Page 495 of 846 FirstFirst ... 395445485490491492493494495496497498499500505545595 ... LastLast
Results 7,411 to 7,425 of 12679
  1. #7411
    Oct 2018
    Is VCD hex v2 3 VIN is user friendly? Is it worth to buy?
  2. #7412
    Nov 2015
    home
    hello, please need you help
    a upgrade my vcds 18.2 to 18.9 success ,it worck perfectly in my seat ibiza 2014 ,big thnks to kollimer.
    but I need code security access for central electric
    Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
    Part No SW: 6R0 937 087 P HW: 6R0 937 087
    Component: BCM PQ25 H+4 H34 0411
    Revision: BF034001 Serial number: 0581 086140925
    Coding: 7A882BF888E30D0000300EF07E8B9EC800C843E9608C004020 0000000000
    Shop #: WSC 00049 770 00139
    VCID: 4A9BD429E5BF0E1A45-801E
    thanks for help
  3. #7413
    May 2018
    Cool
    Hi guys is there anyway of sorting out a hot start issue with vcds, got a 2.0 tdi bkd engine so far changed battery but still the same....been told need to flash a hot start remap rang a tuning company wanted £100 to flash...just wondered if it's possible with vcds.....where are you hids you sorted me out last time I was having issue with flashing my cable.
  4. #7414
    Dec 2014
    PL
    eliteland786
    You can not make a hot start with Vcd$. If it's really just a hot star problem (no other mechanical malfunction), buy MPPS V 16 for $ 11-16
    https://pl.aliexpress.com/wholesale?...=mpps+v16.1.02
    and ask for help here.
    https://www.digital-kaos.co.uk/forum...light=vag+vcds
    or here
  5. #7415
    May 2018
    Quote Originally Posted by Mario6 View Post
    eliteland786
    or here
    Thanks mate I take a gander at it....seen few YouTube video..where they copy the cold start over the hot start graph...and flash that...Thanks for the input.
    Anyone know reasonable priced who does it in the Midlands.... £100 at my local but feel it's a bit pricey.
  6. #7416
    joker01's Avatar
    Jan 2018
    guys there is a way to see with connection on the bench ecu engine if immobilizer is active or not ??
  7. #7417
    Hi this is my first post and I'd like your help.
    I'm trying to flash this old 10.6 cable below.
    With VAGCOMHWType has been identified as HW x046.
    i am pretty pretty sure that the connections are made correctly to the USBASP ribbon cable, assuming the red stripe is pin 1. I made them using the guide I found in this thread. Pins 8 & 10 are live ground (measured with with a multimeter)
    I give 12V to the cable by the OBD port and i connect the USBASP to the USB port. The drivers are installed correctly, (checked with device manager)
    My problem is that the LED on the USBASP is continuously red, it won't turn green whatever I do.
    I am trying to flash the Atmega chip with progisp 1.72 by I get "chip enable program error'all the time.
    I can flash the FTDI chip though with Mprog.
    Any suggestions ? Bad soldering on the Atmega chip ?
    Thanks in advance for any help.
  8. #7418
    Oct 2018
    I succesfully coded a few skoda superb with VCDS 18.9 with the HEX V2 clone cable of obd2cartool. Sadly I received a 2019 model, and VCDS is complaining that the interface is old. Is there still a way to use it for long coding and adaptations on my 2019 model?
  9. #7419
    Mar 2018
    dimitrisTSI
    delete IC8
  10. #7420
    Thanks for your answer,
    which one is IC8 ?
    If you mean the STC chip I have tried to cut the line between it and the R50 resistor.
  11. #7421
    Aug 2018
    can any one help with this clone cable
    no R50 or R51 component to remove "resistor"
    i just need a step by step tutorial
    or at least can i flash it directly via usb or LPT is must ??
    which dump should i use ??
    any one with the same dongle
  12. #7422
    EU
    Good photos. Try again.
    Search loader archive. Unzip it.
    Read info.pdf
    Connect cable (if it has atmega162) to pc and to car or 12v source.
    Use hwtype exe to check if bootloader is locked or not.
    If not use eewrite.
    Otherwise read info.pdf again, get usbasp, wire it up correctly (remember, you have read info.pdf already twice), get avrdude.exe and avrdude.conf, put it unside unzipped folder with loader and run appropriate *.cmd batch file. After that if you are successful, then copy loader exe into latest vcds folder and open it.
    If this doesn't help, read last 20-30 pages in this topic.
  13. #7423
    Mar 2018
  14. The Following 4 Users Say Thank You to Roma77 For This Useful Post:
    kaalis (20th December, 2018), miouser (21st December, 2018), SergeyIg (28th May, 2019), ZIPPO4594 (26th December, 2018)
  15. #7424
    Aug 2018
    thanks so much bro
    will try now
  16. #7425
    EU
    Also, AIB, DRV, MFT and PCI were updated. Greetings to RT.
  17. The Following User Says Thank You to kaalis For This Useful Post:
