Hi, can you help me out with the radio code for vw polo i have the VIN number ?
Hi guys, is it possible to update this vcds via USB or i must solder pin using USBASP? Thanks. photo5828195940236898502.jpgphoto5828195940236898504.jpg
When will you start reading the info file in the folder from the colimer? The shaman is visually determining whether the bootloader is unlocked has gone to work as a Santa Claus)))
https://drive.google.com/drive/folde...Un?usp=sharing
Not always HW type (44 or 46) is correctly determined by Koli's soft
That because chineses write incorrect version of flask inside Atmega. If chineses (or someone else) write firmware flash for "46" HW inside "44" HW, the soft will report "46" and viceversa. So, the best solution for knoing is to open the case and check the HW by "your eyes"
16.8.3 v7.2 18.9.0.2 updated and working well. Thank you very much!
Hello dear Digital Kaos friends. I read here for a while. Have many things solved without asking. very well explained. But.
I can not continue without asking.
I have a vag interface. I flashed it with ProgIsp (USBasp) and it works, for 3 - 4 times read out and erase errors, then vcds no longer recognizes the dongle. I can not find the stc chip on my board. Can someone help me?
Here are pictures of the dongle
Attachment 581895Attachment 581895Attachment 581896IMG_20181115_171655.jpgIMG_20181115_171657.jpgIMG_20181115_171830.jpg
nice greets deepkey
Show us pics with the other side...at list I can not open it in tapatalk
crazy ... was 3 pics of each site...
Now it's ok.
Soo, do not look for STC, it is not there, not all hw have it.
Try again to reflash, pay attention to all stepps you need to go...choose dumps for x46 HW, double check fuse bits.
Nice hardware you have there....where did you get it...how much you paid for?
I have flashed it very often. I do not know exactly which fuse bits have to be set. I used the progisp project. It works for a short time. It behaves as if it had a stc chip.
Ooh, the cable is from my father, tomorrow I can ask him where. it cost, if I remember correctly, 37 €. but worth nothing if it does not work 100%.
what i do is this...
After reflash, License is OK?
There is any antivirus program on your PC that can kill the loader? If so make some exceptions for install folder.
how i check the license?
not antivirus on my pc.
when I flash I do not have to swap the loader again ... it works again for 4-5 times read ...
License check:
Cable conected to car/12V- ignition on, Options - Test - k1k2 ok, Can: Ok or not ready.
Go to About, there is license info-( green ok, red -not ok).
thats all
so, can is not ready
but led is green
