Page 388 of 854 FirstFirst ... 288338378383384385386387388389390391392393398438488 ... LastLast
Results 5,806 to 5,820 of 12803
  1. #5806
    Feb 2018
    Ok so i have finally fixed my cable....
    I thought i tried everything and somehow while searching the web now i came accros the below link and this actually resolved my issues 100%, cable is now picking up in Fprog etc.
    Found these steps and my cable is installed following these steps and the driver is working 100% now
    https://sites.google.com/site/imnuts...ch-vcp-drivers
  2. #5807
    Feb 2018
    Quote Originally Posted by Stompie View Post
    Nice work. I thought it was drivers due to device manager showing it.
    Good luck
  3. #5808
    Feb 2018
    Quote Originally Posted by AndreaEl View Post
    I have used Atmel Studio v7.0.1652 with a Atmel-ICE programmer, all work fine now. What you need to know?
    Hi AndreaEl,
    Thanks for feedback, I`m looking for how to setup program and what to click to correctly update VCDS as on screen from FANTOMEL:
  4. #5809
    Feb 2018
    I have a hex v2 multilanguage ENG 17.8.1 and AKP 17.1.3 with atmega chip, HW_0x46. I would update only newest AKP version 17.8.1. I connect 12v to the obd socket and connect to usb port. I have an error in VAGCOM_EEWriteLang:
    How to fix it? Thanks
    I have a hex v2 multilingual ENG 17.8.1 and AKP 17.1.3 with an atmega chip. I would like to make the ACP version 17.8.1. I connect 12v to the obd socket and connect to usb. I have an error in VAGCOM_EEWriteLang
  5. #5810
    Feb 2018
    Italy
    Quote Originally Posted by r0bertt View Post
    Hi AndreaEl,
    I have do this in sequence vith Atmel Studio:
    1) Apply 12V at OBD Connector, connect Atmel-ICE programmer
    2) Open Device Programmer in Atmel studio 7, select ATMega162, check that target voltage is 5V
    3) Program Flash with a erease of target device
    4) Program EEPROM
    5) Set Fuses (ONLY FOR 0x46!!!):
    - LOW: CD
    - High: DA
    - Ext: F9
    - Lock: CC
  6. #5811
    Jan 2017
    Quote Originally Posted by Gracek View Post
    You don't have correct bootloader in your interface. You must program it using external programmer (USBASP). Read Info.pdf in V6.1 Loader.
  7. #5812
    EU
    Hex v2 with atmega looks interesting
  8. #5813
    Mar 2018
    Hi! i have a china clone cable vag 17. Please somebody tell me how can i work with kolimer's package vcds loader? I read all infos and i try to use vagcom eeprom writer but no bootloader mode. So i realized need to wires and usbasp programmer(which exactly?? so many in ebay) and i saw 0x46 picture in description but mine is different...what must i do EXACTLY to work with kolimer's package vcds?
    Or can somebody show me a store and cable which working 100% without any soldering and wiring with kolimer's vcdsloaderv2??maybe that is the best for me
  9. #5814
    Jul 2016
    Vilnius
    LOL. Your cable seems to be missing a little bit of Atmega.
    Some quality cables from our friend's store:
    1) "HEX-V2" style: http://www.obd2cartool.com/atmega-va...t-skoda-p-1492
    2) "Classic" one: http://www.obd2cartool.com/vagcom-16...version-p-1266
    I think it has been mentioned at least 10 times here.
    PS: Even Mr. Kolimer uses one of these...
    * MK100
  10. #5815
    Mar 2018
    Quote Originally Posted by hid3 View Post
    Thank you! and sorry for my question...
    Yes, those cables look like better than mine
    I use my cable with original program and have errors in long coding(error missing rod file) and same things. i read if i use kolimer's package everything will be fine and working that is the reason why i try with this cable...
    But if it is possible i buy a new one to use a vcdsloader and get a full working vcds. And i don't want to solder and wiring and programming anything...
    If i buy this cable 100% i don't need any mods only with software???
  11. #5816
    EU
    You will need to use usbasp programmer for the first time because of locked bootloader.
  12. #5817
    Feb 2018
    Italy
    Quote Originally Posted by kaalis View Post
    Or any Atmel ATMega 162 compatible programmer, not necessarily USBASP
  13. #5818
    hi
    i have tested loader v6.1 with
    17.1.3 EN X86 ok
    17.1.3 EN X64 not ok
    17.8.1 EN X86 ok
    17.8.1 EN X64 not ok
    18.1.0 EN X86 ok
    18.1.0 EN X64 ok
    18.2.0 EN X86 ok
    18.2.0 EN X64 ok
    17.1.3 RO X86 ok
    17.1.3 RO X64 ok
    17.8.1 RO X86 ok
    17.8.1 RO X64 ok
    please Kolimer can you take one luke over
    thanks for your hard work
  14. The Following 2 Users Say Thank You to nicu_cuc For This Useful Post:
    hid3 (9th March, 2018), kitnoos2002 (14th March, 2018)
  15. #5819
    Dec 2016
    hi guys i have a vcds from this website http://www.obdkcan.com/vagcom-1684-v...711_p1272.html
    actually i have no communication with different module when i make test usb port on the software sometimes k line 1,2 can ok and sometimes when i test again interface not found
    maybe interface bricked ? or other problem ? your advice are welcom
  16. #5820
    Oct 2017
    This HEX-V2 can support opening module 46 on Q7 4M?
    Thanks in advance
    bedrock
