Page 444 of 854 FirstFirst ... 344394434439440441442443444445446447448449454494544 ... LastLast
Results 6,646 to 6,660 of 12803
  1. #6646
    Nov 2011
    Quote Originally Posted by networkers View Post
    Try to connect the interface directly to 12V/GND and retest.
    I just tried and got same result. I conncted directly to 12v and pressed test in VCDS it says interface not found. The led is lit up in green color. Directly after connecting to 12V the led is red for a brief moment and then swtiches to constant green. Any other ideas?
  2. #6647
    Oct 2017
    Germany
    Quote Originally Posted by Resko View Post
    i have flashed succesfully with flash and eeprom from 6.1 loader.
    You have flashed your interface by "VAGCOM_EEWriteLang.exe" orUSBasp? And we are talking about the english version?
    Maybe you have to update your FTDI-Chip, see info.pdf?!
  3. The Following User Says Thank You to networkers For This Useful Post:
    belkor (21st August, 2018)
  4. #6648
    Nov 2011
    I used usbasp with the included Project in 6.1 loader.( for 44 hw ) I downloaded multi language installer 17.8 but vcds seem go be in English.
  5. #6649
    Oct 2017
    Germany
    This is 100% org. 17.8.0-Installer in english, give them a try...
    http://www.share-online.biz/dl/ZAWI9R6PGT
  6. The Following User Says Thank You to networkers For This Useful Post:
    Resko (21st August, 2018)
  7. #6650
    May 2018
    My friends
    Does any clone version working with New Polo/Virtus (MQB) ? Anybody has tested? Because my fake "Hex-V2" from China didn't works and Rosstech said only Genuine Hex-V2 will work on this plataform (not even genuine Hex-Can works).
  8. #6651
    Newbie adicristi's Avatar
    Oct 2017
    Europe
    Quote Originally Posted by adicristi View Post
    I think I burn my interface. Even with UsbAsp I cannot repair. Do you know some good clone with AT162?
    Sent from my Mi A1 using Tapatalk
    I tested with 3 cars. Same error. I think I have an electrical problen...What I should change on the PCB?
  9. #6652
    Apr 2018
    Now I'm using Kolimer's 6.3 full package for 18.2 and it works proper
    But if I wanna downgrade my cable to 17.8 how will I now which package will good this
    I found the followings: v1-full , v2.7-full , v4-full
    Can somebody tell me which version of \/€Đ$ use these packages?
    Is there any way to check a BIN/HEX files about it's supported \/€Đ$ version?
    Thanks!
  10. #6653
    Feb 2014
    adicristi did you use MProg?
  11. #6654
    Feb 2014
    Tib82 can use kolimer v6.1
  12. #6655
    EU
    Quote Originally Posted by Tib82 View Post
    V6.3 will also work with 17.x
  13. The Following User Says Thank You to kaalis For This Useful Post:
  14. #6656
    Apr 2018
    Quote Originally Posted by kaalis View Post
    If I know right the v6.3 supports maximum only 2 languages (English + 1 additional), but my previous 17.8 cable was a multi lang. So I think that used a previous version of the BIN/HEX file. What is your opinion about it?
  15. #6657
    May 2018
    I have this interface. Is it chinese crap one, right ?
    Could you guys recommend me(post a link to buy) a good one that i can upgrade easily with VAGCOM_EEWriteLang.exe"
    Do i need buy USBASP (i'm really noob) ?
  16. #6658
    EU
    Was it atmega162 based?
    v6.3 supports English + 15 different languages (yes, I counted options from dropdown). Are you switching to other language every 10 minutes?
    Reflash loader and use other language.
  17. #6659
    Apr 2018
    ... Are you switching to other language every 10 minutes?
    Of course not But one of my friends wanna use it with German and Hungarian languages and it supports Eng+Ger or Eng+Hun. So thats why the 17 multi lang should good for him
    So I still got no answer for the package versions:
    • The v1 and v2.7 contains only 1 eeprom for 0x44 and 1 for 0x46 and the v4 and v6.3 contains eeprom for each languages. Is it means that the v1 and v2.7 are multi langs?
    • Can somebody tell me which version of \/€Đ$ use the v1, v2.7 and v4 packages?
    • Is there any way to check a BIN/HEX files about it's supported \/€Đ$ version?
  18. #6660
    Oct 2017
    Germany
    Quote Originally Posted by Fabio89 View Post
    Unfortunately yes! No Atmega162 chipset , no update, maybe no K(KL)-Line support.
    Read some pages backward and you will find a good interface from obd2cartool.com.
