if helps with me when i connect to reprogram (usb and parralel port) led does not turn on.
it just turns on when finishes reprograming.
still fighting with my problem...
Boas Festas
chek atmega fuses
I already enabled the BAP, but no result. But I think I can answer the question for my problem: I tried to do an auto scan of the Passat B7 and noticed, that I can not select the chassis type in the auto scan menu. The Passat B7 is not available in the list :-( After I have selected the auto scan with the auto detecion option I get this message: Function not supported by the gateway!
Maybe some of you know how to add the new Passat B7 into this list or what to do to make auto scan possible?
thanx & greets
If you are trying to get an LPT port via USB forget it.
These USB->LPT and USB->COM work very badly. I had lots of bad experiences with those adaptors.
I am not saying they don't work at all... but for me, and if we are talking in uC programming, automation programming... usually they never work.
The best way to add an LPT or COM port in a computer that doesn't have that kind of ports is using PCMCIA adaptors.
The PCMCIA adaptors add a real physical port directly working as a real port. The USB adaptors emulates an LPT or COM port and that's the problem (the emulation).
HEY!!!! I am not saying that it NEVER works... I am talking about my experience.
I'm programming this atmega with Upa-usb and always works fine.
Hello boys,
the china clone VAG 10.6 supports the ASAM protocol ?
Yesterday I try to read the Engine Module of Audi Q5 my 2009. VCDS tells: "No ASAM data" and stops.
Why ?
