Page 448 of 854 FirstFirst ... 348398438443444445446447448449450451452453458498548 ... LastLast
Results 6,706 to 6,720 of 12803
  1. #6706
    Aug 2018
    Poland, England
    Quote Originally Posted by belkor View Post
    first download from here kolimer v6.3 https://www.sendspace.com/file/em3y1f
    AV or Windows Defender off
    plug in your cable into OBD socket car
    run VAGCOM_HWType as admin and report
    FW Version : 1.84
    HW Version : 0x44
    Identification : HEX-OEM
  2. #6707
    Feb 2014
    Quote Originally Posted by bratek View Post
    FW Version : 1.84
    HW Version : 0x44
    run VAGCOM_EEWriteLang as admin choosing your language and report
  3. #6708
    EU
    Everything runs from limited user as good as from admin.
    vagcom_EEwritelang.exe is not detected as bad. Virustotal detection ratio: 3 / 66 (all 3 from unknown antivirus software).
    Only vcdsloader.exe needs AV exception.
  4. The Following User Says Thank You to kaalis For This Useful Post:
    belkor (24th August, 2018)
  5. #6709
    Jul 2016
    Vilnius
    vagcom_EEwritelang.exe will NOT work on his cable since it doesn't have bootloader enabled.
    Please do no mislead people.
    * MK100
  6. The Following 2 Users Say Thank You to hid3 For This Useful Post:
    belkor (24th August, 2018), jan4 (24th August, 2018)
  7. #6710
    Feb 2014
    Quote Originally Posted by hid3 View Post
    you`re right
    we will see after his report
    mislead people ???????
  8. #6711
    Jul 2016
    Vilnius
    bratek will need to do some soldering and reprogramming before he'll be able to use vagcom_EEwritelang.exe
    * MK100
  9. The Following User Says Thank You to hid3 For This Useful Post:
  10. #6712
    @belkor and maybe others: "not mislead people" - translate as "do not disinform"... hid3 use a translator from russian to eng and sometimes google or yandex translator offer a bad translation. Like here.
    About "not in bootloader mode"..i think are more causes.
    the most common cause is "chinese firmware". No bootloader, bypassed bootloader, modified bootloader+firmware...
    Or, sometimes, not proper fuse setting.
  11. The Following User Says Thank You to liviudiaconu For This Useful Post:
  12. #6713
    Feb 2014
    I supposed that.......no problem at all...........thanks to all
  13. #6714
    Aug 2018
    Poland, England
    Pins 1-4 are not connected at all.
    So let's start with soldering pins for the programmer.
    When I do, I'll check your suggestions ...
  14. #6715
    Feb 2013
    Check the edited photo 1-4 should corespond to Atmega , use multimeter -ohm scale.
  15. #6716
    Jan 2018
    Thank you for your quick reply. Connections are ok. I had program correctly and easy way other vag. USBASP works good. Only this cable that I program before without 5V, now is it not programmable. Now when I give it 5v led doesn't turn on and I have the message "chip enable program error". I ask what I have to do to program this vag or if it's no more programmable
  16. #6717
    Feb 2013
    I never see or heard anyone saying that is posiblle to reprog atmega without power up by obd2 or direct to LM7805.
    Now, you migth blocked atmega for further operation until you use a tool to recover(I do not remember the name of that tool). search google fot atmega doctor reset etc.
  17. The Following User Says Thank You to alexm1 For This Useful Post:
  18. #6718
    Jul 2016
    Vilnius
    The entire circuit operates at 5 Volts. You can use 5V from the programmer to power up the AT162. In fact, that's what LM7805 actualy does.
    I really doubt someone might need to use high voltage programmer against ATmega162, unless somethng has gone really really wrong (e.g. RST disabled?!).
    Usually under normal conditions that doesn't happen.
    * MK100
  19. The Following 2 Users Say Thank You to hid3 For This Useful Post:
    belkor (24th August, 2018), paro44 (28th August, 2018)
  20. #6719
    Aug 2018
    Poland, England
    Quote Originally Posted by alexm1 View Post
    I confirm, you're right, only the order is different
    not 3-1-2-4 only 3-2-1-4
    what voltage and from where?
    with OBDII or USB?
  21. #6720
    Feb 2013
    12 vcc to lm7805
  22. The Following User Says Thank You to alexm1 For This Useful Post:
