Page 483 of 854 FirstFirst ... 383433473478479480481482483484485486487488493533583 ... LastLast
Results 7,231 to 7,245 of 12803
  1. #7231
    Jul 2016
    Vilnius
    Can you please describe what is wrong and in which modules?
    * MK100
  2. The Following User Says Thank You to hid3 For This Useful Post:
    kaalis (18th November, 2018)
  3. #7232
    Two controllers: 15 Airbag on NATIVE K, not by Can GW, and 19 Can GW by CAN.
    Created a virtual car with 15,19 = 16 times
    autoscan..stop after 16 scans on Address 15 and after 15 scans Address 19. Not finalize, not timer (end x minutes).
    clear all DTC: start Address 15, Start Address 19, start Address 15 and stop. Not all 16 "pairs" DTC erase do-it.
    On Address 15 make Clear DTC, make Adaptations..
    On Address 19 Clear DTC but..long coding not. Press Do-IT and nothing happend.
    The eeprom remain clean but no LC.
    Attn: the method with virtual car working well in the others versions of V(d$
  4. The Following User Says Thank You to liviudiaconu For This Useful Post:
    kaalis (20th November, 2018)
  5. #7233
    May 2018
    Quote Originally Posted by Fabio89 View Post
    Please, need some help
    I have VCDS Atmega162 from china - Well after a take a picture i see it actualy is atmel
    https://imgur.com/5udY3GK
    https://imgur.com/Kk4yEUX
    I Flashed with VAGCOM_EEWriteLang chossing Portuguese - PTT, but when start VCDS 18.9 PTT it is shows unlicensed and unregistered.
    Any way to fix it ?
    EDIT: I think it works with Loader v7.1. I will test soon. message "unlincensed" is gone
    Tested with Loader 7.1 and works fine - Portuguese Version 18.9.0 Doesnt works with Loader 7.0 for me as mentioned before
  6. #7234
    Newbie adicristi's Avatar
    Oct 2017
    Europe
    What vcds can be used for 7.1?
    Sent from my Mi A1 using Tapatalk
  7. #7235
    EU
    Any actual versions. Try and report if you have problems.
  8. #7236
    Jan 2018
    Hi, which file should I choose (into the folder "eepromavr_AllLang") to program my vag in German language (VCDS-PCI-18.9.0)?
    Thank you
  9. #7237
    Oct 2017
    Germany
    Quote Originally Posted by tucano79 View Post
    eepromavr_HW_0x44_DRV.bin or eepromavr_HW_0x46_DRV.bin depending on your Hardware.
  10. #7238
    Jan 2018
    Quote Originally Posted by networkers View Post
    Thank you so much!
  11. #7239
    May 2012
    tucano79 , why using pci version when the drv version is the (reference version from english )you know. i use the drv with my genuine pci interface just because its faster in reference translations.
  12. #7240
    Mar 2018
    Hello guys
    Could You please help me with following problem?
    I have few chineese clone VCDS interfaces. I have had few versions before and succesfully flashed them with MR Kolimer FW. All were working OK with old VAGs with K-line and newer ones with CAN. Now I got something like thisIMG_20181120_234206.jpgIMG_20181120_234150.jpg
    and it doesnt work with CAN. Everytime it show "Can not ready" when doing test in VCDS. I tried v6.3 7.0 and 7.1 of loader and proper dump files. What is more interesting is that it is working with CAN ONLY on my desktop with home made CAN tester (made of Golf mk5 Cluster). But when going to car and checking if it works I got : CAN not ready. I tested it on many VAGs: Pasat B6, Audi A4 b8, A4 B7, A6 C6, Skoda Octaveia : all show the same. I measured voltage on CAN lines and it shows 0,7V. On properly working interface I got something around 2,5V. It is not an individual case. All theese interfaces I got have exaclty the same problem. They work OK with K line on evey car, but CAN works only in labolatory enviroment just with Cluster instruments conneted to 12V power AC adaptor on my desk. I suspect there might be something wrong with Analog circuits but I need somebody's help with guiding me to proper solution...
    Any clues ?
  13. #7241
    Nov 2018
    I have the same interface, the CAN line does not work the first time. It turned out that it is too weakly pressed into the OBD connector.
  14. #7242
    Nope. Begining with 6.3 loader this bug appear time to time.
  15. #7243
    Mar 2018
    But is it possible that all 10 pcs of this interface has exaclty the same issue? I will try to push it more deep into ODB2 connector, indeed it doesnt want to fit that easy in a connector. Possibly I am too weak
  16. #7244
    I said is from loder TOO not ONLY from cables. Indeed, in cables with atmega but without GAL the frequency of appeareance "Can NR" is higher. Is very possible to appear because of FTDI (china cloned FTDI too, see the problems with FTDI+Microsoft bcz of cloned FTDI, few years ago)...
  17. #7245
    Mar 2018
    Hello, I see this https://diystuff.nl/automotive/automatic-cruisecontrol/ but it is done on the NEC chip, can someone help me with the same project on Atmega162, I would appreciate any help, there is a project where they are done two boards but I wanted on a single two-layer board https://www.carhelp.info/forums/show...=1#post1505839
    Archived vcds project and ATF / GAL programmer project
