i have 16.8 cable with 0x44 version hardware 34 and 35 pins not connected.
when i try to read with hwtype.exe i dont have any response from cable.
* MK100;
* MK100;
Just to help other people thinking of buying this interface from this website, I contacted the poster that bought from there. He advised me that the interface didn't work out of the box; chinese sellers asked him to register with them and sent some files and it still wouldn't work. So online update feature doesn't work it seems. He then had to flash it with Kolimers files to get it working.
Here's is a Hex-V2 with Atmega162 chip. Does anyone have any experience from this seller?
https://www.aliexpress.com/item/Newe...857610306.html
All that Chinese software and gossips aren't worth the paper which they are printed on.
I tell this to everyone - remember, you are buying just hardware. Ignore anything what the description says about the version, updates etc.
Once you get the hardware, just flash Kolimer's stuff and enjoy.
* MK100;
e701 (10th April, 2019)
@hid3:
When i told "maybe that regulator is not made for 1A, but only 300mA" i told about parameters of 7805.
From datasheet:
3-Terminal 1A Positive Voltage Regulator. That is description of 78xx series of Fairchild, b.e.
One of this will be only warm in vcds cable.
Oh, I thought that the cable was draining 1 AThat'd be some serious shit. A month ago I measured the current with the cable connected to just +12V and it was a hair less than 10 mA, IIRC.
* MK100;
No need to solder. You just wire cable connector together with usbasp connector and make sure wires do not touch each other.
Easy job.
lemta (15th March, 2018)
Thanks for the picture. Could you possibly show another picture (if it's not too much trouble) to show how it's connected at the interface as well as USBASP? There's no pictures on this thread of how people are connecting their interfaces - it would be very helpful for newbies like myself. Also do you have the Hex-V2 from obd2cartool or a different interface? Many many thanks friend!
If you look for pinout....you will find it below
https://www.digital-kaos.co.uk/forum....php?p=3229388
I will not post it because I have different connector inside cable.
I have 16.8.4 cable from obd2ct.
Pinout for hex v2
Gnd is on pin 14. I ordered a hex v2 from an aliexpress from autox431 but the interface did not have an atmega chip. I ordered a better hex v2 from atmega from the eobtool store.
* MK100;
