Page 440 of 854 FirstFirst ... 340390430435436437438439440441442443444445450490540 ... LastLast
Results 6,586 to 6,600 of 12803
  1. #6586
    Dec 2014
    PL
    Aleks1975S
    I tried to run 18.2.1 RUS with Kolimers V 5.0, 6.1 and 6.3. Did not work.
    Maybe you should use version 17.8.1 RUS.
    EDIT
    I checked. Kolimers loader v 6.3 works with 17.8.1 RUS
  2. #6587
    Feb 2018
    Belarus. Brest
    Thanks I know. I have a good working VCDS 18.2 ENG and VCDS 17.8.1 RUS. Can anyone have a solution for VCDS 18.2.1 RUS?
  3. #6588
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    for reference ,
    i have tried 18.2.1 Polish , but unfortunately Russian is not working .
    Jan4
  4. #6589
    Feb 2018
    Belarus. Brest
  5. #6590
    EU
    Wait for loader 7.0, then it will work.
  6. The Following User Says Thank You to kaalis For This Useful Post:
    FoxMulder (5th August, 2018)
  7. #6591
    May 2014
    Quote Originally Posted by RedNix View Post
    Hello, I bought VCDS 18.2 clone running with 1.12 loader.
    http://oi63.tinypic.com/35mjtqo.jpg
    http://oi63.tinypic.com/30sy80o.jpg
    When I connect it to car, it blinks red and thank lights solid green. After running software and trying test, while connected to car, it says: port ok, interface not found. On the other hand, when connected only to laptop interface is found with status: Not plugged into Car. Anyone has idea how to solve issue?
    You need to get it activated by your seller, it will never works without it. Or flash it with Kolimer's tool...
  8. The Following User Says Thank You to dj2d For This Useful Post:
    RedNix (10th August, 2018)
  9. #6592
    May 2014
    Quote Originally Posted by kaalis View Post
    I didn't read from Kolimer since a long time, someone knows if he's working on a new loader?
  10. #6593
    EU
    I would wait for next out-of-beta release and see what "improvements" Uwe has done to vcds.exe
  11. #6594
    Feb 2016
    I somehow damaged the pad on Atmega162 chip (Xtal1 pin15) and I want to reconnect it, but I don't know where pin 15 goes in this circuit. Thanks in advance.
    https://image.ibb.co/e6Jzfe/IMG_1849.jpg
  12. #6595
    Jul 2016
    Vilnius
    Pins 14 and 15 go to 7.3728 MHz quartz crystal (one to each end).
    Use multimeter to verity.
    * MK100
  13. #6596
    Mar 2018
    Tell me please what is the radio parts in the picture? Thank you.
  14. #6597
    xoom's Avatar
    Ylakiai
    all diodes, you can use 4148.. its SOD80C package
  15. The Following User Says Thank You to xoom For This Useful Post:
    Roma77 (12th August, 2018)
  16. #6598
    For sure noone Zener diode?
  17. #6599
    Jul 2016
    Denmark
    Can anyone help me install kolimer loader and use on 18.2 danish vcds?
  18. #6600
    EU
    What problems are you having? Reading?
