So when you plug it in, device manager doesn't detect anything?
* MK100;
Sounds very similar to this:
http://www.digital-kaos.co.uk/forums...=1#post3277550
Are you sure all the USB wires are okay and not broken?
Any chance you try to access it with MProg?
The interface has not ATF/GAL so if it's the FTDI faulty, I wouldn't spend much time/money/effort on repairing it.
A new quality hardware (HEX-CLONE+CAN as the Dictator calls it) is under $30 with worldwide shipping.
* MK100;
Hello, any body help me with Long code for abs pump Vw polo 2013 1.2 petrol. Thank you
Yes i forgot to mention the post by alexm1. I have tried mprog and ft_prog but neither pick it up.
Sorry for the stupid question but what is the gal chip for and why does it make it a better lead then one without?
I am going to go look if i have another ftdi chip somewhere but will probably end up buying a new one. Any recommendations on a decent lead?
Hy guys. I have a vcds 12.12 chinese clone that shows unregistered. I still can do some things with it, but not to much. Can anyone walk me through , how to reflash this tool ?The chip inside is atmega 162 (16AU 0921H) ,FTDI 1608-C CN480661 FT232RL. Thanks in advance.
Just read the thread backwards. People already asked about these interfaces several times.
i've been reading for a couple of hours. i need to know what tools, and files do i need. if i should upgrade to a newer version, stick with this one, or downgrade. thanks for you answer.
First I would hook it up to a usbasp and backup the flash+eeprom and fuses that is on the atmega and the settings in the FTDI, in case you want to go back.
http://www.mouser.com/ds/2/268/atmel...62-1065300.pdf
Here on page 2 you can find the pinout of the ATMega. Trace MOSI, MISO, SCK and Reset from the chip to the prog-header J4 and hook up the usbasp. Don't forget ground and if you don't plug it into your car, hook up +5V too.
Take the kolimer package v6.3 and I think the 0x46 firmware should be the right one for your interface. Everything else is explained in the info.pdf
You don't have the best quality interface, but it should work..
eliteland786 (10th May, 2018)
So if i got this straight: i can use the J4 on my pcb (so i don't need to solder directly on atmega),Capture 2.JPG and will this tool do the trick ?Capture3.JPGCapture4.JPG
Hi everyone, i have just a couple of questions:
1) I've seen on Ro$$ T€ch website that HEX+CAN has been replaced by HEX-V2, is this version better than HEX+CAN? Does exist a good quality clone of it? And could be upgraded like the HEX+CAN?
2) Several people are reporting of troubles with 18.2 /17.8.1, mainly with coding (ex. have to do it a couple of times before having coding accepted, lost connection during auto-scan, etc.) someone could confirm this? (However i assume that flashing kolimer firmware i could go back with 17.1.3 if needed, right?).
Thanks.
I use 17.1.3 where reliability is required (e.g. coding, adaptations of expensive cars) and find it stable.
* MK100;
i've found something: https://mega.nz/#F!wOQ0Tara!BpD1MDJatF_bxWklB0rQCA
As long as the digital signature is still in the installer-exe, they are non-modified and completely stock, is it right?
