Page 417 of 854 FirstFirst ... 317367407412413414415416417418419420421422427467517 ... LastLast
Results 6,241 to 6,255 of 12803
  1. #6241
    Jul 2017
    Quote Originally Posted by wallix89 View Post
    Hy guys. I have a vcds 12.12 chinese clone that shows unregistered. I still can do some things with it, but not to much. Can anyone walk me through , how to reflash this tool ?The chip inside is atmega 162 (16AU 0921H) ,FTDI 1608-C CN480661 FT232RL. Thanks in advance.
    Attachment 527319Attachment 527311
    i managed to make my cable registered again. i just copied the vcds loader.exe from kolimer's package to my ross tech folder. i did a test with the cable and it shows registered, and another one on the car and still registered. only problem that remains is the error for comunications "too many comunicatiions errors"
  2. #6242
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    follow the instructions from the pdf ,
    i had similar problems before i followed the complete guide.
  3. The Following User Says Thank You to jan4 For This Useful Post:
    TheSky (17th May, 2020)
  4. #6243
    May 2018
    Guys,
    i Have a chinese hex-v2 17.8.1
    it is showing "Invalid/Unauthorized
    Any chance to fix it?
  5. #6244
    Jul 2016
    Vilnius
    Pics of the Chinese hex-v2 PCB?
    * MK100
  6. #6245
    Oct 2017
    Today I've got my Hex-V2 from obd2cartool and I don't understand one thing: They say that they use kolimers firmware and loader, but they set the atmega lockbits anyways. Therefore I couldn't read the flash and eeprom. I'm not mad at all, I just wonder why.
    I wanted to backup the original firmware, in case I need to go back. It seemed that the LEDs where blinking a little bit different, maybe I imagined it, but thats why I wanted to do the backup.
    Anyways, the hex-v2 works just fine with kolimers loader v6.3. Thank you veeeery much!
  7. #6246
    Feb 2013
    Usually Atmega is protected for reading....you will get some dumps but are encrypted. If you can not read at all: are you sure it is Atmega inside?
  8. #6247
    Oct 2017
    I've opened it up and yep it has a atmega inside with "178" written on it. I connected my usbasp to the prog header
    I could read the flash but I got either just FFs or garbage. The lockfuse was "C2" and http://eleccelerator.com/fusecalc/fu...chip=atmega162 says it means "application protection mode 3", "boot loader protection mode 3" and "further programming disabled"
  9. #6248
    Jul 2016
    Vilnius
    I think it contains V5 inside there. Don't worry, just use Kolimer's latest.
    If for some reason you need to go back to "original", try contacting them, they are friendly and helpful people.
    * MK100
  10. #6249
    Feb 2018
    X fabio Copia kolimer loader nella cartella ross tech /vcds
  11. #6250
    Feb 2018
    Quote Originally Posted by Fabio89 View Post
    Guys,
    Copia kolimer loader v6.3 nella cartella ross tech /vcds
  12. #6251
    Sep 2016
    hoping someone can point me in the right direction. My Vag Com has stopped working been about a year since i last used it. it's showing status "Status: Not plugged into Car"
    i'm guessing a solution is buried somewhere within these 417 pages, and any direction would be appreciated. it's a VAG106 photos of the board attached, tried using software 10.6
  13. #6252
    EU
    Start reading this thread backwards. Page by page.
  14. The Following User Says Thank You to kaalis For This Useful Post:
    Mario6 (11th May, 2018)
  15. #6253
    Oct 2017
    Quote Originally Posted by hid3 View Post
    Alright, thank you for your answer!
    Just a feedback: I've tested the interface with my golf 5 gateway+airbag testbench on my table and everything (incl. coding) seems to work just fine. I don't see any improvements in speed, but I like the case+cable and I like to have a spare interface, in case my first one dies unrepairable. I use it just for my own and friends cars, no profitable use at all.
    For extra protection I've soldered a NUP2105LT1G CAN protection diode in the missing place on the pcb. They are dirt cheap and probably not needed, but I like it that way.
    dannyb13, look on page 389, but keep in mind that on the way back you may find useful informations for your interface.
  16. #6254
    Apr 2018
    Hello, my friend is asking if this interface a good one? Thanks.20180512_124430.jpg20180512_124430.jpg20180512_124452.jpg
  17. #6255
    Feb 2013
    I have an issue with an older cable updated to 18.2.0, it does not work on a laptop with win 10 64 bit in dev manager I get:
    USB device is not recognized "Device Descriptor Request Failed"
    On the same laptop with win 10 I tried another newer model cable with 18.2.0 and is working fine.
    The older cable is the one with Atmega, Ft232RL, no Gal/Atf and this cable is working just fine on a laptop with win 7 32bit.
    On the laptop with win 10 I did the steps to dissable digital driver signature enforcement. Tried to instal driver manually, no luck.
    Any ideeas?
