Page 423 of 854 FirstFirst ... 323373413418419420421422423424425426427428433473523 ... LastLast
Results 6,331 to 6,345 of 12803
  1. #6331
    Jul 2016
    Vilnius
    Correction - it will not work at all.
    For now 18.2.0 is the way to go. Seems it will take a while for that, so relax.
    Guys, seriously, do you believe 0.0.1 change in version will do any magic for you?
    * MK100
  2. The Following User Says Thank You to hid3 For This Useful Post:
    Tor999 (7th June, 2022)
  3. #6332
    Apr 2018
    Quote Originally Posted by hid3 View Post
    Why not to buy a good cable from a shop which is confirmed trusted in this thread?
    This interface (with Atmega) doesn't have K-Line controllers.
    Out of curiousity, what is the price quote for this?
    Same price as good Interface. About 21€.
  4. #6333
    May 2018
    Italy
    Hi!
    I noticed this interested forum. I am specialized in software development and reverse engeenering.
    I bought r0$$ cable some days ago.
    I have a strange problem using VAG and VCDS with VCDS Loader and i would like to understand how it works to discover this problem.
    The problem is that i do not see the bit list when i open the long coding helper and if i try to set the coding manually, VCDS says: out of range and it doesnt code (AUDI A4 B8). But i am sure that the coding is right for that module.
    While adaptation, diagnosis and other stuff works normally.
    I am using VCDS 18.2.0 and HEX-V2 cable.
    Cable test result (VAGCOM_HWType):
    FW Version : 1.96
    HW Version : 0x46
    Identification : ROSS-USA
    Has the VCDSLoader to be "alligned" with the software version or it work correctly with any version?
    I tried to download the VCDSLoader v6.3, but if i try to run VCDS by that, cable is not recognized and VCDS doesnt work.
    So how can be sure to use the correct VCDSLoader? Is there a way to see what VCDSLoader i am using?
    Does i need to flash the vag (i see there is a method to do it in the kolimer's VCDSLoader v6.3 zip file) to use VCDSLoader v6.3?
  5. #6334
    Jul 2016
    Vilnius
    can you post the snip from Autoscan of the module you are trying to recode and the new coding you are trying to recode to?
    PS: be sure to either snip the "VCID" field or change some numbers there, because R0$$ is reading this thread.
    * MK100
  6. #6335
    May 2018
    Italy
    Sorry if it is in Italian (i was trying the IT version but problem is the same).
    Indirizzo 17: Cruscotto (J285) Etichette:. ITT\8T0-920-xxx-17.clb
    N°. di Ricambio SW: 8K0 920 930 D HW: 8K0 920 930 D
    Componente: KOMBIINSTR. H20 0255
    Versione: 00300000
    Codifica: 0F04100002000008000000
    Nessun Guasto riconosciuto
    This is the part of Scan (i removed the VCID, serial number and WSC).
    17-Instruments > I would like to activate the needle sweep/gauge test, so byte 1 bit 0.
    Byte 1 is 04 (binary 00000100)
    I changed it to 05 (binary 00000101)
    So the new coding should be: 0F05100002000008000000
    Code rejected, out of range. So problem is the cable....? The software...?....my car (AUDI A4 B8 2011) ???!
  7. #6336
    Oct 2017
    I have a hex-v2 too and this is what I did: I took kolimers loader v6.3, reflashed the hex-v2 cable completely (but eeprom with the hw-tool should be enough), I've downloaded the original VCDS installer and used loader v6.3.
    It should work for you too
    edit: oops, sorry, nevermind. I forgot to refresh the page and didn't saw that someone already answered..
  8. #6337
    EU
    Quote Originally Posted by Alenet View Post
    Popup windows with God Bless. There is a version number in the bottom right corner.
    But I don't see you actually flashed your cable. Hwtype don't do that.
    About long coding. You could "uncheck" a feature you have right now and see if vcds accepts it. After that put it back and test if it's accepted again.
  9. #6338
    Jul 2016
    Vilnius
    ^^^ Good advice on trying to "uncheck" a currently existing feature.
    Also, the God Bless is only a free version thing. Commercial loader doesn't bless anything/anybody - once it's about commerce, there no God
    * MK100
  10. The Following User Says Thank You to hid3 For This Useful Post:
  11. #6339
    May 2018
    Quote Originally Posted by Empirey View Post
    Thank you Mario6 and hid3, I read your posts and If am not wrong I have to follow the tutorial part with Program VCDS with USBASP programmer but at step B at Load flash and load Eeprom I don't know what to load from Loader archive, what files bin and hex? Those with 0x44 ? And from folder Projects TL866+Progisp is neccesary to load something from there ? I found also an tutorial about the loader how to activate, it is working the proccedure ?
    Attachment 529201
    Sorry for my noob questions but it's first time when I'm doing this. Thank you a lot for helping me.
    Hi. Please can anyone help me with some steps to reflash my cable via USBASP ?
    I don't know what hex files to load from that archive and what software to use.... It's first time when I'm doing this...
  12. #6340
    Oct 2017
    Germany
    It depends on your Hardware (0x44 or 0x46). It's all described in Info.pdf. If you don't want a GUI, use "avrdude.exe" in Windows commandline.
    http://download.savannah.gnu.org/releases/avrdude/
    A working connection should look like this:
    avrdude -p m162 -c usbasp -n -v
    avrdude: Version 6.2
             Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
             Copyright (c) 2007-2014 Joerg Wunsch
    avrdude: auto set sck period (because given equals null)
    avrdude: AVR device initialized and ready to accept instructions
    Reading | ################################################## | 100% 0.00s
    avrdude: Device signature = 0x1e9404 (probably m162)
    avrdude: safemode: hfuse reads as DA
    avrdude: safemode: efuse reads as F9
    avrdude: safemode: Fuses OK (E:F9, H:DA, L:CD)
  13. #6341
    EU
    There are ready to use batch files for avrdude. Need to copy exe in unzipped archive and detect your hardware to get right one.
  14. #6342
    May 2018
    Quote Originally Posted by networkers View Post
    OK, thank you very much. I will try this.
  15. #6343
    May 2018
    Italy
    Update about the coding.
    I tried to code removing an existing bit (to readd it later), nothing. I tried to recode the SAME code. Nothing....code rejected. I cannot code anything.
    I opened the cable, the cable is r0$$-tech HEX-V2 but it doesnt provide the atmega, but a MCP2515. I do not know, test about hardware says:
    FW Version : 1.96
    HW Version : 0x46
    But as i see about instructions, i cannot flash it because it is not an atmega.
    At this point, i think i have to change the cable.
  16. #6344
    May 2018
    I am struggling to find an installer for 18.2, it seems Ross tech has taken it down, does anyone have a mirror?
  17. #6345
    Oct 2017
    FW Version : 1.96
    HW Version : 0x46
    The MCP2515 is just the CAN-Controller, and the ATA6561 is the CAN-Transmitter, connected to the MCP. You surely have a atmega162 aswell, do you? Please take pictures of both sides of the pcb and post it.
