Does anyone own a genuine HEX-V2 and is willing to help?
If so, please write me a PM directly.
Thank you.
OK. What you do'it in definitions is what i obtained by following your formulas and modifying equations.
With your present equations i obtained the same file..
With ONE exception: lines 768 and 800 REVERSED. Yes, this two lines reffer at the same OUT but, why in my generator appear reversed?
Can you, please, send me your settings in WinCUPL?
Thank you..
A question:
When obtained truth-table of 46 GAL you run ALL combinations? I mean including pin 3 and pin 19 influences?
An idea: for see if .jed is correctly generatde try to obtain the same tables as with original.
Compare. If the same results, the equations are OK.
Thank you.
* MK100;
To match 100% input-output correlation (all 262144 combinations on app pins) to original 0x46 GAL, some additions were added, final code which confirms it is 1:1 clone:
0x46 JED:Code:Name 0x46 ; PartNo 00 ; Date 2019-01-02 ; Revision 01 ; Designer Elektrik ; Company * ; Assembly None ; Location ; Device g16v8a ; /* *************** INPUT PINS *********************/ PIN 2 = i2 ; /* */ PIN 3 = i3 ; /* */ PIN 4 = i4 ; /* */ PIN 5 = i5 ; /* */ PIN 6 = i6 ; /* */ PIN 7 = i7 ; /* */ PIN 8 = i8 ; /* */ PIN 11 = !i11 ; /* */ /* *************** OUTPUT PINS *********************/ PIN 12 = o12 ; /* */ PIN 13 = o13 ; /* */ PIN 14 = f14 ; /* */ PIN 15 = o15 ; /* */ PIN 16 = o16 ; /* */ PIN 17 = f17 ; /* */ PIN 18 = o18 ; /* */ PIN 19 = f19 ; /* */ !o18 = i11 & !i8; !o16 = (i11 & !i7) # (!i6 & (!i5 # !i4) & !i2); !o15 = !i5 # !i4; !o13 = (!f17 & !i6 & !i2) # !f14; !o12 = !f17 & !i2;
Don't know why it also responds on signals on pin 4 as well (which is not connected), maybe for some hybrid china clones, don't know. Attaching .JED project, which can be opened with WinCupl (open as project), also leaving pin combinational responses for original 0x46, compiled with this code 0x46, also performed check of original 0x44 response tables, and C3H8 compiled logic response (which I do confirm corresponds 100% to all original 0x44 input-outputs).Code:CUPL(WM) 5.0a Serial# 60008009 Device g16v8as Library DLIB-h-40-2 Created Sun Jan 06 19:17:12 2019 Name 0x46 Partno 00 Revision 01 Date 2019-01-02 Designer Elektrik Company * Assembly None Location *QP20 *QF2194 *G0 *F0 *L00256 11111111111111111111111110111110 *L00768 11111111111111111111101111111110 *L00800 10111111101111111011111111111111 *L00832 10111111111110111011111111111111 *L01024 11111111111110111111111111111111 *L01056 11111111101111111111111111111111 *L01536 10111111111111101011111111111111 *L01568 11111111111111111110111111111111 *L01792 10111111111111101111111111111111 *L02048 00000000001100000011000000100000 *L02112 00000000101001001111111111111111 *L02144 11111111111111111111111111111111 *L02176 111111111111111110 *C299A *AFE8
All decimals represented in such was:
DEC PIN19 PIN18 PIN17 PIN16 PIN15 PIN14 PIN13 PIN12 PIN11 PIN9 PIN8 PIN7 PIN6 PIN5 PIN4 PIN3 PIN2 PIN1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 ... 262143 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
hid3 (6th January, 2019), jakuza (11th January, 2019), liciniu2000 (28th November, 2020), pablobrsp (9th January, 2019), paro44 (7th January, 2019)
pin 4 not used in "46".
Still nothing about pins 3 and 19.
I think must be like in "44" equations for 12 and 13..
Something like
Code:! p12 = ((p17#p2)&(p19#p3)); ! p13 = (p17#p2#p6)&(p19#p3#p6)& p14;
thanks kolimer , good job
Pin 4 is not used, but is written in logic somewhy.
No pin19 and pin 3 usage in original GAL as well. I think it's normal, since LLine (19) input is not needed for any car afaik, it's onyl needed as an output for 5baud communication to wake up ECU. So only output. I may try to add logic you written, but perhaps test won't pass then. I have old ecu which needs LLine for wake up, and logic without 3 and 19 pins works fine there.
Perhaps the KKL protocol is no longer used, but there is software support in version HW46.
