Page 418 of 854 FirstFirst ... 318368408413414415416417418419420421422423428468518 ... LastLast
Results 6,256 to 6,270 of 12803
  1. #6256
    Jul 2016
    Vilnius
    Quote Originally Posted by rak183 View Post
    Hello, my friend is asking if this interface a good one? Thanks.
    Tell him it's decent but not one of the best possible options. This interface doesn't have K-line controllers although who uses K-line these days?!
    * MK100
  2. The Following User Says Thank You to hid3 For This Useful Post:
    rak183 (12th May, 2018)
  3. #6257
    DK Veteran bibkare's Avatar
    B & H
    Quote Originally Posted by hid3 View Post
    Have you seen those 1AM npn transistors, there is K-line
  4. The Following User Says Thank You to bibkare For This Useful Post:
  5. #6258
    Jul 2016
    Vilnius
    Quote Originally Posted by bibkare View Post
    Well, if you read carefully, I told _controllers_ Yeah, I did see them.. My cheap interface also has got transistors versus the controllers. K-line may work - I don't have such a car to test it,
    * MK100
  6. The Following 2 Users Say Thank You to hid3 For This Useful Post:
    rak183 (12th May, 2018), winamax69 (5th February, 2019)
  7. #6259
    B & H
    These 1AM transistors are actually pretty good unlike those with J3Y marking, i replaced hundreds of them and maybe only 3-4 1AM, anyway option with ISO 9141 controllers much better except when Chinese put false marking SI9241 on LM393 then you get real treat
  8. The Following User Says Thank You to bibkare For This Useful Post:
  9. #6260
    Jul 2016
    Vilnius
    Maybe someone has got 17.8.1 installer of Dutch language (Netherlands)? Would like to test it with v6.3.
    Looks like at the portal they are askin 2 Euros for a download,
    * MK100
  10. #6261
    Apr 2018
    I told him to buy another one from obd2cartool and keep this interface as spare parts donor.
  11. #6262
    Jul 2016
    Vilnius
    No need to keep this one for spares.
    All is fine with it!
    Except that it has got K-line driven by transistors rather than proper controllers.
    K-line will function fine...
    Just you asked for some comments and I provided.
    Not worth to spend money only to get a cable with proper K-line unless your friend will be working often on older pre-CAN cars
    * MK100
  12. The Following User Says Thank You to hid3 For This Useful Post:
  13. #6263
    Oct 2017
    The important parts are FTDI, Atmega162, GAL16V8, MCP2515 and the TLE6250 1MBit CAN Transceiver. It even got protection diodes on the CAN bus lines, so no need to buy a new cable. 9241 K-Tranceivers are nice to have, but not needed for CAN. This cable should work just fine.
    I just wonder what the GAL-chip is needed for. It is connected in between the FTDI and Atmega and the 9241 drivers and atmega. It is a really old programmable logic chip, so I think it's not easily replaceable. I never saw a firmware for this thing.
    hid3, I've just found 17.1.3 NL version, but not 17.8.1 :/
  14. #6264
    Jul 2016
    Vilnius
    Quote Originally Posted by peetr View Post
    I found the 17.8.1. It seems that they are asking 3 Euros for the CD in a box,
    You need to look at the bottom/right side of the same page, click last tab and there will be the download.
    * MK100
  15. #6265
    Dec 2014
    PL
    BIJLAGEN
    https://www.priemus.nl/home/14-vcds-1781.html
  16. The Following User Says Thank You to Mario6 For This Useful Post:
    peetr (13th May, 2018)
  17. #6266
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by Mario6 View Post
    GAL chip is programmable logic.. can make all kinds of logic elements like OR, AND, XOR and so on gates
  18. #6267
    On my pc-s work only on Chrome.
    IE, Mozilla..nothing happend if "Bijlagen" click.
    GAL dump exist for "44" only.
    For "46" not extracted yet (or not public)
  19. #6268
    May 2018
    Default Any good
  20. The Following User Says Thank You to eliteland786 For This Useful Post:
  21. #6269
    Apr 2018
    Quote Originally Posted by eliteland786 View Post
    I have same interface. Anyone knows if it is usable with MQB platform? I can't coding "09-centr. Elect." Only adaptation and also with "13.Auto Dist Reg" and with "4B.Multifunc Module" that are shown as incompatible with interface.
    Inviato dal mio LG-H815 utilizzando Tapatalk
  22. #6270
    May 2018
    Quote Originally Posted by Illo View Post
    Cant get to connect...no led when connected to comp, computer says no.
