Page 441 of 854 FirstFirst ... 341391431436437438439440441442443444445446451491541 ... LastLast
Results 6,601 to 6,615 of 12803
  1. #6601
    Feb 2013
    UK Bristol
    Hi There folks.
    After broke my 2 VCDS one HEX+CAN (0x44) 2nd HEX v2 (0x46) (using probably wrong number vcds and wrong loader) both cable was recognized (detected) but shows NOT PLUGGED INTO A CAR (off course OBD2 plug was connected to car).
    So i start procedure reflash ATMEGA162..... older VCDS HEX+CAN (0x46) back to life (reflash using Programmer TL866 Plus) tested with car and at the moment work fine.
    the same firmware but for 0x44 i tried wrote to 2nd vcds HEX v2, flashing ATMEGA 162 finally was OK, but VCDS 17.8 (17.1.3) still NOT PLUGGED INTO A CAR and both LEDS not light.
    Can anyone tell me firmware for HEX V2 and HEX+CAN shoul be diffrent on is the same to both cables?
    If is diffrent someone can share firmware or link where i can find, on this forum or nuber post ( i tried find but without result)
  2. #6602
    You said your Hex+CAn is 0x44 but you said wrote 0x46. So? Post here photos good resolution with both sides of PCBs.
    For 17.x.y-18.z.w version Firware is 1.96. 0x44 or 0x46, like HW-type
  3. #6603
    Feb 2013
    UK Bristol
    Apologize if i confused... the same firmware means file from the dame package, finally Like hex-can hw is 0x44 because pin 34 and 35 is connected with GAL chip... so wrote 0x44 file then Hex v2 pin 34 and 35 is NC so i used files 0x46. But for both vcds firmware from the same package, just diffrent 0x44 or 0x46.
    I thinking maybe for Hex V2 is totally diffrent firmware from.diffrent package, because in description Hex v2 is faster then older Hex-Can and Hex v2 can support UDS/ODX.
    So this is why was my question.
    My post helps you? Please Hit Buttons
  4. #6604
    Feb 2013
    For this hardware without GAL/ATF how can we "see" the type of the hw?
    Is this one 0x44 or 0x46?
  5. #6605
    Aug 2018
    Hello there,
    iŽve figured that my cable have an ARM chip, so useless.
    thanks for your help
  6. #6606
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    only atmega 162 can be adapted......................
    yours has an arm processor .
  7. #6607
    Aug 2018
    Thank you.
    IŽll try to buy a better one.
  8. #6608
    Jul 2018
    I have but one question, does this work on 2018 VAG cars?
  9. #6609
    EU
    Even originals works only partly with latest years. Check rosstech forum.
  10. #6610
    Jul 2018
    Quote Originally Posted by kaalis View Post
    So basically it doesn't make difference if I'm using cloned interface, it works as good as the original?
    I have this one HEX+CAN
    HW: 0x44
    FW: 1.96
    PID: FA20
    Upgradable via USB using VAGCOM_EEWriteLang.exe
  11. #6611
    EU
  12. #6612
    Jul 2018
    It's not mine it's my customers car, I have HEX V2 interface too bought from obd2cartool.com but i haven't had any time to get it running yet. Will my HEX V2 work as good as the original?
  13. #6613
    EU
    If you have no Vbat in port test result, then you have fake V2.
    Check device manager for cable name/title. Is it under usb or hid devices...
  14. #6614
    Jul 2018
    Yes I know I have a clone from obd2cartool.com but that was not my question.
    My question was will this interface work as good as the original.
  15. #6615
    Quote Originally Posted by alexm1 View Post
    Is a petard.
    Quote Originally Posted by pocinas View Post
    Tested "HexV2" and "Hex+CAN" in the same car in "autoscan".
    The faster HexV2 is slower than Hex+CAN.
    And, most important, "HexV2" is, in fact, a "Hex+CAN".