I propose to test this logic:Code:; =============== S U B R O U T I N E == HW:0X46 sub_229: sbi PORTA, PORTA4 lds r24, Kx_ctrl clr r25 sbrs r24, 5 rjmp loc_231 cbi PORTA, PORTA5 ; K-line select rjmp loc_232 ; -------------------------------------- loc_231: sbi PORTA, PORTA6 loc_232: sbrs r24, 6 rjmp loc_236 cbi PORTA, PORTA6 ; KL-line select rjmp loc_237 ; -------------------------------------- loc_236: sbi PORTA, PORTA6 loc_237: lds r24, Kx_stat clr r25 sbrs r24, 2 rjmp loc_23E cbi PORTA, PORTA0 ; K-line select rjmp loc_23F ; -------------------------------------- loc_23E: sbi PORTA, PORTA0 loc_23F: sbrs r24, 3 rjmp loc_243 cbi PORTA, PORTA1 ; KL-line select ret ; -------------------------------------- loc_243: sbi PORTA, PORTA1 ret ; End of function sub_229
Code:Name 0x46 ; PartNo 00 ; Date 2019-01-07 ; Revision 01 ; Designer XXX ; Company * ; Assembly None ; Location ; Device g16v8a ; /* *************** INPUT PINS **********************/ PIN 2 = i2 ; /* K-line select */ PIN 3 = i3 ; /* KL-line select */ PIN 4 = i4 ; /* */ PIN 5 = i5 ; /* FT_TXD */ PIN 6 = i6 ; /* FTDI <-> KKL enable */ PIN 7 = i7 ; /* K-line select */ PIN 8 = i8 ; /* KL-line select */ PIN 11 = i11 ; /* TXD1 */ /* *************** OUTPUT PINS *********************/ PIN 12 = o12 ; /* RXD1 */ PIN 13 = o13 ; /* FT_RXD */ PIN 14 = f14 ; /* TXD0 */ PIN 15 = o15 ; /* RXD0 */ PIN 16 = o16 ; /* TX1 K-line */ PIN 17 = f17 ; /* RX1 K-line */ PIN 18 = o18 ; /* TX2 KL-line */ PIN 19 = f19 ; /* RX2 KL-line */ o18 = ( i11 # i8 ) & ( i6 # ( i5 & i4) # i3 ); o16 = ( i11 # i7 ) & ( i6 # ( i5 & i4) # i2 ); o15 = i5 & i4; p13 = ( p17 # p2 # p6 ) & ( p19 # p3 # p6 ) & p14; p12 = ( p17 # p2 ) & ( p19 # p3 );
Elektrik1 (7th January, 2019)
I have modified it a bit, but it show this (does not work)
This might be because logic needs to be negated (all pins are pull-upped internally).Code:Name 0x46 ; PartNo 00 ; Date 2019-01-02 ; Revision 01 ; Designer Elektrik ; Company * ; Assembly None ; Location ; Device g16v8a ; /* *************** INPUT PINS *********************/ PIN 2 = i2 ; /* K-line select */ PIN 3 = i3 ; /* KL-line select */ PIN 4 = i4 ; /* NC but exists in original */ PIN 5 = i5 ; /* FT_TXD */ PIN 6 = i6 ; /* FTDI <-> KKL enable */ PIN 7 = i7 ; /* K-line select */ PIN 8 = i8 ; /* KL-line select */ PIN 11 = i11 ; /* TXD1 */ /* *************** OUTPUT PINS ********************/ PIN 12 = o12 ; /* RXD1 */ PIN 13 = o13 ; /* FT_RXD */ PIN 14 = f14 ; /* TXD0 */ PIN 15 = o15 ; /* RXD0 */ PIN 16 = o16 ; /* TX1 K-line */ PIN 17 = f17 ; /* RX1 K-line */ PIN 18 = o18 ; /* TX2 KL-line */ PIN 19 = f19 ; /* RX2 KL-line */ o18 = ( i11 # i8 ) & ( i6 # ( i5 & i4) # i3 ); o16 = ( i11 # i7 ) & ( i6 # ( i5 & i4) # i2 ); o15 = i5 & i4; p13 = ( f17 # i2 # i6 ) & ( f19 # i3 # i6 ) & f14; p12 = ( f17 # i2 ) & ( f19 # i3 );
Edit: inverted gives positive result on green light and test passes:
And it does connect to my old KL-Line ECU just fine.Code:!o18 = (!i11 & !i8) # (!i6 & (!i5 # !i4) & !i3); !o16 = (!i11 & !i7) # (!i6 & (!i5 # !i4) & !i2); !o15 = !i5 # !i4; !o13 = (!f17 & !i2 & !i6) # (!f19 & !i3 & !i6) # !f14; !o12 = (!f17 & !i2) # (!f19 & !i3);
A lot of differences to input-output combinatiosn to "original" chinese 46.
