Page 456 of 854 FirstFirst ... 356406446451452453454455456457458459460461466506556 ... LastLast
Results 6,826 to 6,840 of 12803
  1. #6826
    Jul 2016
    Vilnius
    LOL, those russkies steal and copy everything; starting from Concorde ending by VCDS/Vasia and now they got their hands even on kolimer's loader... Strange how they diidn't amend his banner.... Come on, make something on your own, at least once in a history!
    * MK100
  2. The Following User Says Thank You to hid3 For This Useful Post:
    belkor (22nd September, 2018)
  3. #6827
    Mar 2018
    Quote Originally Posted by hid3 View Post
    Who helps people - he spends time in vain)))))), funny but .... no one appropriated the merit of a colimer, the case in the flash driver in which there is no choice of language, unlike the brewer in the package 6.3.
    Perhaps all the problems are due to the curved interpreter.
  4. #6828
    Jul 2016
    Vilnius
    The software you provided was re-worked by russians.
    And kolimer's stuff always had an ability to choose the language, where it was required
    * MK100
  5. #6829
    Mar 2018
    Maybe you are right, but in any case it helped a person with the problem san - not found, maybe help others and do not need to change the quartz.
    Maybe we do not understand each other correctly because of the bad Google translation.
  6. #6830
    Aug 2018
    hi guys ive successfully reflashed my vag 178 interface 0x46 but im still getting the same error as i was getting before when plugged in the car and I click test I get interface no found. did I need to do anything else after I flashed with usbasp ?
    thanks again
  7. #6831
    Quote Originally Posted by Roma77 View Post
    The flasher is kindly laid out elpaso544, allows to work simultaneously with two versions 17.8.1rus-18.2.0eng, no language selection, just flashing and working with two versions. He also kindly shared the information that the Labels files from version 18.2.1 can also be used in version 17.8.1, I checked everything works. https://yadi.sk/d/0uVPl3sC3ZyToB
    And the password for loader archive?
  8. #6832
    EU
    Try: vcds
    It's written in txt file from archive.
    But vcdsloader is the same as v6.3 from original.
  9. The Following User Says Thank You to kaalis For This Useful Post:
    liviudiaconu (24th September, 2018)
  10. #6833
    Jul 2016
    Denmark
    Hello guys how can i update this to Danish langauge?
    When i try with kolimers package it says "Not in bootloader"
    Do you know the pinouts for this?
  11. #6834
    EU
    Really bad image. Can't see sh##t. If you don't see atmega162, then it's not possible.
  12. The Following User Says Thank You to kaalis For This Useful Post:
    belkor (24th September, 2018)
  13. #6835
    Aug 2018
    Guys I'm still getting interface not found when plugged in car do I need to do anything else after I've flashed with USBASP?
  14. #6836
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by romaiz View Post
    does it reflashes now with eepromwrite.exe?
  15. #6837
    Aug 2018
    xoom do I need to run vagcom_eewrite.exe while it is connected to USBASP?
  16. #6838
    xoom's Avatar
    Ylakiai
    no need usbasp.. only put 12V to cable (pin 16 - +12V , 4-5pins - GND)
  17. #6839
    atmpitbull's Avatar
    Sep 2018
    Hi i have this
    and Polish version 17.1.3 how update to 18.2.1 english or polish? With loader v6.3 not work polish and english version 18.2.1
  18. #6840
    EU
    use 18.2.0 english + v6.3 loader
