Page 484 of 854 FirstFirst ... 384434474479480481482483484485486487488489494534584 ... LastLast
Results 7,246 to 7,260 of 12803
  1. #7246
    Not a valid schematic file - error reported both sch files
  2. #7247
    Mar 2018
    Безымянный.jpgБезымянный1.jpg \/CDS - KiCad открывается нормально. ATF/GAL - Dip Trace ok.
  3. #7248
    Whats the major difference between this cables, apart the look:
    https://www.obd2cartool.com/atm-182-...hoqblebqqpaco6
    and
    https://www.obd2cartool.com/atmega-v...r_of_uploads=0
  4. #7249
    Mar 2018
    Quote Originally Posted by safm View Post
    Design, light indication of dimensions, and shipping cost)
    The best way https://www.obd2cartool.com/vagcom-1...version-p-1266
  5. #7250
    Dec 2014
    PL
    I have the same (16.8.4) and easily upgraded to 18.9.0 EN and 18.9.0 AKP. Works well.
  6. #7251
    Mar 2012
    Hello people my HEX V2 is after I forgot my Antivir software to deinstalieren, like dead :-(
    is no longer recognized in the usb port no matter which PC I take!
    Is there a good way to bring it back to life?
    Thanks in advance.
    Gesendet von iPhone mit Tapatalk
  7. #7252
    EU
    You forgot to post pictures of cable internals.
  8. #7253
    Mar 2018
    Moffo - Just place vcdsloader.exe in RT/vcds directory after disabling AV and off you go again. At worst reflash and start all over. Assuming it's an obd2tool device that is.
  9. #7254
    Mar 2012
    thanks first for the answer, I have the feeling I have to rewrite it if it is feasible, so the interface itself. Has anyone experience in things rewriting Hex V2 reperatures? I am very grateful for help!
  10. #7255
    Nov 2018
    Just got my VCDS from obd2cartool.com, works perfectly fine and seems to even come with a cable for flashing(?). I own an Audi A3 8PA 1.6l from 2010 (0588 AHU001238). My service interval indicator has been bugging me for some time and I want to reset it. I don't know if I'm on that fixed interval or the other one and the VCDS offers lots of different modes to reset, some are labelled "US only" or "worldwide" (my car was bought in Germany). This is what I get from the reset diagnostics: https://bpaste.net/show/803b778de5ea What should I choose exactly to reset the service indicator? Am I on a fixed interval or whatever the other thing was? Thank you
  11. #7256
    Mar 2018
    Moffo - This is exactly like mine with atmega. Probably from obd2tool. Bootloader is unlocked. Connect to car obd port to supply 12v to device. Then flash via usb using EEwrite file within Kolimer 7.1 zip
  12. #7257
    Jun 2016
    Can someone help me to patch my original hex v2 3 vin to unlimeted
  13. #7258
    Dec 2014
    PL
    kayne30
    Hi. Read post 7037 and send PM message to hid3
  14. #7259
    Nov 2018
    Kolimer v7.1 worked just fine for me, i found this tread during the week because my cable didn't allowed me for long coding. Turned out it was an atmega with bootloader unable so i flashed it and reinstalled original vcds 18.9 from ross tech directly, then updated interface to 1.96 like vcds asked. Voila, long coding works just fine right now! All the information are in the info.pdf file included into the zip. Thank you so much kolimer for this work, its well appreciated!
  15. #7260
    Mar 2012
    Unfortunately, this does not work, have tried everything with the programs connected to the car obd eewrite prog HW ident prog and vcds loader, unfortunately, no comunication with the interface always vcds not found :-( What possibilities do I have yet usbprogram flash?
