Page 459 of 854 FirstFirst ... 359409449454455456457458459460461462463464469509559 ... LastLast
Results 6,871 to 6,885 of 12803
  1. #6871
    Feb 2013
    Usually is dead when you get malfuntion device or no device detected in dev manager; or is seen from time to time...
  2. #6872
    Apr 2018
    On the pcb there is fake ftdi without any description. Interface is 4 mount older its working with colimer 6.3 after flash with usbasp.
    I will try another Computer and see if it stil unknow devise.
  3. #6873
    Mar 2017
    Bras?lia - BRAZIL
    VAGCOM_EEWriter.exe (quoted into file "Info.pdf") IS NOT in VCDSLoader_v6.3.zip file...
    Any sugestion? Thank you.
  4. #6874
    EU
    Yes, that file was in V5 and older versions.
    Use VAGCOM_EEWriteLang.exe for the same purpose.
  5. #6875
    This cable is on atmega and could be repaired with USBasp?
  6. #6876
    Not Atmega inside.
  7. The Following User Says Thank You to liviudiaconu For This Useful Post:
    1 6 D (3rd October, 2018)
  8. #6877
    Apr 2018
    Hi Guys,
    First of all I'm using and old-fashioned, but goot HEX-CAN with AT162 and it works well for me... Today I got a few pics about a cable and I'm very interested your opinion. As the owner (seller) told me it can update itself online, it supports 16 langs in the same time and it needs a Loader (v1.12e) too.
    I know nobody love and believe in online uptadeable cables, but pls take a look and tell something about it.
  9. #6878
    EU
    ok, tell what?
    Connect obd side to 12v source, connect to usb port, try to flash it with v6.3 eewritelang. If bootloader is locked use a programmer solution.
    Ask seller can it run multiple vcds executables in the same time and read engine ecu with english, abs with polish and gearbox with chinese... Can it?
    Don't see real purpose with 16 languages in the same time.
  10. #6879
    Quote Originally Posted by Tib82 View Post
    Hi Guys,
    [...] Today I got a few pics about a cable and I'm very interested your opinion. As the owner (seller) told me it can update itself online, it supports 16 langs in the same time and it needs a Loader (v1.12e) too.
    That cable is like a "V6.1 ?? cable" but bad copy. Because V6.1 clone have another power regulator. This have a 78L05... If the quality still the same as at first "6.1" cables, is ok. little components. If this, is possible 78L05 be still cold.
    v1.12e loader..i don't know. A chinese petard? with registration?
  11. #6880
    Jul 2016
    Vilnius
    Tib82,
    this one is (was) a genuine RT but with blacklisted serial or very similar to it. Chinese bought these cables in order to reverse engineer and make clones.
    Good/quality piece of hardware, works fine with Kolimer's stuff once reflashed.
    * MK100
  12. #6881
    Apr 2018
    Quote Originally Posted by kaalis View Post
    ok, tell what?
    The default language is English and most of the Earthlings can use it more or less. But what if I wanna use 2 other languages in the same time? The cause is not important... Beleave it or not, it has prupose. For me or for somebody... but has... But okay, forget the number of langs for a while....
    I think the most important part of this question, is there any chance that it can update itself online to the latest release without blocking?
    And if any problem appears, there is a possibility to re-flash it.
    If it is truly a re-flashable cable (and not a cheap clone) and if is hasn't got any serious issue, than it knows more than a "usual HEX-CAN" interface (online update and multi lang support). In this case why not this one is the most used version?
    This is what I found how the Loader Eva v1.xx looks like:
    https://www.linkedin.com/pulse/how-i...are-steven-hou
  13. #6882
    Oct 2018
    Does loader 6.3 work properly with VCDS 18.2.1 russian language?
  14. #6883
    Mar 2018
    Quote Originally Posted by Toljanoss View Post
    Good question i too would like to know.
    tried it. connects to the machine, but does not register.
  15. #6884
    EU
    Tried yesterday, doesn't work. Looses licence instantly.
  16. #6885
    Sep 2018
    Is there any way to edit the *.CLB files to add my own descriptions ?
    Thx
  17. The Following User Says Thank You to apc005 For This Useful Post:
    Meat-Head (4th October, 2018)
