Page 387 of 854 FirstFirst ... 287337377382383384385386387388389390391392397437487 ... LastLast
Results 5,791 to 5,805 of 12803
  1. #5791
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by robyno View Post
    I'm trying to upgre a couple of 0x44 cables 8.12 / 11.11 with firmware 1.10 and 1.81 but even if the led comes red the dwnload starts then it always fail when trying to load the eeprom content.
    I'm doing something wrong?
    Looks like it's not writing but fuses seems to be correct power supply is connected etc.
    Do I have to cut something on the board?
    Loader 6.1 but same results on V5.
    Can anyone tell me how to proceed?
    Thanks in advance
    R.
    Attachment 511315Attachment 511316Attachment 511317
    i think that FW is too old to download kolimers FW in your cable i guess yu shuld try write with external programmer
  2. #5792
    ok thanks so from 1.81 there is no way to upgrade directly
  3. #5793
    Feb 2018
    XOOM "Looks like FT232 is not talking with ATMega162."
    Hi is there a way to test this?
  4. #5794
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by Hadgee View Post
    It would be easy with oscilloscope or Logic analyzer.. other test for FT232 would be to short TX and RX pins on FT232.. and try type in terminal when connected to virtual com port (also you have to make serial usb converter in that case)
  5. #5795
    May 2012
    test with VAGCOM_EEWrite from loader package v1 dated 5.08.17 . rename hw44eprom from v6.1 loader to eepromavr.bin . at least write ....
  6. #5796
    Quote Originally Posted by openit View Post
    Ok thanks good suggestion
    I'll try this evening and let you know!!
  7. #5797
    Feb 2018
    Quote Originally Posted by xoom View Post
    OK thanks for the information. I will investigate further when I have some time.
  8. #5798
    No way same results even with V1 and new bin.
    I also tested some combinations but as the first load seems to be finished the led comes back green and eprom content loading fails.
  9. #5799
    Feb 2018
    Has someone use AVR Studio for program vcds and could give some tips/screenshots?
  10. #5800
    Looks like FT232 is not talking with ATMega162..
    is any way to solve that?
  11. #5801
    Feb 2018
    Italy
    Quote Originally Posted by r0bertt View Post
    I have used Atmel Studio v7.0.1652 with a Atmel-ICE programmer, all work fine now. What you need to know?
  12. #5802
    Feb 2018
    Quote Originally Posted by Stompie View Post
    Hi all, need some help please.
    I have vag 113 / 11.11.3 cable but doesnt connect any longer.
    Cable is atmega162
    Showing as rosstech hex cable in windows but has exclamation mark?
    Please point me in the right direction to what i need to fix my cable
    Also- can this cable be modified to use on BMW Inpa diagnostics?
    Sent from my HUAWEI VNS-L31 using Tapatalk
    Any help please?
  13. #5803
    Feb 2018
    Any help please?
    Hi, have tried reinstalling drivers as the device is seen?.
  14. #5804
    Feb 2018
    I have tried re installing the drivers, using other drivers. This is a clone cable but used to work 100%. I think it only stopped working after i was upgraded to windows 10 last year.
    Ive followed a couple of threads on how to reinstall the drivers or even change the VIDPID in the INF file but nothing. If i plug the cable into my car, the LED light goes green but cannot use the cable as its not seen as a port.
    If i remember correctly, before the upgrade or before the cable stopped working it used to say "Ross tech usb interface" or something and then it changed? so is this just a driver error?
  15. #5805
    Feb 2013
    Did you tried with another PC? With different WIN?
