Page 413 of 854 FirstFirst ... 313363403408409410411412413414415416417418423463513 ... LastLast
Results 6,181 to 6,195 of 12803
  1. #6181
    Jul 2016
    Vilnius
    You can get a donor cable for GAL
    Sometimes I say "keep this cable for spares" for cables with NEC chip etc.
    So a perfect example when you need a spare.
    A new/quality cable from Obd2CarTool's shop is around $24 shipped worldwide, so one might consider if it's worth the effort "to give it last chance".
    K-lines are used on old(er) cars, which did not have CAN.
    Honestly, I don't have a single car with K-lines, nor any of my friends do.
    * MK100
  2. #6182
    Home
    Keep in mind, English is not my native language.
  3. #6183
    Jan 2016
    well i have updated my 12.12 cable using usbasp and 0x44 firmware, all went good
    i've installed VCDS 17.8.0 and extracted kolimer 6.3 loader in c:\ross-tech\vcds folder
    There are no drivers installed, and the new "cable" shows un device manager as " Ross-Tech HEX-USB "
    vcds started with loader does not prompt for firmware update and on the test screen shows:
    Ross-Tech USB interface not found
    USB Library Version: 03.02.07
    Interface not found
    Shall i do something else besides usbasp > new vcds version installation > kolimer and start?
    Please advise
  4. #6184
    Jul 2016
    Vilnius
    So there were drivers installed or not?
    What are VID & PID IDs in device manager when you conenct the interface?
    * MK100
  5. #6185
    Jan 2016
    under XP the drivers were installed and the device name is : Ross-Tech Direct USB interface
    VID=0403
    PID=FA30
    any thoughts?
  6. #6186
    Jul 2016
    Vilnius
    PID=FA30??
    You need to correct it to PID=FA20 is it's 232BL and FA24 if it's RT232R* chip inside.
    Is this was a typo, then watch in device manager what happens when you plug the cable in. Does it get detected properly and appears in dev manager without any exclamation marks?
    Also, why didn't you use latest version of \/CDS?
    * MK100
  7. #6187
    Jan 2016
    Not a typo, how to correct the pid?
  8. #6188
    Jul 2016
    Vilnius
    Use Mprog. In Kolimer's pack there are prepared files:
    ftdi_mprog_BMBL.ept
    and
    ftdi_mprog_RLRQ.ept
    For interfaces with BL/BM chips, use first one, for RL/RQ, use 2nd. This is very easy.
    * MK100
  9. #6189
    Jan 2016
    here's the view from linux
    will do the Mprog part
    [ 58.772080] usb 1-4: new full-speed USB device number 7 using xhci_hcd
    [ 59.325790] usb 1-4: New USB device found, idVendor=0403, idProduct=fa30
    [ 59.325792] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [ 59.325794] usb 1-4: Product: Ross-Tech HEX-USB
    [ 59.325795] usb 1-4: Manufacturer: Ross-Tech
    LE: Mprog done, looks good on the bench, have to figure out with the latest version and windows 10 will provide feedback and beer in the end
    Thanks so much
    regards
  10. #6190
    Jul 2016
    Vilnius
    Oh, yeah, a mistake for sure
    BTW, if you'd post the pics of the PCB, it would be possible to tell you exactly which ept file to use.
    * MK100
  11. #6191
    May 2018
    hello friend i search for testing loader 6.3 to kolimer i have read lot off page in this thread but i find only 6.1
    thanks you
  12. #6192
    Dec 2014
    PL
    Quote Originally Posted by guyguy307 View Post
    thanks you
    Kolimers V6.3 loader is on page 389 post 5823.
  13. The Following User Says Thank You to Mario6 For This Useful Post:
    guyguy307 (4th May, 2018)
  14. #6193
    Jan 2016
    Quote Originally Posted by hid3 View Post
    Already used mprog all fine in the test on the bench using windows xp(old piece of hardware lying arround)
    I've already uploaded pics with the pcb a few pages back, i can do it again if needed
  15. #6194
    Jul 2016
    Vilnius
    Your hardware is HW 0x44, you should be using that dump.
    For Mprog, use RL/RQ file.
    In fact, you need to set correct VID/PID settings
    * MK100
  16. #6195
    May 2018
    I think I just bricked an HW 0x46 cable. The cable never worked properly, so I decided to flash it using VAGCOM_EEWriteLang.exe. First I used VAGCOM_HWType.exe to detect it and it confirmed hw type 0x46, chip ATmega162 + FT232RL (confirmed by opening the cable). I connected the cable to the OBD2 port of the car, led turned green, start flashing with EEWriteLang but after a while it has thrown out errors and the interface remained stuck with red led. Now when I connect the cable to the laptop it gets detected as Ross-Tech USB interface but if I connect it to the car the led remains red and HWType does not detect any interface. VCDS also does not detect any cable.
    Did I just lose my cable or can I re-flash it using an usbasp programmer? The cable does have a programming header pin so it should be easy to do.. but before I go ahead and buy an usbasp programmer I wanted to know if I stand a chance or if I should just buy a new cable.
