Page 438 of 854 FirstFirst ... 338388428433434435436437438439440441442443448488538 ... LastLast
Results 6,556 to 6,570 of 12803
  1. #6556
    Hello, I have VCDS 18.2 and VCDS loader 1.12, can someone please activate it for me?
  2. #6557
    Dec 2014
    PL
    rak183
    Paste this converted RT USB file into the main vcds folder. Then your cable should be visible in Mprog 3.5. Then if so, program it to the correct EPT
    PID FA24.
  3. The Following User Says Thank You to Mario6 For This Useful Post:
    rak183 (30th July, 2018)
  4. #6558
    Apr 2018
    Hey,
    of corse i didnt wrote the bulgarian clone, i just read it. i wrote the Dump in second clone from obd2cartool. But the dump from bulgarian clone is locked. and i wrongly wirte false PID in obd2cartool clone. the second empty clone is not killed its now working after FTDI flash with corect PID.
  5. #6559
    As i know, even if you can extract correct eeprom from atmega, the clone will not work. FTDI married with ID
  6. #6560
    May 2018
    So i got this thing in the mail today.
    The chips say:
    MCP2515
    AT6560
    FTDI 232RQ
    HL 008 802GC 27498055-14 ARM (what is this chip?)
    since non of them say AT162 i belive this thing is trash? It came bundled with kolimers loader.
  7. #6561
    Feb 2013
    If it works, be happy and leave it as it is...no solution for ARM cip...and thats the chinese plan, sell more because can not be repaired /updated.
  8. The Following User Says Thank You to alexm1 For This Useful Post:
    Phoeny (31st July, 2018)
  9. #6562
    May 2018
    Well, it says it is unlicenced and it cant connect to my Audi B4 but that could be because i have a problematic car to connect to.
    So anyway, i want to buy the correct cable, I looked at obd2cartool.com but there are so many of them which strangely all have the same description but different prices.
    Are there any hardware differences or is it all firmware?
    I mean what is the difference between this one 42$ and this one 48$ and this one 29$? The first 2 seem to be the same thing and the 3rd one cant update for some reason but still has AT162
    I want to do coding, measuring blocks on older vehicles like my Audi 80 B4 which has K-Line and a Audi A4 B5 which has CAN.
  10. #6563
    Feb 2013
    In my opinion, The one at 29$ is just ok for your needs.
    Where did get your cable? Just in case we need buy and from where not to...
  11. The Following User Says Thank You to alexm1 For This Useful Post:
  12. #6564
    Dec 2014
    PL
    Phoeny
    For these two cars you need only a simple vag kkl with ftdi for $ 8-10 and vcds lite 1.2 in the English full version.
  13. The Following User Says Thank You to Mario6 For This Useful Post:
  14. #6565
    May 2018
    Quote Originally Posted by alexm1 View Post
    So there is a difference? can you tell me which?
    i bought it here. Probably not the smartest idea to buy from a random ebay seller
  15. #6566
    Feb 2013
    Quote Originally Posted by Mario6 View Post
    Phoeny
    It is possibke to do coding with vcds lite?!?!? I did not tried...
    Quote Originally Posted by Phoeny View Post
    Nobody test all hardware/software from obd2... to see whats the difference .
    I just said whats my opinion.
    It's important to have a cable with Atmega..after that you migth try reflash with new free stable/working dumps.
  16. The Following User Says Thank You to alexm1 For This Useful Post:
  17. #6567
    Dec 2014
    PL
    VCDS LIte 1.2 of the full version with vag kkl can do short coding, view the block of measured values, basic settings, adaptations. Audi B4 and audi A4 b5 do not support long coding. I have a vag kkl and hex can. For me, it is better to connect the audi a6 c5 2003y engine with a vag kkl than a hex can. Vag kkl also supports other cars, You can read mileage from EDC 15, read pin immo. e.t.c.
    But this topic is about vcds hex can
  18. #6568
    Feb 2013
    ....read pin immo....
    What sofware did you use for this ?
  19. #6569
    EU
    First test your cable with A4 B5. And it don't use CAN for diagnostics. Only K1 and K2.
    What engine you have in that B4? Let's hope it's not a 2.3 10v or 2.0 16v trash.
  20. The Following User Says Thank You to kaalis For This Useful Post:
  21. #6570
    Dec 2014
    PL
    alexm1
    vag k can commander 1.4 or 2.5 and vag eepromprogrammer 1.19g. (tested on audi a6c5 2003y 2.5 tdi VDO, audi a4 1.8 t 97y 125 ps, pasat b5 ,b5 fl 1.9 tdi VP and PD VDO)
