I check voltage, in 11.79 V , out 4.95 V
Hello, China has new VAG 18.2 / 18.9 without loader, Tried it it seems to works well, PCB is 6.1 with Atmega 162 and everything, I can share informations aabout it if needed, I have received 2 to test.
I flashed one with 7.1 Kolimer's loader (thanks !) works well also.
I didn't checked yet if everything is working well, for now it can works with English and other languages, I'm testing everything later.
I know I'm late.
From now, here are your options for MQB2018+ platforms :
Official Ro$$
Official VC.P
ODIS (clone, official) with VAS or VXdiag (cheapest but needs a GEKO online access for all cool functions)
Other will not have full acess to this platform (From 1 to 3 ECU not responding, that's the issue I have with customers cars)
fennec62 (9th December, 2018)
vag12.12 cable disabled by newer than 12.12 vcds or networked vcds. Used Kolimer's VCDS Loader v7.1 got it all working perfectly with VCDS 18.9.
Was fortunate the cable (friend bought it a couple of years back) had bootloader enabled so no need for any HW mods. Just flashed the cable (failed 2x before 3rd times a charm) following by running vcds via vcdsloader, update to 1.96 and everything works. Just follow the directions in the info file in Kolimer's software package.
Here are the pics of what I have. Ignore the soldering marks on the USB red wire. It came loose so had to solder it back on. For whatever reason it had to solder onto C13 rather than then pad. I guess no continuity to the pad. Chinese manufacturing haha.
Thanks Kolimer!
Thanks for all information
just do you know where is MOSI MISI .....
Do you thinks on the motherboard G T R V is for flash ? or i must solder point on motherboard
Thanks again
Thanks i think it's ok
i flash by MCP2515 like this
Now if i start vcds 18.9 with loader i can see cable interface ok
But if put on cars with 12V led red and after green but interface not ok if 12V is present car or supply
Do you know why ?
Hi, can someone share the firmware for GAL/ATF16V8.jed 0x46 version?
I think he asked fot GAL/ATF firmware, not dumps
Maybe someone knows the Vcc pin number on "HEX-V2" programming header? Thanks
* MK100;
