Page 501 of 847 FirstFirst ... 401451491496497498499500501502503504505506511551601 ... LastLast
Results 7,501 to 7,515 of 12705
  1. #7501
    Dec 2018
    Quote Originally Posted by Laique View Post
    Hi guys!
    Glad that i found this topic
    I'm looking for an upgrade to 18.2 or maybe 18.9. (This cable works now with 17.1.3.)
    There are few things i dont know and hope you can help me.
    Here is my cable that came to me last week.
    Attachment 583250
    VAGCOM_HWTYPE tells me its:
    FW Version: 1.96
    HW Version: 0x46
    Files that i've found in this thread seem to have the same FW version.
    Attachment 583251
    What should i do now?
    Do i still have follow the FirmWare upgrade procedure or do i just have to install the newer VCDS, then crack it with VCDS_Loader, and then update the cable using VCDS?
    thx
    Seriously NOBODY ?!
  2. #7502
    May 2018
    Quote Originally Posted by hid3 View Post
    Not pin 1 of FTDI but rather pin 25, I believe. Check the chip orientation!
    The EEWrite tool reflashes it to the same HW as it was flashed before. It's impossible to flash it to different one because of different bootloader size/different fuse bits.
    In order to reflash from 0x46 to 0x44 you will need to do that using AVR programmer (e.g. USBASP)
    No it's definitely pin 1 next to the dot...looked at schematic and that's pin 1.
    Not going to bother with re flashing with AVR programmer if it's working let it be.
  3. #7503
    May 2018
    Quote Originally Posted by eliteland786 View Post
    Pin 1 is TXD and pin 25 is ground...AGND.
  4. #7504
    Dec 2016
    Vilnius, Lithuania
    Cool
    Some progress, made - developed Arduino Mega based bruteforce interface with GAL slot and tested with GAL from working 0x44 cable, chip works fine after such manipulations
    Wrote simple program to toggle each pin and check remaining pins state:
    void setup() {
      Serial.begin(115200);
      //Main loop
      for(int i = 22; i<=39; i++){
        //Pin configuration loop
        for(int j = 22; j<=39; j++){
          if(i == j){
            //Set togg'able pin as output
            pinMode(j, OUTPUT);
          }else{
            //All other pins as input (high impedance)
            pinMode(j, INPUT);
        //Toggle output high
        digitalWrite(i, HIGH);
          //Skip checking togg'able pin from reading
          if(j == i) continue;
          //Check if input is high
          if(digitalRead(j) == HIGH){
            //Print values to UART
            Serial.print(i);
            Serial.print(" ");
            Serial.println(j);
        //Toggle pin back
        digitalWrite(i, LOW);
    TODO: implement code for each combination toggle; Karnaugh map minimizer for logic generation.
    Results:
    OUTPUT PIN 1-(10 skipped, GND)-19 INPUT PIN 1-(10 skipped, GND)-19
    1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 - 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
    0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 - 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
    0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 - 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
    0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 - 1 1 1 1 1 1 1 1 1 1 1 1 1 1
    0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 - 1 1 1 1 1 1 1 1 1 1 1 1 1
    0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 - 1 1 1 1 1 1 1 1 1 1 1 1
    0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 - 1 1 1 1 1 1 1 1 1 1 1
    0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 - 1 1 1 1 1 1 1 1 1 1
    0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 - 1 1 1 1 1 1 1 1 1
    0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 - 1 1 1 1 1 1 1 1
    0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 - 1 1 1 1 1 1 1
    0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 - 1 1 1 1 1 1
    0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 - 1 1 1 1 1
    0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 - 1 1 1 1
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 - 1 1 1
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 - 1 1
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 - 1
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 -
    As it seems things get tricky, as it seems from datasheet, GAL can be configured as clocked, and registered modes:
    So for further investigation I need someone who can tell about known 0x44 configuration (additionally to C3H8 logic), as well as create .JED file with known logic to check if bruteforcer works fine.
    Cheers
  5. The Following 2 Users Say Thank You to Elektrik1 For This Useful Post:
    pablobrsp (2nd January, 2019), seal777 (6th September, 2019)
  6. #7505
    Mar 2018
    The algorithm of work and programming CUPL of FPGA is well described in this article. https://justmoose.ru/?p=17
    Laique
    Please read the info file in the kolimer folder, as well as several pages of the forum and you will find the answers.
    Please read the info file in the colimer folder, as well as several pages of the forum and you will find the answers.
  7. #7506
    Dec 2018
    Hello @LL,
    can someone reupload the newest loader for \/CDS 18.9.0 (DRV) German and the firmware files please ?
    Thank you in advance.
    Best regards
    schmiddie1982
    Gesendet von meinem F8331 mit Tapatalk
  8. #7507
    EU
    Run VAGCOM_HWType.exe to see if you have locked bootloader, then VAGCOM_EEWriteLang.exe if it's not locked and you don't know how old vcds version was used for it, use loader, and then update firmware after port test.
    Quote Originally Posted by schmiddie1982 View Post
    Check last post from Kolimer, there are still some loader links active.
  9. The Following User Says Thank You to kaalis For This Useful Post:
    schmiddie1982 (30th December, 2018)
  10. #7508
    Dec 2018
    Quote Originally Posted by kaalis View Post
    thx. for the answear man!
    This is all what VAGCOM_HWType.exe is telling me. How do i know if the bootloader is locked ? The cable works with 17.1.3 now.
  11. #7509
    EU
    That exe is not from 7.2 loader.
    Anyway you can try eewrite and it will tell if it's not in bootloader mode or flash it succesfully.
    Don't forget to plug it in obd2 port while flashing.
  12. #7510
    Dec 2018
    THANKS A LOT!
    The VAGCOM_HWType.exe from 7.2 shows the bootloader is enabled! i will start with VCDS 18.2.0 ENG.
    Is the 18.9.0 stable 100% ?
  13. #7511
    EU
    Latest not very, but you can report your findings in this topic.
  14. #7512
    Dec 2015
    Italy
    Hi, is possible to repair this cable?
  15. #7513
    Feb 2013
    Yes, you can. But first you need "kill" STC, see how in info.pdf from Kolimer zip.
    L.e.
    You may need to use usbasp programmer, I do not think will work by usb, but you can try...
  16. #7514
    Quote Originally Posted by Elektrik1 View Post
    hid3, they are, you can see it in screenshots and my reverse engineered schematics, I have 3 of such cables
    About your schematic i don't see K-line and L-line Rx. K-line and L-line are bidirectional.
    If that transistor with emiter "in air" i assimilate as a diode, can be Rx. And go on 17 and 19 pins of GAL. Thet mean that pins are IN, not OUT.
    Look as a correct schematic for a 44HW, not transistors but correct and can see the Rx (K/L lines)
  17. #7515
    Dec 2018
    Got the 18.2.0!!! It's ALIVE!
    @KOLIMER! WHEREVER YOU ARE, GOD BLESS YOU.
    Small tribute for you man!
  18. The Following 4 Users Say Thank You to Laique For This Useful Post:
    amstel7 (28th August, 2019), Col19 (23rd January, 2019), Elektrik1 (31st December, 2018), Tib82 (1st January, 2019)
