Page 386 of 854 FirstFirst ... 286336376381382383384385386387388389390391396436486 ... LastLast
Results 5,776 to 5,790 of 12803
  1. #5776
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by Hadgee View Post
    It is a VW Passat 2012 Alltrack B7. It does have CAN. Also checked on Seat Leon 2012 (before reflash) always same response.
    Thanks,
    Did You checked resistance on cable between 6 and 14 pins? (should be around 120ohm) if there is.. then check pin 6 to CAN transceiver chip and pin 14 to CAN Transceiver
  2. The Following User Says Thank You to xoom For This Useful Post:
    Hadgee (3rd March, 2018)
  3. #5777
    EU
    Quote Originally Posted by hid3 View Post
    It's not clear regarding the jumpers. There is a theory that one is for the Aes chip, another of K-line (or L line?). I have tried with both jumpers shorted and it works fine.
    I had cable that worked k1+k2+can with both jumpers shorted. After flashing with loader, k2 doesn't work anymore.
    But mysterious anyway...
  4. #5778
    Feb 2018
    Quote Originally Posted by xoom View Post
    HI, I have 120ohm between pins 6 and 14. OK I have 120ohm to the pins in the picture. Strange?
  5. #5779
    xoom's Avatar
    Ylakiai
    Maybe this helps
  6. #5780
    Quote Originally Posted by alinutz198 View Post
    i test with vag com hwtype.exe , din't detect any hardware
    DO I HAVE TO UPDATE GAL CHIP AS WELL?
  7. #5781
    Feb 2018
    Maybe this helps
    Thanks for the picture, it helped a lot. both have good connections to the pins........
  8. #5782
    xoom's Avatar
    Ylakiai
    but you also showed some connection that i didnt understood .. also you can check if there is no short to VCC or to GND.. it can be that CAN chip is bad..
  9. #5783
    Feb 2018
    Ok I will check soon as off to work.. First connection picture was my guess on the CAN chip which was incorrect so ignore. The pin out helped greatly.
    Thanks again
  10. #5784
    kowalwalcz's Avatar
    Hi, thanks again to all, I have tried on the car with and without jumpers.......'Can:Not Ready' This has never worked from new so I am thinking it may be a bad lead.
    Just for information what do the jumpers do on this lead?.
    Thanks again.
    I have the same situation. Working device 0x46 flashed and at this time can not ready in the car. Another new interface working with the same car and can is ready
    if I helped You, press the button THANKS
  11. #5785
    Quote Originally Posted by kowalwalcz View Post
    same problem here.
    update ok. test can not ready
  12. #5786
    Feb 2013
    Share some pics with both sides of each pcb, to see if hardware is different or not.
    Same request for everyone with the same problem.
  13. #5787
    xoom's Avatar
    Ylakiai
    same problem here.
    this is not "CAN: Not Ready".. it either not plugged in the car or banned..
  14. #5788
    yes, in both cases the same problem. tested on the car and bench.
    is a old model 9.08. i dont know what can i do so solve this.
    i install 5,6 and 6.1 version with usbavr, without problem, firmware, eeprom, fuses. all ok . i used avrdude and progisp, no problem as well.
  15. #5789
    xoom's Avatar
    Ylakiai
    Looks like FT232 is not talking with ATMega162..
  16. #5790
    I'm trying to upgre a couple of 0x44 cables 8.12 / 11.11 with firmware 1.10 and 1.81 but even if the led comes red the dwnload starts then it always fail when trying to load the eeprom content.
    I'm doing something wrong?
    Looks like it's not writing but fuses seems to be correct power supply is connected etc.
    Do I have to cut something on the board?
    Loader 6.1 but same results on V5.
    Can anyone tell me how to proceed?
    Thanks in advance
    R.
    eprom content failure.PNGupgrade from 1.10 to 1.96.jpgfallimento upgrade da 1.10 a 1.96.jpg
