Page 472 of 854 FirstFirst ... 372422462467468469470471472473474475476477482522572 ... LastLast
Results 7,066 to 7,080 of 12803
  1. #7066
    Nov 2015
    Quote Originally Posted by MacNB View Post
    Picture cabling is correct but the labelling is wrong. -12v should be 0v (or GND for GrouND).
    I just used an old 12v netgear router power adapter by cutting off the connector end and soldering a suitable pin socket onto the 0v lead and another onto the +12v lead:
    Attachment 566175
    how much amper (A) does it need?
    Gesendet mit Tapatalk
  2. #7067
    Athens
    hello
    after i did succeful upgrade with the loader ...today i went to my car and try but i got this...??
    what must I do??
  3. #7068
    Athens
    it works with the test in my desktop pc
    but not on the laptop??
  4. #7069
    Athens
    the problem is when i insert it in the obd
    can not do the test thing
  5. #7070
    Oct 2018
    Hi, you need only 250mA to power the interface on 12V.
  6. The Following User Says Thank You to Nullos007 For This Useful Post:
    FoxMulder (28th October, 2018)
  7. #7071
    Athens
    please help somebody...
    when i power up the interface with 12 i have the same problem....
    when i dont have powerup it i have this...
  8. #7072
    xoom's Avatar
    Ylakiai
    does LED lit up?
  9. #7073
    Athens
    yes red and then green
  10. #7074
    Athens
    when i do VAGCOM HWtype i get
    FW 1.96
    HW 0x96
    identification ROSSTECH
    can i start over the EEwriteLang.exe??
  11. #7075
    Apr 2018
    Quote Originally Posted by onoff View Post
    FW 1.96
    HW 0x96
    Yes. If you are lucky it will be flashed. If not (interface not in boot mode) you have to use usb asp. See info.pdf inside colimer v7.
  12. #7076
    Athens
    Quote Originally Posted by rak183 View Post
    but how did i flashed in first place?
  13. #7077
    Athens
    can not flash it any more...
    it says "error flashing custom firmware"
  14. #7078
    Apr 2018
    Share picture of your pcb.
  15. #7079
    Athens
    124ki9y.jpg here it is....
  16. #7080
    Athens
    i manage to flash again...
    back that it was... 18.2
    so what im doing wrong?
