Yes, but can't see difference from v3 yet. The same "bugs".
And anything have for me a solution update to 18.X.X my 17.8.1?
Gesendet von iPhone mit Tapatalk
But HexV2 are not really Hex-V2, they are regular HEX-USB+CAN, so why buying them?
I compare the 3 cables below. After flashing them, they are all identical in term of VCDS functionality... aren't they?
https://www.obd2cartool.com/vagcom-1...3er8huc5t8lkc0
https://www.obd2cartool.com/atmega-v...3er8huc5t8lkc0
Close. Seller didn't reply about real testing of ATA6561 comparing autoscan speed vs classic interface. So that is just a marketing trick.
@beepi: of course V2 is regular aka HexK+CAN. But first link = a version of clone where 7805 is very hot. Why? Not sure, bad quality of components. "V2" fake is cold.
@Kaalis: That speed not usefull. I think USB (FTDI) + protocol cannot work at this speed realy.
And as i wrote here few time ago.."V2" is a little lazzy like "regular" HexK+CAN (a good clone).
kaalis (30th November, 2018)
About first link: could it be because of Palce chip to make it cheaper (bigger profit) in pictures but still with Atmel 16V8B in description?
Yes, you are correct. That's why it's marketing.
Hello friends,please can me help my 17.8.1 to higher version 18.x.x!
Thanks in advance
hello,
for vcds where can i find the explination bits from long-coding for a touareg 2016? Almost no module has long-coding explained.
Thank you
because no one made a adaptation backup and emailed to rosstech for this partnumber......
Can you please detail? How would that help describing what does each bit?
Search for coding calculator
Keep in mind, English is not my native language.
First link on Google http://www.ross-tech.com/vcds/tour/recode_screen.php
