I tried to reprogram 2 pcs vag 15.7 using USBASP programmer but i get CHIP ENABLE PROGRAM ERROR ! I check connection twice tried to program both interfaces but same error.
We can't help everyone, but... everyone can help someone!
I can't see that you solder to reset on pin4 od atmega162, there should be 5 wires, MISO MOSI SCK RESET GROUND
For 15.7 "Red PCB with STC chip".
Even Kolimer said "No need desolder STC", i preffer to desolder it.
About Long Coding:
Can Gateway where Long Coding not documented well:
8T0 907 468 H
13.07.08
Can someone to confirm or infirm that?
Look at this photo;Attachment 517567
Reset pin is connected but not on picture that I take. I tried several times without any success on both cables. But i updated firmware on this cable with same programmer. This cable works only with k line , can line is not ready! Any solution for that. Iam using 17.8 with v2 loader.
makadam (28th March, 2018)
* MK100;
Adyp (29th March, 2018)
Hello, would you be able to tell me if the cable pictured bellow can be reprogrammed? It's a version 12.12 with Atmega 162, ATF16V8b and FT232RL. Thanks.
Yes it can be reprogrammed.
Sent from my D6603 using Tapatalk
Originally it came with 12.12, should I stick with the same version or I can load the latest dumps? Right now cable will read fault codes but I get unauthorized message. Yesterday I tried to release mu handbrake so I change my pads and it didn't work.
It is clear: it is Unregistered (See About), so it is not fully functional, if you have all you need reflash Atmega.
I have same problem with can, did u find any solution ?
Finally I reflash old 157 with colimer files install 17.8 using loader v2 and in all 3pcs (two red 157 and one old 904) is OK but works only modules with k line, CAN is not ready. I made a test with passat b6, Any solution?
About CHIP ENABLE PROGRAM ERROR BWF was right it was driver problem!
I want to use kolimer v6.3 loader. I downloaded 18.2.0 EN. My cable is 0x46.
How make it to work in polish language? Can i download 18.2.0 PL and is it all? in zip loader there another zip with lang files. Where i have to flash it?
ftdi_mprog_RLRQ is for FTDI232RL
Flash1.96_HW_0x46 is for atmega?
eepromavr_HW_0x46 this is for what?
I thought that i need 2 files to flash. one for atmega and one for FTDI.
One more question. If I use loader, can i use the internet during scanning?
PS. I read thread from ~300 page and i know how to connect it to programmer. Also i noticed that somebody told there's a possibility to program atmega via usb. is that true?
Most cases first time youl need to use usbasp.
For Atmega you need 2 files (mentioned by you eeprom+flash).
For Ft232xx different file.. ept
Read Pdf document(it is in the zip) for more info.
