Posted by hid3 View Post
    It is a VW Passat 2012 Alltrack B7. It does have CAN. Also checked on Seat Leon 2012 (before reflash) always same response.
    Thanks,