Latest project source:
and .JED for it:Code:Name 0x46 ; PartNo 00 ; Date 2019-01-02 ; Revision 01 ; Designer Elektrik ; Company * ; Assembly None ; Location ; Device g16v8a ; /* *************** INPUT PINS *********************/ PIN 2 = i2 ; /* K-line select */ PIN 3 = i3 ; /* KL-line select */ PIN 4 = i4 ; /* NC but exists in original */ PIN 5 = i5 ; /* FT_TXD */ PIN 6 = i6 ; /* FTDI <-> KKL enable */ PIN 7 = i7 ; /* K-line select */ PIN 8 = i8 ; /* KL-line select */ PIN 11 = i11 ; /* TXD1 */ /* *************** OUTPUT PINS ********************/ PIN 12 = o12 ; /* RXD1 */ PIN 13 = o13 ; /* FT_RXD */ PIN 14 = f14 ; /* TXD0 */ PIN 15 = o15 ; /* RXD0 */ PIN 16 = o16 ; /* TX1 K-line */ PIN 17 = f17 ; /* RX1 K-line */ PIN 18 = o18 ; /* TX2 KL-line */ PIN 19 = f19 ; /* RX2 KL-line */ !o18 = (!i11 & !i8) # (!i6 & (!i5 # !i4) & !i3); !o16 = (!i11 & !i7) # (!i6 & (!i5 # !i4) & !i2); !o15 = !i5 # !i4; !o13 = (!f17 & !i2 & !i6) # (!f19 & !i3 & !i6) # !f14; !o12 = (!f17 & !i2) # (!f19 & !i3);
Conclusion: my original GAL did not have this LLine readout functionality, only output wakening (5BAUD init sequence) functionality, which did also worked fine.Code:CUPL(WM) 5.0a Serial# 60008009 Device g16v8as Library DLIB-h-40-2 Created Mon Jan 07 02:05:26 2019 Name 0x46 Partno 00 Revision 01 Date 2019-01-02 Designer Elektrik Company * Assembly None Location *QP20 *QF2194 *G0 *F0 *L00256 11111111111111111111111110111110 *L00288 11111011101111111011111111111111 *L00320 11111011111110111011111111111111 *L00768 11111111111111111111101111111110 *L00800 10111111101111111011111111111111 *L00832 10111111111110111011111111111111 *L01024 11111111111110111111111111111111 *L01056 11111111101111111111111111111111 *L01536 10111111111111101011111111111111 *L01568 11111010111111111011111111111111 *L01600 11111111111111111110111111111111 *L01792 10111111111111101111111111111111 *L01824 11111010111111111111111111111111 *L02048 00000000001100000011000000100000 *L02112 00000000101001001111111111111111 *L02144 11111111111111111111111111111111 *L02176 111111111111111110 *C37E2 *CEE9
hid3 (7th January, 2019), jakuza (11th January, 2019), liviudiaconu (7th January, 2019), paro44 (7th January, 2019), seal777 (29th August, 2021)
I saw in the past more schemathics named "original"..for 44 and 46 too..
Only one of them having pin 4 pulled-up external too. Attached..
See ONLY pin 4 is pulled-up externaly. That make me think is used in logical as 1. pins 1 and 9 not used, so..not connected.
And another thing: the programm having a button named "OBD II". Is for generic and, as i saw work only for engine for other cars.
When i am lazzy time to time erase DTC for engine for my old Corsa 2001.
Is very possible using LLine for this "OBD generic"..
Is very possible too RT excluded the LLine support in 46 HW. I don't remember when 46 released..If someone having old installers can see in wich version appear HPxxx.bin. But this not explain why LLine circuit still exist.
Is very possible too, chineses tried extract dump or a person for them..and..extracted truncated or truncated by himself for this motive ("is old, no need")
I have old NEC clone hex-v2 fake. In Kolimer hw info tool it shows up as 0x46. K2 (L) didn't work in even when cable was brand new. Now something has fried inside and voltage regulator has 7V in input and 5V in output.
K1 sometimes work, sometimes not. Shi##y cable.
In this case, why RT mounted 1K on pin 4 to +?
Because GAL chips have ACTIVE pull-ups, resistor is an PASSIVE pull-up, it ensures always logical 1 on pin 4 even if VCC glitches occur (very small chance), it's just right way to terminate floating pins. Wonder why they didn't do it as well on pin 1 and 9, but perhaps that's because only PIN 4 is affecting logic (still not sure why it's defined in logic if it has static state, but it's question for RT).
RT never answer you or me..we know why..
We can suppose: maybe RT prepared logical for another pin (pin 4 in this case) and:
-the developing of that logic never applied.
-this logical applied for first series of "46" and after RT eliminated pin 4 from this and pulled up.
