Page 477 of 854 FirstFirst ... 377427467472473474475476477478479480481482487527577 ... LastLast
Results 7,141 to 7,155 of 12803
  1. #7141
    Apr 2018
    Quote Originally Posted by mixio60 View Post
    It is also due to this
    Its possible to share pictures from your pcb? Im Interessed to know witch component are inside.
  2. #7142
    Quote Originally Posted by mlodywafel View Post
    hello anybody can help i need coding rear led light on passat b7 on bajt 18 but what codding is correct?
    To code it correctly u need VCP.
  3. #7143
    May 2016
    Kaunas
    Quote Originally Posted by fedez View Post
    I have reflashed atmega and got error: not plugged into car, blinking red?
    Double-check which files you use for your hardware type, and which fuse bit you are writing.
    Maybe you should remove these wires from GAL and use files for hardware type 0x46
    Also, you should carefully clean the flux from the soldering points.
  4. #7144
    Nov 2018
    Can I not buy anything on www.obd2cartool.com without my name and email showing up at the "History" tab for the whole world to see? Kinda nogo for me to buy there if I cannot disable this.
  5. #7145
    Jul 2016
    Vilnius
    Contact the team directly via Skype or email and they will arrange it to you
    * MK100
  6. #7146
    hi can some one
    help activate vcds 16.8.3 by key lick picture
  7. #7147
    EU
    Hello, i have problem getting bench setup connecting to VCDS.
    I have 1K0 gateway directly connected to obd2 connector and that to vcds cable. It works. VCDS connects.
    And then there is also 1K0 convenience module that is connected via convenience CAN to the Gateway.
    Installation list: everything unchecked leaving only #19 gateway and #46 convenience saved.
    Gateway's measuring blocks can see if conv.module is connected with one or both can wires.
    And this is my problem. VCDS can't connect to #46 (Central Conv). What's wrong? Any hints what else to look or missing?
    Modules are in working condition and were tested before removal from car.
    Gateway 1K0907530C
    T20 connector
    #1, #2 - 12v permanent
    #5 - convenience CAN-L (to convenience module)
    #9 - diagnostics CAN-L
    #11, #12 - ground
    #14 - 12v switched
    #15 - convenience CAN-H (to convenience module)
    #19 - diagnostics CAN-H
    Convenience 1K0959433AK
    T18 brown connector:
    #2 - 12v permanent
    #3 - ground
    #9 convenience CAN-H (to gateway)
    #10 - convenience CAN-L (to gateway)
    Convenience CAN-L against ground ~5 Volts
    Convenience CAN-H against ground ~0.2 Volts
  8. The Following User Says Thank You to kaalis For This Useful Post:
    seal777 (5th November, 2018)
  9. #7148
    Dec 2017
    I need working VCDS software for this HEX-V2.
    Preferred language is German.
    I have some software version with VCDS loader, but that don't work on this cable.
    Thank You!
  10. #7149
    Feb 2013
    Prefered ...for you to buy another. With Atmega for example...this one keep it how it is...or recicle it.
  11. The Following 2 Users Say Thank You to alexm1 For This Useful Post:
    kaalis (2nd November, 2018), mladen223 (2nd November, 2018)
  12. #7150
    EU
    We will need picture from other side also.
  13. The Following User Says Thank You to kaalis For This Useful Post:
  14. #7151
    Dec 2017
  15. #7152
    Jan 2011
    Quote Originally Posted by vaicekas View Post
    yes, am removed wires from GAL and used 0x46 files, flashed with ponyprog...I will try with USBASP
  16. #7153
    Jan 2011
    EU
    Quote Originally Posted by mladen223 View Post
    B side
    Yes, as Alex said before, it's expensive transistor holder.
    Loader will not work. You have to use software that you got when buying this cable.
  18. #7155
    Dec 2017
    Software CD is missing. As far I know, on this cable is successfully used 17.1 software, but after windows reinstalling we can't find working version anymore.
