7.0 works fine with 18.2 polish and 18.9 english ?
You can try any combination you want. If doesn't work you can start all over with the same hardware. No need to put it in trash bin and buy another.
Yes V7.0 works fine with 18.9.0 english released before 18th october.
Read page by page backwards and learn new things. Spoonfeeding is in RT forum![]()
Hello. Im locking for French 18.9 vcds. Can some one share it. Thanks.
Thank you !![]()
VAGCOM_HWType FW Version : 1.96
HW Version : 0x44
Identification : ROSSTECH !
chip installed cable:
ATMEGA162 16AU 1604M
ftdi ft232rl
mpc2515
mpc2561e
atmel atf16v8b 15jc 0218
l9637d x 2
have problem sometimes I have a "communication error" and software crashes car diaologhe, why ! Used sw vcd 18.9 ITA and loader v6....?
Can you try the same with v7.0 loader?
not have loader v7 sir
Hi! Quick question; What's the easiest way to connect VCDS cable (2018 version HEX-V2) to 12V when writing/flashing with VAGCOM_EEWriteLang? I'm thinking of attaching a + wire to pin 16 and a -wire to pin 4 or 5 on the OBD-2. Is it safe, and will it work?
Yes this will work
Look at links at the end of this post: http://www.digital-kaos.co.uk/forums...=1#post3401808
mapexo (22nd October, 2018)
have resolt, worked interface used loader v7, thankyou!
The sha256 hash of the 18.9.0 drv installer that I've got a few days ago is be03a248c59755ed7d69dfcf6f725cca77185af6bb0ecf7f7a 47960646048407, the digital signature is from 05 Oct 11:07 and it works just fine. How many different versions are out there?!?!
Picture cabling is correct but the labelling is wrong. -12v should be 0v (or GND for GrouND).
I just used an old 12v netgear router power adapter by cutting off the connector end and soldering a suitable pin socket onto the 0v lead and another onto the +12v lead:
