This test was taken on car or power up with 12v on bench?
One more step to see License, to About.
I tested both
Can you repeat it with 18.9.0 PCI and loader 7.2?
Which version of loader are you using with 18.2.1? - 6.3?
OK. I have tried it with the versions ... pci 18.2.1, DRV 17.1.2, DRV 18.2.1 and release 18.2.1. I'll try it with the PCI 18.9.0.
I downloaded the last loader from here. I use progisp and burn VCDS HW 0x46 BB v2 project
Your car..is REALY with CAN?
Time to time loader say "CAN Not ready" especialy at first test. After the second test OR after AN unplug from +12V AND USB say CAN OK but ONLY IF CAN CAR ready.
SO...IF you car not after 2006 car (few 2005 can report CAN ready) you didn't report CAN Ready!!!
If your car is FOR SURE CAN Ready...maybe the cable defective! This only you can know!!!
!8.9.0 ROJ and HGJ 18 december Released. Download NOW!!!
Tib82 (25th December, 2018)
How many pages have you read?
The answer is in info.pdf - file found in the Kolimer super zip.
I had identical look pcb that had 0x46 flashed by China but in reality it is 0x44 by hardware. But check yourself.
I tested it now with the 18.9.0 and it works. read write and can io. Thank you. I will still write where the dongle came from.
I still have an original lie but is limited to three vehicles. How can I bypass this lock
169usd for upgrade to 10 vin licence or 2x169usd for unlimited. You know where is RT webshop located.
Doesn't look... you better test continuity with multimeter. Trace can go under some chip you don't see where it comes out again.
