Page 505 of 854 FirstFirst ... 5405455495500501502503504505506507508509510515555605 ... LastLast
Results 7,561 to 7,575 of 12803
  1. #7561
    Quote Originally Posted by Elektrik1 View Post
    Which corresponds to:
    !o18 = i11 & !i8;
    !o16 = (i11 & !i7) # (!i6 & !i5 & !i2);
    !o15 = !i5;
    !o13 = (!f17 & !i6 & !i2) # !f14;
    !o12 = !f17 & !i2;[/CODE]
    100% match to 1024 combinations logic, will check to all possible pins and outputs. Attaching fully working 0x46 .JED
    We made it!
    0x46.JED:
    CUPL(WM)        5.0a  Serial# 60008009
    Device          g16v8as  Library DLIB-h-40-2
    Created         Fri Jan 04 18:22:51 2019
    Name            0x46
    Partno          00
    Revision        01
    Date            2019-01-04
    Designer        Elektrik
    Company         *
    Assembly        None
    *QP20
    *QF2194
    *G0
    *F0
    *L00256 11111111111111111111111110111110
    *L00768 11111111111111111111101111111110
    *L00800 10111111111110111011111111111111
    *L01024 11111111111110111111111111111111
    *L01536 10111111111111101011111111111111
    *L01568 11111111111111111110111111111111
    *L01792 10111111111111101111111111111111
    *L02048 00000000001100000011000000100000
    *L02112 00000000101001001111111111111111
    *L02144 11111111111111111111111111111111
    *L02176 111111111111111110
    *C21AA
    *A040
    With this my compilation appear like..
    *QP20
    *QF2194
    *G1
    *F0
    *L00256 11111111111111111111111110111101
    *L00768 10111111111110111011111111111111
    *L00800 11111111111111111111101111111101
    *C222A
    *A207
    Which optimization used you?
    And...
    !o18 = i11 & !i8;
    For sure is not !i11?
  2. #7562
    xoom's Avatar
    Ylakiai
    !o18 = i11 & !i8 < - is this should not to be like: !o18 = (!i11 & !i8) # (!i5 & !i9) ?
  3. #7563
    i9 not used in 46..so..!i9 is 1 allways?
  4. #7564
    xoom's Avatar
    Ylakiai
    it is used in both 0x44 and 0x46... FTDI TX pin goes there
  5. #7565
    xoom's Avatar
    Ylakiai
    hmm or maybe it doesn't checked china board and yes its not connected but would be interesting to see original version
  6. #7566
    I remember the year when i modified my first 704 with RL by rerouting 3 wires and rewrote GAL with "44".jed (see Aminebot file).
    The FTDI Tx go to pin 5 GAL (STC, R50/R51/Reseter used too and desoldered)
    So, for sure the pin 9 not used.
    In my .jed two lines are reversed like in last 46.jed posted by Elektrik
    *L00800 11111111111111111111101111111110
    Where i wrong?
    I made only two modifications (without this the .jed is more different)
    Elektrik say this:
    PIN 18
    (1) X = I
    or K;
    not X = not I and not K;
    PIN 16
    (1) X = I and M
    or I and N
    or I and Q
    or L and M
    or L and N
    or L and Q;
    not X = not I and not L
    or not M and not N and not Q;
    PIN 17 MAYBE 15...
