Page 449 of 854 FirstFirst ... 349399439444445446447448449450451452453454459499549 ... LastLast
Results 6,721 to 6,735 of 12803
  1. #6721
    Aug 2018
    Hello, looking for VCDS cable advice. I have a 2015 Golf SportWagen TDI, & am looking for cloned cable that will support the latest (or a suitable) version of VCDS.
    I not only want to check for codes but also make some changes to my TDI programming. ( nothing major)
    Since there are a ton of cloned cables out there, I really don't know where to start.
    Any help would be appreciated.
  2. #6722
    Quote Originally Posted by hid3 View Post
    The entire circuit operates at 5 Volts. You can use 5V from the programmer to power up the AT162. In fact, that's what LM7805 actualy does.
    I really doubt someone might need to use high voltage programmer against ATmega162, unless somethng has gone really really wrong (e.g. RST disabled?!).
    Usually under normal conditions that doesn't happen.
    Normal conditions= REAL FischlDE programmer, too. But almost whole peoples use "china clone cheap AVR ISP Programmer". First time must reprogram with another firmware and, sometimes must use "K" drivers.
    My personal example: use an cheap programmer. Working 99% well on XP SP2 and eXtreme burner 1.4.3.
    On another laptop with W7 64 work 80% well with "K" drivers/extreme burner or ProgISP. The same on W10/64.
    W7/64=on a Dell Latitude. So, is possible the news USB controlers be a little bad wquality or..drivers?
    Because of this, time to time must use after "atmega doctor" or HVP. But, because of bad quality A162 (maybe china clone too) few times with HVP the A162 was broken. Can programm but.. K1,K2 OK, CAN Not ready. But car having CAN. And no one of CAN tranceivers not bad.
  3. The Following 2 Users Say Thank You to liviudiaconu For This Useful Post:
    belkor (24th August, 2018), paro44 (28th August, 2018)
  4. #6723
    Apr 2018
    Quote Originally Posted by tucano79 View Post
    ... Now when I give it 5v led doesn't turn on and I have the message "chip enable program error". I ask what I have to do to program this vag or if it's no more programmable
    My USB ISP programmer's got 4 active GND pin and one time when I used my programmer cable with the cheaper USB ASP programmer I got the same fault and error message. To solve it I have to rewire my programming cable, because the USB ASP had only 1 active GND pin and my programming cable used one of the other 3 pins Now it's working both programmer
    For the first step I should check my programmer and my programming cable... Does the USB port / programmer supports the 5V ? Is the programming cable still in good condition (no cracks or anything else)? If you using Jumper cables, then is the wiring good?
  5. The Following 2 Users Say Thank You to Tib82 For This Useful Post:
  6. #6724
    May 2018
    Quote Originally Posted by Fabio89 View Post
    My friends
    Does any clone version working with New Polo/Virtus (MQB) ? Anybody has tested? Because my fake "Hex-V2" from China didn't works and Rosstech said only Genuine Hex-V2 will work on this plataform (not even genuine Hex-Can works).
    Attachment 550657
    Up ! Anyone using VCDS clone in MQB-A0 Plataform (New Polo)?
  7. #6725
    OLD Hex+CAN (and your clone HexV2 is in fact Hex+CAN) not work on MQB. Your clone "hexV2" havinh only case like original HexV2
  8. The Following 2 Users Say Thank You to liviudiaconu For This Useful Post:
    belkor (29th August, 2018), paro44 (29th August, 2018)
  9. #6726
    May 2018
    Yes, i know that it is Hex+can (crappy one ).
    So, Doesnt have any VCDS Clone version working on MQB-A0 Plataform yet?
  10. The Following User Says Thank You to Fabio89 For This Useful Post:
    belkor (31st August, 2018)
  11. #6727
    Not and, sincerily, i think will not appear one.
  12. The Following User Says Thank You to liviudiaconu For This Useful Post:
  13. #6728
    May 2018
    Genuine Hex-v2 is so expansive here in Brazil, but i'm seeing i don't have any other choice
    Maybe New Jetta 2019 also won't support Hex+Can....idk
  14. #6729
    Jul 2016
    Vilnius
    Maybe a ticket to States and back plus buying HEX-V2 there will be cheaper than obtaining it in Brasil
    * MK100
  15. #6730
    Senior Member makadam's Avatar
    Nov 2010
    EUROPE
    Does anyone found solution for Can not ready? I have several cables with this problem so far without resolving the problem. Cables are different HW versions.
    We can't help everyone, but... everyone can help someone!
  16. #6731
    EU
    Is your car "can ready"?
  17. The Following User Says Thank You to kaalis For This Useful Post:
    belkor (4th September, 2018)
  18. #6732
    Feb 2014
    Quote Originally Posted by makadam View Post
    try on cars from 2009 onwards and see what happens.
  19. #6733
    Feb 2013
    Happened me to a few times at first Test, Can:Not ready! All of them was Audi. After a few connect/disconect obd2 socket, give another try and Can: Ok. All those cars was Can Ready!
  20. The Following User Says Thank You to alexm1 For This Useful Post:
    belkor (5th September, 2018)
  21. #6734
    Yes, me too. Only at first test of same cable on the same SW/ same pc.
  22. The Following User Says Thank You to liviudiaconu For This Useful Post:
  23. #6735
    Nov 2010
    EUROPE
    Different cars and every car was was after 2010 y. Problem is strange because I change almost every important component from working cable to non working but never succeeded to repair them! I have both version 0x44 and 0x46. I try several times connect disconnect check can-H can-L connection but nothing. I noticed that also some people have this problem but no one found solution. Once time even I bought 2 pcs chinese cables (red one) with this problem it was 15.7 version, one ot them has this problem!
