Page 476 of 854 FirstFirst ... 376426466471472473474475476477478479480481486526576 ... LastLast
Results 7,126 to 7,140 of 12803
  1. #7126
    May 2016
    Kaunas
    Quote Originally Posted by fedez View Post
    here is 912, is it possible to reflash?
    Yes..........
  2. #7127
    Nov 2018
    Hello, I'm somewhat new to all the VCDS stuff (just had some cheap OBD2 dongle), but I want to now reset my service interval and also do other things.
    I searched for quite a while until I found this forum and that there are cheap cables from china.
    I found this cable: https://www.aliexpress.com/item/VAG-...953979572.html
    Does this thing look legit? Or is it not possible that it already has this 18.9 version and I should buy an older one?
    I guess I should use the b164183bc43b6bcc95c75dded3dd634be4371ec3 installer instead of the CD they send me because the china CD might contain malware, or will that not work?
    Thank you
  3. #7128
    Mar 2018
    Quote Originally Posted by manedi View Post
    Thank you
    Don't bother with Aliexpress. Trash!
  4. #7129
    EU
    Are you sure? It's the same as cartool, only this is 6usd cheaper. If you are lucky, can find the same for as low as 19usd. Then why pay 2x times more as cartool and get only 1x cable?
  5. #7130
    Feb 2018
    Latvia
    Quote Originally Posted by Xaby View Post
    Solder wires directly to atmega pins.
    didn't work with soldering direct to pins atmega
  6. #7131
    Realy?it working!
  7. #7132
    Jul 2016
    Vilnius
    Quote Originally Posted by kaalis View Post
    No, it's not the same, mate..
    That cable doesn't have controllers for K-lines and is driven by transistors. That's why it's better to go with Obd2cartool's version!
    Sometimes you get what you pay for. Be careful.
    * MK100
  8. #7133
    EU
    Yes, my bad. Didn't check pictures good enough from phone. Still possible to find and get the same hardware as "they" are selling for less money.
    I'm not changing my mind. You know what i got this monday.
  9. #7134
    Jan 2011
    Quote Originally Posted by vaicekas View Post
    Yes..........
    I have reflashed atmega and got error: not plugged into car, blinking red?
  10. #7135
    EU
    ... and you want to know how to connect it to your car?
  11. #7136
    Nov 2018
    Quote Originally Posted by hid3 View Post
    So I should buy this instead:
    https://www.obd2cartool.com/-p-1566
  12. #7137
    Jan 2011
    connected 12v to obd, or its not enough?
  13. #7138
    Mar 2018
    Doubt very much it is the same!
  14. #7139
    Feb 2013
    well...when will arive to you, you can share some pics and we will compare it.
  15. The Following User Says Thank You to alexm1 For This Useful Post:
    kaalis (2nd November, 2018)
  16. #7140
    Nov 2018
    It is also due to this