    (1) X = N;
    not X = not N;
    PIN 13
    (1) X = C and F
    or F and M
    or F and Q;
    not X = not C and not M and not Q
    or not F;
    PIN 12
    (1) X = C
    or Q;
    not X = not C and not Q;
    !o18 = !i11 & !i8;
    !o16 = (!i11 & !i7) # (!i6 & !i5 & !i2);
    !o15 = !i5;
    !o12 = !f17 & !i2;
    With this obtained
    *QP20
    *QF2194
    *G1
    *F0
    *C21AA
    *A220
  7. The Following User Says Thank You to liviudiaconu For This Useful Post:
    jakuza (11th January, 2019)
  8. #7567
    Look difference RL46 vs BM 44 GAL to FTDI/Atmega pins
  9. The Following 2 Users Say Thank You to liviudiaconu For This Useful Post:
    jakuza (11th January, 2019), xoom (5th January, 2019)
  10. #7568
    Dec 2016
    Vilnius, Lithuania
    liviudiaconu, ,yeah PIN 15 there should be, typo. Sorry forgot to post the header, this is full project:
    Name     0x46 ;
    PartNo   00 ;
    Date     2019-01-02 ;
    Revision 01 ;
    Designer Elektrik ;
    Company  * ;
    Assembly None ;
    Location  ;
    Device   g16v8a ;
    /* *************** INPUT PINS *********************/
    PIN 2    = i2                        ; /*                                 */
    PIN 3    = i3                        ; /*                                 */
    PIN 5    = i5                        ; /*                                 */
    PIN 6    = i6                        ; /*                                 */
    PIN 7    = i7                        ; /*                                 */
    PIN 8    = i8                        ; /*                                 */
    PIN 11   = !i11                       ; /*                                 */
    /* *************** OUTPUT PINS *********************/
    PIN 12   = o12                       ; /*                                 */
    PIN 13   = o13                       ; /*                                 */
    PIN 14   = f14                       ; /*                                 */
    PIN 15   = o15                       ; /*                                 */
    PIN 16   = o16                       ; /*                                 */
    PIN 17   = f17                       ; /*                                 */
    PIN 18   = o18                       ; /*                                 */
    PIN 19   = f19                       ; /*                                 */
    !o18 = i11 & !i8;
    !o15 = !i5;
    !o12 = !f17 & !i2;
    i11 is inverted in pin definition.
  11. The Following User Says Thank You to Elektrik1 For This Useful Post:
    liviudiaconu (6th January, 2019)
  12. #7569
    Newbie Mrjitter's Avatar
    Dec 2010
    Spain
    hi
    Searching through my old files I found this ....
    https://rapidgator.net/file/4ed94933..._love.zip.html
    I think this file corresponds to a gal file of type 0x46 for the images found in the doc attached in the files.
    the doc translate by google to english ...
    https://rapidgator.net/file/91f7ea31...ru.en.doc.html
    Please .... anyone can post the .jed gal file for 0x44 type ?
  13. #7570
    Sep 2016
    how to power up vcds with 12 v i got the ordino programer and i shearched here no pic how to do it i cant do it in my car obd2 the operation will be done here at my home in which pins i connect the ac charger 12 v to the vcds ?
  14. #7571
    Mar 2018
    [QUOTE = Mrjitter; 3464667] hi
    При поиске в моих старых файлах я нашел это ....
    Я думаю, что этот файл соответствует файлу gal типа 0x46 для изображения, найденные в документе, прилагаемом к файлам.
    Документ переведен Google на английский ...
    Пожалуйста .... кто-нибудь может опубликовать файл .jed gal для типа 0x44?
    С уважением [/ QUOTE]
    Пожалуйста
  15. The Following User Says Thank You to Roma77 For This Useful Post:
    Mrjitter (5th January, 2019)
  16. #7572
    Dec 2018
    I wonder why pin 19 and pin 3 is not used any longer? Audi needs RX on L Line?!
  17. #7573
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    heshamzn
    obd connector pin 16 + , 5 -
  18. #7574
    Dec 2016
    Vilnius, Lithuania
    Mjriter, it's 0x44 jed in your pack. C3H8, l line only needs to be output for 5baud wake process on old vw/audi ecu's. No other data is sent there afaik. That's why Lline input is not used.
  19. The Following User Says Thank You to Elektrik1 For This Useful Post:
  20. #7575
    Dec 2010
    Spain
    Ok Elektrik1
    Thank you for the clarification
