Page 445 of 854 FirstFirst ... 345395435440441442443444445446447448449450455495545 ... LastLast
Results 6,661 to 6,675 of 12803
  1. #6661
    Oct 2017
    Germany
    Quote Originally Posted by Tib82 View Post
    But one of my friends wanna use it with German and Hungarian languages and it supports Eng+Ger or Eng+Hun.
    Go and get another good cable for 25 EUR and you are done :-)
  2. #6662
    Nov 2011
    Quote Originally Posted by networkers View Post
    This is 100% org. 17.8.0-Installer in english, give them a try...
    http://www.share-online.biz/dl/ZAWI9R6PGT
    Thanks networkers, i tried it, still the same result unfortunately. I even updated the atmega with 6.3 flash and hex. And also updated ftdi with mprog. Any other ideas?
    The interface worked previously with old 11.11 VCDS and got disabled when connected to internet. I will check the pcb if there are some issues with it.
    It is strange that it is detected correctly when not connected to 12V but as soon as 12v is applied interface is not found by VCDS.
    I need VCDS right now to investigate an issue with park sensors on my Tiguan.
  3. #6663
    Newbie adicristi's Avatar
    Oct 2017
    Europe
    Link?
    Sent from my Mi A1 using Tapatalk
  4. #6664
    Feb 2013
    Unfortunately yes! No Atmega162 chipset , no update, maybe no K(KL)-Line support.
    Read some pages backward and you will find a good interface from obd2cartool.com.
    Removing ARM cip and soldering Atmega on pcb will be a chance to make it work again? I see on pcb a place were will fit Atmega, wrigth?
  5. The Following User Says Thank You to alexm1 For This Useful Post:
    belkor (22nd August, 2018)
  6. #6665
    Oct 2017
    Germany
    Maybe this one:
    http://www.obd2cartool.com/vagcom-16...version-p-1266
    You need an USBASP programmer to update/reflash.
  7. The Following User Says Thank You to networkers For This Useful Post:
  8. #6666
    Jul 2018
    17.8.0 work VCDSLoader_v5
  9. The Following User Says Thank You to shkumbata74 For This Useful Post:
  10. #6667
    Oct 2017
    Germany
    Quote Originally Posted by Resko View Post
    What does "VAGCOM_HWType.exe" and Windows System/Hardwaremanager show about your interface?
  11. The Following 2 Users Say Thank You to networkers For This Useful Post:
    belkor (22nd August, 2018), Resko (22nd August, 2018)
  12. #6668
    Feb 2014
    Attachment 550793
    Attachment 550794
    no attachments
  13. #6669
    xoom's Avatar
    Ylakiai
    You can diagnose Park sensors without diagnostics just by ear.. if you get close and listen to them they make sound (tik tik tik tik tik....) that's working sensor (atleast BMW sensors do that)
  14. The Following User Says Thank You to xoom For This Useful Post:
  15. #6670
    Apr 2018
    Wow one more reply without any answer or helping hint I don't wanna buy a new one, I wanna reflash it with the right contetnt.
    Is there anybody here who know something about these questions?
    • The v1 and v2.7 contains only 1 eeprom for 0x44 and 1 for 0x46 and the v4 and v6.3 contains eeprom for each languages. Is it means that the v1 and v2.7 are multi langs?
    • Can somebody tell me which version of \/€Đ$ use the v1, v2.7 and v4 packages?
    • Is there any way to check a BIN/HEX files about it's supported \/€Đ$ version?
  16. #6671
    Nov 2011
    Mine looks like this:
  17. #6672
    Feb 2013
    I did not remember the page were was shared last dumps, but look for the latest loader v6.3. There you will find pairs eeprom +flash ×44.×46. Take them and use it as a pair , not combined.
  18. #6673
    Jul 2016
    Vilnius
    Why do you keep diggin up old versions? Have you tried Windows 98? LOL. Forget about the previous versions. Each Kolimer's version is a significant improvenet over the old one; once new one is out, the previous ones should be forgotten.
    Having said the above, use Kolimer's v6.3 or v7.0 with any VCDS version, starting from 17.1.3 till 18.2.1 and enjoy.
    * MK100
  19. The Following 2 Users Say Thank You to hid3 For This Useful Post:
    belkor (22nd August, 2018), kaalis (22nd August, 2018)
  20. #6674
    Feb 2014
    my new clone vcds hex v2
  21. #6675
    Oct 2017
    Germany
    Are you sure, that you have written the right FTDI file? Check what kind of FTDI-Chip is on PCB. I guess you need to write "ftdi_mprog_BMBL.ept" with mprog.
    Then you will get:
    USB VID=0403
    USB PID=FA20
    Manufacturer=Ross-Tech
    Product=Ross-Tech HEX-USB
  22. The Following User Says Thank You to networkers For This Useful Post:
